By buying this product you get 84 loyalty points
The Aune S17 Pro headphone amplifier/preamplifier and Aune AR5000 headphones package lets you enjoy audiophile headphone listening, as well as taking advantage of the S17 Pro's preamplifier function within your Hi-Fi system.
With its S17 Pro, Aune unveils a powerful headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features discrete components and balanced outputs. Its Class A amplification stage is equipped with a pair of JFET transistors for the headphone outputs, plus two OPAs per output for a total of 16 OPAs. It also features an R2R volume control and an attractive color display on the front panel. Inputs include stereo RCA and balanced stereo XLR. Powerful, the S17 Pro is able to drive any type of headphone on the market, whether with an impedance of 32Ω or 600Ω.
View complete product page of AUNE S17 PROAune's AR5000 are open-air headphones with a dynamic MLD (“Multi-Layer Distributed”) driver of no less than Ø50mm. Thanks to its innovative driver, high-angle acoustic structure and concentric-circle port system, these headphones deliver rich, detailed reproduction over a wide soundstage. Its 28 ohm impedance and 108dB sensitivity make it easy to control. A detachable 2x jack 3.5mm to jack 3.5mm termination cable accompanies the Aune AR5000.
View complete product page AUNE AR5000Technical characteristics
Products type | Headphone amplifier/preamplifier + headphones |
Package contents | 1x Aune S17 Pro 1x Aune AR5000 |
Aune S17 Pro specifications | |
Product type | Headphone amplifier Preamplifier |
Inputs | 1x Stereo RCA input 1x Balanced stereo XLR input |
Outputs | 1x 6.35mm jack headphone output 1x Balanced 4.4mm jack headphone output 1x XLR 4-pin balanced headphone output 1x RCA line output 1x XLR line output |
INPUT/OUTPUT IMPEDANCE | |
RCA input impedance | 10KΩ |
RCA output impedance | 200Ω |
XLR input impedance | 22KΩ |
XLR output impedance | 100Ω |
Headphone output impedance | 1Ω |
6.35MM Jack HEADPHONE OUTPUT | |
Frequency response | 20Hz - 80kHz (+/- 5dB) |
THD+N | < 0.00038% @1kHz |
SNR | > 115dB @600Ω |
Crosstalk | < -105dB @1kHz 600Ω |
BALANCED XLR HEADPHONE OUTPUT | |
THD+N | < 0.00016% @1kHz |
SNR | > 116dB @600Ω |
Crosstalk | < -110dB @1kHz 600Ω |
GAIN-RELATED OUTPUT POWER | |
G-L 6.35mm jack headphone output (Low Gain) | |
738mW @ 32Ω | |
250mW @ 100Ω | |
166mW @ 150Ω | |
100mW @ 250Ω | |
83mW @ 300Ω | |
53mW @ 470Ω | |
41mW @ 600Ω | |
G-L Balanced headphone output (Low Gain) | |
2773mW @ 32Ω | |
968mW @ 100Ω | |
645mW @ 150Ω | |
388mW @ 250Ω | |
333mW @ 300Ω | |
212mW @ 470Ω | |
166mW @ 600Ω | |
G-H 6.35mm jack headphone output (High Gain) | |
2020mW @ 32Ω | |
675mW @ 100Ω | |
453mW @ 150Ω | |
273mW @ 250Ω | |
228mW @ 300Ω | |
145mW @ 470Ω | |
114mW @ 600Ω | |
G-H Balanced headphone output (High Gain) | |
7507mW @ 32Ω | |
2643mW @ 100Ω | |
1793mW @ 150Ω | |
1089mW @ 250Ω | |
908mW @ 300Ω | |
580mW @ 470Ω | |
453mW @ 600Ω | |
Dimensions | 211 x 288 x 63mm |
Color | Black |
Package | 1x Aune S17 Pro headphone amplifier/preamplifier Black 1x Power cable 1x Remote control (CR1220 battery not included) |
Aune AR5000 Specifications | |
Product type | Open-back headphones |
Driver type | Dynamic with MLD technology |
Frequency response | 5Hz-41kHz |
Nominal impedance | 28 Ohm |
Sensitivity | 108dB (@ 1kHz, 1Vrms) |
THD | <0.03% (@ 1kHz, 100dB SPL) |
Cable type | Detachable |
Heaphone connectors | 2x Jack 3.5mm |
Cable terminaison | Jack 3.5mm |
Cable length | 1.5m |
Dimensions | 195 x 220 x 115mm (LxHxP) |
Net weight | 350g |
Package | 1x Aune AR5000 headphones 1x Cable 2x jack 3.5mm stereo to termination jack 3.5mm stereo |
