Pack Audiophonics AP310-PREAMP Preamplifier + Audiophonics AP300-S250NC Amplifier + Câbles XLR Audiophonics Wire 30cm
This Audiophonics pack includes the AP310-PREAMP preamplifier, the AP300-S250NC stereo amplifier, Audiophonics Wire XLR connection cables and a trigger cable. It will enable you to set up a high-performance HiFi system, capable of reproducing your music with dynamics and precision. What's more, the devices are designed to work together, with the same sober, modern design for a coherent aesthetic, especially when placed one on top of the other. XLR cables enable symmetrical connection, and trigger cables automate synchronized ignition of the two devices.
By buying this product you get 84 loyalty points
Reference : 19583
845,00 €tax incl.
704,17 € tax excl.
Instead of 941,80 €
Pack content
Pack Audiophonics AP310-PREAMP + AP300-S250NC + Wire XLR Preamplifier + Amplifier + XLR Cables 30cm + Trigger cable
Pack Audiophonics AP310-PREAMP + AP300-S250NC + Wire XLR cables + Trigger cables
This Audiophonics pack includes the AP310-PREAMP preamplifier, the AP300-S250NC stereo power amplifier, Audiophonics Wire XLR connection cables and a trigger cable. It will enable you to set up a high-performance HiFi system, capable of reproducing your music with dynamics and precision. What's more, the devices are designed to work together, with the same sober, modern design for a coherent aesthetic, especially when placed one on top of the other. XLR cables enable symmetrical connection, and trigger cables automate synchronized ignition of the two devices.
Audiophonics AP310-PREAMP preamplifier
Audiophonics AP310-PREAMP: Balanced preamplifier
The Audiophonics AP310-PREAMP is a purely analog balanced preamplifier. Combining comfortable power with MUSES72320 volume control and full connectivity, this preamplifier is a sure bet for setting up a high-performance HiFi system.
FIND OUT MORE ABOUT THE AUDIOPHONICS AP310-PREAMP PREAMPLIer
Audiophonics AP300-S250NC: NCore NC252MP Power amplifier
The Audiophonics AP300-S250NC is a stereo amplifier based on a Hypex NCore NC252MP amplifier module. This solution is ideal for those who want a substantial power reserve (2x250W into 4Ω) without sacrificing sound quality. This amplifier block is ideal, for example, for accompanying demanding loudspeakers, providing sound reinforcement for large listening rooms, or for studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
FIND OUT MORE ABOUT THE AUDIOPHONICS AP300-S250NC AMPLIFIER
Audiophonics AP300-S250NC amplifier
Audiophonics Wire XLR cables
Audiophonics Wire XLR: XLR Cables
The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire XLR cable features a Mogami Neglex W2549 modulation cable and Neutrik NC3MXX-B and NC3FXXB male and female XLR connectors, ensuring excellent conductivity and durability for efficient audio signal transmission.
FIND OUT MORE ABOUT AUDIOPHONICS WIRE XLR CABLES
Product typePreamplifier + power amplifier + XLR cables + trigger cables
Pack content1x Audiophonics AP310-PREAMP
1x Audiophonics AP300-S250NC
1x XLR 30cm Audiophonics Wire cables pair
1x Jack 3.5mm trigger cable 1.8m
Audiophonics AP310-PREAMP preamplifier specifications
Inputs1x Balanced stereo female XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo male XLR
Volume range-90dB - +12dB
Gain settings0dB
+6dB
+12dB
OLED screenBrightness not adjustable
Automatic switch-off after 40 seconds
Input impedance10kΩ
Supply voltage100-240V AC
Dimensions295 x 220 x 65mm
Weight1.56kg
Case materialBrushed aluminum
Black acrylic front panel
Package1x Audiophonics AP310-PREAMP
1x Remote control
1x Power cable
Audiophonics AP300-S250NC amplifier specifications
Product typePower amplifier
Amplification typeClass D
Number of channelsStereo (2)
Max output power (@ 1kHz, THD=1%)2x150W à 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Inputs1x Balanced stereo XLR
OutputsSpeaker terminals
TriggerYes
5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Dimensions300 x 220 x 65mm
Weight2.08kg
Package1x Audiophonics AP300-S250NC
1x Power cable
Audiophonics Wire XLR cables specifications
Product typeXLR cables
Connectors2x Male XLR
2x Female XLR
Length30cm
Cable conductors materialOFC copper
Cable conductors section0.339mm² (22 AWG)
Cable conductors diameterØ1.9mm
Cable conductors insulation materialXLPE (cross-linked polyethylene)
Cable outer sheath materialPVC
Connectors contacts materialCopper alloy
Connectors contacts platingGold 24k
Connectors body materialPolyamide
This Audiophonics pack includes the AP310-PREAMP preamplifier, the AP300-S250NC stereo amplifier, Audiophonics Wire XLR connection cables and a...
