Pack Audiophonics AP300-S250NC + SMSL DO100 Pro + Audiophonics Wire XLR 30cm
We offer you an Audiophonics and SMSL product pack comprising the AP300-S250NC power amplifier, the SMSL DO100 DAC and a pair of XLR modulation cables for balanced connection. This high-end package is perfect for anyone wishing to benefit from a large power reserve and multiple digital inputs. Coupled with passive speakers, this combination is sure to bring out the best in your music.
By buying this product you get 72 loyalty points
Reference : 19482
729,00 €tax incl.
607,50 € tax excl.
Instead of 817,90 €
Pack content
Pack Audiophonics x SMSL Audiophonics AP300-S250NC + SMSL DO100 Pro + Audiophonics Wire XLR 30cm
Photo of Audiophonics AP300-S250NC + SMSL DO100 Pro + Audiophonics Wire XLR 30cm
Audiophonics AP300-S250NC: Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
The Audiophonics AP300-S250NC is a stereo amplifier based on an Hypex Ncore NC252MP amplification module. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
View complete product page of Audiophonics AP300-S250NC Audiophonics AP300-S250NC
SMSL DO100 Pro: DAC Symétrique 2x ES9039Q2M XMOS SU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a third-generation XU316 USB XMOS interface, enabling it to support high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD. An HDMI ARC port also enables the DO100 PRO to be linked to a TV as well as to active speakers or an amplification system, for a high-quality, immersive sound experience. A QCC5125 Bluetooth receiver chip completes the DO100 PRO's versatility, enabling wireless transmission with high-definition codecs: SBC, AAC, aptX, aptX HD, LDAC. Numerous digital inputs and two balanced RCA and XLR analog outputs make this a device of choice.
View complete product page of SMSL DO100 Pro SMSL DO100 Pro
AUDIOPHONICS WIRE Interconnect Cable Stereo XLR OFC Copper Gold Plated 30cm (Pair)
These balanced XLR interconnect cables, assembled in our workshops in France, consists of a Mogami Neglex W2549 cable and Neutrik NC3FXX-B and NC3MXX-B XLR connectors. It features OFC copper conductors and full shielding, while the connector contacts are 24K gold-plated for increased resistance to corrosion and oxidation.
View complete product page of AUDIOPHONICS WIRE XLR 30 cm AUDIOPHONICS WIRE XLR 30 cm
Products typePower amplifier + DAC + Interconnect cables
Package contents1x Audiophonics AP300-S250NC
1x SMSL DO100 Pro
1x Audiophonics Wire XLR 30cm (pair)
AP300-S250NC specifications
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Unbalanced Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Dimensions300 x 220 x 65mm
Weight2080g
Package1x Audiophonics AP300-S250NC
1x Power cable
SMSL DO100 Pro Specifications
Product typeDAC
DAC chip2x ES9039Q2M
USB interfaceXMOS XU316
AOP6x OPA1612
Inputs1x USB-C input
1x Toslink optical input
1x Coaxial SPDIF input
1x HDMI ARC
Bluetooth
Outputs1x RCA Stereo
1x XLR balanced stereo
Supported sampling ratesUSB: PCM 32bit 768kHz, DSD DoP256, DSD512 and MQAx8/MQA-CD
Toslink optical and SPDIF coaxial: 24bit 192kHz, DSD DoP64 and MQAx8/MQA-CD
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD et LDAC
Output levelRCA : 2.5Vrms
XLR : 5Vrms
THD+N0.00005% (-124.5dB non-weighted)
Dynamic rangeXLR : 131dB RCA : 127dB
SNRXLR : 131dB RCA : 127dB
Output impedance100 ohms
USB TransmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
MAC OSX 10.6 et + / Linux (without driver)
Power consumption<10w
Standby : <0.5W
Dimensions189x45x186mm
Weight1.45kg
Package1x SMSL DO100 PRO DAC
1x USB-C cable
1x Bluetooth antenna
1x IR remote control
1x Mains cable
AUDIOPHONICS WIRE XLR 30CM Specifications
Product typeStereo XLR cable (pair)
Connectors2* Male XLR
2* Female XLR
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Neutrik connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialPolyamide
Pack Audiophonics AP300-S250NC Amplifier + SMSL DO100 Pro DAC + Audiophonics Wire XLR Cables 30cm
We offer you an Audiophonics and SMSL product pack comprising the AP300-S250NC power amplifier, the SMSL DO100 DAC and a pair of XLR modulation...
