Pack Audiophonics AP300-S500NC + SMSL DO400 + Audiophonics Wire XLR 30cm
We offer you an Audiophonics and SMSL product pack comprising the AP300-S500NC power amplifier, the SMSL DO400 DAC and a pair of XLR modulation cables for balanced connection. This high-end package is perfect for anyone wishing to benefit from a large power reserve and multiple digital inputs. Coupled with passive speakers, this combination is sure to bring out the best in your music.
By buying this product you get 118 loyalty points
Reference : 19481
1 189,00 €tax incl.
990,83 € tax excl.
Instead of 1 287,90 €
Pack content
Pack Audiophonics x SMSL Audiophonics AP300-S500NC Amplifier + SMSL DO400 DAC + Audiophonics Wire XLR 30cm
Photo of pack Audiophonics APS300-S500NC + SMSL DO400 + Audiophonics Wire XLR 30cm
Audiophonics AP300-S500NC : Class D Stereo Power Amplifier Ncore NC502MP 2x500W 4 Ohm
The Audiophonics AP300-S500NC is a stereo power amplifier based on an Hypex Ncore NC502MP amplification module. This solution is ideal for anyone who wants to have a large power reserve (2x500W into 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
View complete product page of Audiophonics AP300-S500NC Audiophonics AP300-S500NC
SMSL DO400 : DAC ES9039MSPRO Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Black
SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the latest ESS ES9039MSPro chip, an XMOS XU316 USB interface, 11 OPA 1612A and the latest generation Qualcomm QCC5125 Bluetooth chip. To complete the package, an MQA decoder is integrated into the DO400, enabling it to decode high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA-CD. Headphone amplifier performance is also very good, thanks to the use of a PLFC circuit. The DO400's complete and varied connectivity will adapt to a wide range of configurations and input sources. SMSL has opted for an internal symmetrical circuit design, and the exterior features a large screen and a number of small aesthetic details, making this a pleasing-looking device.
View complete product page of SMSL DO400 SMSL DO400
Audiophonics Wire : Interconnect Cable Stereo XLR OFC Copper Gold Plated 30cm (Pair)
These balanced XLR interconnect cables, assembled in our workshops in France, consists of a Mogami Neglex W2549 cable and Neutrik NC3FXX-B and NC3MXX-B XLR connectors. It features OFC copper conductors and full shielding, while the connector contacts are 24K gold-plated for increased resistance to corrosion and oxidation.
View complete product page AUDIOPHONICS WIRE XLR 30 cm AUDIOPHONICS WIRE XLR 30 cm
Products typePower amplifier + DAC + Interconnect cables
Package contents1x Audiophonics APS300-S500NC
1x SMSL DO400
1x Audiophonics Wire XLR 30cm
AP300-S500NC specifications
Product typeAmplifier
Amplification typeClass D
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x350W @ 8Ω
2x500W @ 4Ω
2x450W @ 2Ω
Input1x Single Ended Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0018%
SNR124dB
Output noise47µV
Output impedance1.5mΩ
Frequency response10Hz - 48kHz
Efficiency92%
Input sensitivityMax Power at 2.35V RMS
XLR : 2x1.17V RMS
RCA : 2.35V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Dimensions300 x 220 x 65mm
Weight2080g
Package1x Audiophonics AP300-S500NC
1x Power cable
DO400 specifications
Product typeDAC
Headphone amplifier
Input1x USB-B
1x Coaxial
1x AES/EBU
1x Optical Toslink
1x I2S via HDMI
Bluetooth
Outputs1x Stereo RCA analog output
1x XLR stereo balanced output
1x XLR 4-pin balanced headphone output
1x 4.4mm balanced headphone jack output
1x 6.35mm unbalanced headphone jack output
Supported sample ratesPCM 32bit 768kHz, DoP64, DoP256 DSD512, MQA, MQA-CD
Output levelXLR: 5.2Vrms
RCA: 2.5Vrms
Headphone output power2x 6000mW / 16Ω
2x 3000mW / 32Ω
2x 700mW / 300Ω
2x 350mW / 600Ω
THD+NXLR: 0.00005% (-125dB, unweighted)
RCA: 0.00007% (-123dB, unweighted)
HPA: 0.00009% (-120dB, unweighted)
Dynamic rangeXLR: 133dB
RCA: 128dB
HPA: 126dB
SNRXLR: 133dB
RCA: 128dB
HPA: 126dB
Output impedanceLine outputs : 100Ω
Headphone outputs : near 0Ω
Headphone output gainBalanced: +20dB
Unbalanced: +14dB
USB transmission2.0 asynchronous
USB compatibilityWindows 7/8/9/10/11 (with driver)
Mac OS 10.6
Linux
MQA decoding MQA : USB, Optical Toslink, Coaxial, AES/EBU
MQA-CD : Optical Toslink, CoaxialAES/EBU
Supported bluetooth codecsAAC, SBC, aptX, aptX HD, et LDAC
Power consumption< 40W
Standbye power consumption< 0.5W
Dimensions245 x 186 x 42mm
Weight1.45kg
Package1x DAC / Headphone amplifier DO400 SMSL
1x Power cable
1x USB-A to USB-B cable
1x Bluetooth antenna
1x Remote control
AUDIOPHONICS WIRE XLR 30CM specifications
Product typeStereo XLR cables (pair)
Connectors2* Male XLR
2* Female XLR
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Neutrik connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialPolyamide
Pack Audiophonics AP300-S500NC Amplifier + SMSL DO400 DAC + Audiophonics Wire XLR Cables 30cm
We offer you an Audiophonics and SMSL product pack comprising the AP300-S500NC power amplifier, the SMSL DO400 DAC and a pair of XLR modulation...
