By buying this product you get 424 loyalty points
This pack consists of a Tonewinner AD-1PA+ Class A stereo power amplifier, a Tonewinner AD-1PRE+ Class A/B DAC preamplifier and a UP-OCC Audiophonics Obsidian silver XLR-XLR modulation cable. This set will enable you to enjoy precise, powerful and detailed sound reproduction.
Tonewinner's AD-1PA is back in a "+" version with an optimized circuit. Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device, respecting the audio signal to reveal every detail. The amplifier stage of the Tonewinner AD-1PA+ embeds 8 pairs of high power transistors TTC5200 and TTA1943 within a Class A. These allow the amplifier to deliver a consequent power of 300W RMS per channel under 8Ω.
Find out more about the Tonewinner AD-1PA+ power ampThe Tonewinner AD-1PRE+ is a versatile preamplifier that offers a number of interesting features. In fact, it incorporates quality components such as an ES9038 DAC chip combined with two optical inputs, a CT7601PR USB interface, as well as a combination of no less than 9 AOPs (5x OPA1612, 4x OPA1632, 1x OPA1642) and a MUSES72323 volume controller. These components enable it to decode high-resolution streams up to PCM 32bit 768kHz and DSD up to DSD512, delivering a warm final sound with low noise and distortion over a wide dynamic range. When it comes to connectivity, the Tonewinner AD-1PRE+ preamplifier is also extremely complete. Inputs include 4 unbalanced RCA inputs, including two phono inputs (for MM and MC cells), one balanced XLR input, two coaxial SPDIF inputs, two Toslink optical inputs and one USB-B input. Outputs include 2 RCA line outputs and 1 XLR balanced line output. Finally, a trigger connector and remote control enhance the user experience.
Find out more about the Tonewinner AD-1PRE+ DAC preampThe Audiophonics Obsidian is based on the integration of the excellent Neotech NEMOI-1220 modulation cable. This high-end model features UP-OCC silver conductors with a rectangular cross-section (0.33mm²), insulated with a PTFE sheath. This special structure reduces the effect of inductance, while ensuring flawless conductivity. Double shielding consisting of copper foil and braid effectively repels interference that could alter the integrity of the signal. Finally, the whole assembly is held together by a PVC sheath and then covered with a black Viablue braided nylon sheath to great effect. Each Audiophonics Obsidian cable ends in an XLR Viborg connector, male XM203AG and female XF203AG. These maintain the cable's high level of conductivity by using pure silver contacts, housed within a sublime aluminium and carbon fibre body with PTFE insulation.
Find out more about Audiophonics Obsidian cablesTechnical characteristics
Tonewinner AD-1PA+ Specifications | |
Product type | Power amplifier |
Channels | Stereo (2) |
Amplification type | Class A Class AB |
Inputs | 1* Single-ended stereo RCA 1* Balanced stereo XLR |
Outputs | Speaker terminals |
Trigger | Input and output |
Output power | 300W RMS/channel @ 8Ω, 20Hz-20kHz, THD < 0.1%, two driven channels 500W RMS/channel @ 4Ω, 20Hz-20kHz, THD < 0.1%, one driven channel 320W RMS/channel @ 8Ω, THD < 0.1%, one driven channel |
Pure class A output power | 100W @ 8Ω |
Impedance | 8Ω |
Channel separation | ≥ 80dB |
Bias selection | Class A Class AB Auto |
Speaker output mode | A B A+B |
Frequency response | 10Hz-100kHz (+1/-3dB) |
THD+N | < 0.008% @ 1kHz |
SNR | ≥ 108dB (A-weighted) |
Recommended minimum load impedance (per channel) | 2Ω |
Damping factor | > 200 @ 8Ω |
Input sensitivity | 1.6V @ rated power, 8Ω |
Gain | 29.5dB ±1dB |
Supply voltage | 110-240V AC 50/60Hz |
Dimensions | 444*294*449 |
Net weight | 43.4kg |
Housing material | Aluminum |
Color | Black and silver |
Package | 1* Tonewinner AD-1PA+ 1* Power cable |
Tonewinner AD-1PRE+ Spécifications | |
Product type | Preamplificateur / DAC |
Amplification class | A/B |
DAC chip | ES9038 |
OPA | 5x OPA1612 4x OPA1632 1x OPA1642 |
Volume control | MUSES72323 |
Inputs | 4x RCA stereo input (Phono MM, Phono MC, CD, AUX) 1x Balanced XLR input 2x SPDIF coaxial input 2x Toslink optical input 1x USB-B input |
Outputs | 2x RCA stereo output 1x XLR stereo output |
Supported sample rates | USB : PCM 32bit 768kHz,DSD DoP256, native DSD512 Optical : 24bit 192kHz, DSD DoP64 |
Supported audio formats | SACD, ALAC, APE, DIFF, DSF, FLAC, OGG, WAV, AAC, MP3, WMA |
Nominal input impedance | 20 kΩ (analog inputs) |
THD | ≤ 0.0035% (1kHz) |
SNR | ≥ 110dB (A-weighted, direct analog) |
Frequency response | 10Hz-180kHz (+1/-3dB, direct analog) |
Crosstalk | ≥ 102dB (1kHz, analog) |
Power Supply | 110V-115V AC 60Hz, 220V-230V AC 50Hz |
Dimensions | 444 × 106 × 424mm |
Net weight | 9.7kg |
Color | Silver |
Package | 1x Tonewinner AD-1PRE+ preamplifier 1x Remote control 1x Power cable |
Audiophonics Obsidian Specifications | |
Product type | Interconnect cable |
Length | 0.75m |
Connectors | Male XLR Female XLR |
Quantity | Pair (one cable with red connectors, one cable with black connectors) |
Conductors material | UP-OCC Silver (rectangular cross-section) |
Number of conductors | 2 |
Conductors sections | 0.33mm² |
Shielding | Copper-Mylar foil + braided copper |
Insulation | PTFE + PE + PVC + Cotton |
External sheath | PE + PVC |
Resistance | 0.054Ω/m |
Capacitance | 38.19pF/m |
Inductance | 0.86µH/m |
Diameter | Ø10mm |
Contact material | Pure silver (99.998%) |
Contact body material | Aluminum and carbon fiber |
Contact insulation | PTFE |
