Pack Aune S17 Pro EVO Headphone Amplifier + Aune AR5000 Headphones
The Aune S17 Pro headphone amplifier/preamplifier and Aune AR5000 headphones package lets you enjoy audiophile headphone listening, as well as taking advantage of the S17 Pro's preamplifier function within your Hi-Fi system.
By buying this product you get 99 loyalty points
Reference : 19393
999,00 €tax incl.
832,50 € tax excl.
Instead of 1 168,00 €
Pack content
Pack Aune Aune S17 Pro EVO headphone amplifier + Aune AR5000 headphones
Pack Aune S17 Pro EVO headphone amplifier + Aune AR5000 headphones
The Aune S17 Pro EVO headphone amplifier/preamplifier and Aune AR5000 headphones package lets you enjoy audiophile headphone listening, as well as taking advantage of the S17 Pro's preamplifier function within your Hi-Fi system.
Aune S17 PRO EVO: Amplificateur Casque / Préamplificateur Discret Class A Symétrique 7500mW 32Ω Noir
With its S17 Pro EVO, Aune unveils a powerful Class A headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features discrete components and balanced outputs. Its final output stage uses two pairs of transistors in parallel, and the unit totals 16 output transistors. It also incorporates an R2R volume control and an attractive color display on the front panel. Inputs include single-ended RCA and balanced XLR. Powerful, the S17 Pro EVO can drive all types of headphones, from 32Ω to 600Ω impedance. The EVO version of the S17 Pro adds to all this independent volume management between its line and headphone outputs, as well as improved temperature management for more efficient cooling.
View complete product page of AUNE S17 PRO Aune S17 Pro
Aune AR5000 : Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz
Aune's AR5000 are open-air headphones with a dynamic MLD (“Multi-Layer Distributed”) driver of no less than Ø50mm. Thanks to its innovative driver, high-angle acoustic structure and concentric-circle port system, these headphones deliver rich, detailed reproduction over a wide soundstage. Its 28 ohm impedance and 108dB sensitivity make it easy to control. A detachable 2x jack 3.5mm to jack 3.5mm termination cable accompanies the Aune AR5000.
View complete product page AUNE AR5000 Aune AR5000
Products typeHeadphone amplifier/preamplifier + headphones
Package contents1x Aune S17 Pro EVO
1x Aune AR5000
Aune S17 Pro EVO specifications
Preamplifier
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs1x Single-ended jack 6.35mm headphone output
1x Balanced jack 4.4mm headphone output
1x Balanced XLR 4-pin headphone output
1x Single-ended RCA line output
1x Balanced XLR line output
INPUT/OUTPUT IMPEDANCE
RCA input impedance10KΩ
RCA output impedance200Ω
XLR input impedance10KΩ
XLR output impedance100Ω
Headphone output impedance1Ω
6.35MM Jack HEADPHONE OUTPUT
Frequency response20Hz - 80kHz (+/- 0.05dB)
THD+N< 0.00038% @1kHz
SNR> 115dB @600Ω
Crosstalk< -105dB @1kHz 600Ω
BALANCED XLR HEADPHONE OUTPUT
THD+N< 0.00016% @1kHz
SNR> 116dB @600Ω
Crosstalk< -110dB @1kHz 600Ω
GAIN-RELATED OUTPUT POWER
G-L 6.35mm jack headphone output (Low Gain)
738mW @ 32Ω
266mW @ 100Ω
177mW @ 150Ω
106mW @ 250Ω
88mW @ 300Ω
56mW @ 470Ω
44mW @ 600Ω
G-L Balanced headphone output (Low Gain)
2880mW @ 32Ω
1000mW @ 100Ω
694mW @ 150Ω
416mW @ 250Ω
347mW @ 300Ω
221mW @ 470Ω
173mW @ 600Ω
G-H 6.35mm jack headphone output (High Gain)
2050mW @ 32Ω
688mW @ 100Ω
464mW @ 150Ω
282mW @ 250Ω
235mW @ 300Ω
150mW @ 470Ω
117mW @ 600Ω
G-H Balanced headphone output (High Gain)
7500mW @ 32Ω
2673mW @ 100Ω
1837mW @ 150Ω
1102mW @ 250Ω
918mW @ 300Ω
586mW @ 470Ω
459mW @ 600Ω
Dimensions288 x 211 x 63mm
Package1x Aune S17 Pro EVO headphone amplifier/preamplifier Black
1x Power cable
1x Remote control
1x 1x Jack 6.35mm to Jack 3.5mm adapter
Aune AR5000 Specifications
Product typeOpen-back headphones
Driver typeDynamic with MLD technology
Frequency response5Hz-41kHz
Nominal impedance28 Ohm
Sensitivity108dB (@ 1kHz, 1Vrms)
THD<0.03% (@ 1kHz, 100dB SPL)
Cable typeDetachable
Heaphone connectors2x Jack 3.5mm
Cable terminaisonJack 3.5mm
Cable length1.5m
Dimensions195 x 220 x 115mm (LxHxP)
Net weight350g
Package1x Aune AR5000 headphones
1x Cable 2x jack 3.5mm stereo to termination jack 3.5mm stereo
Great Combo, crazy value
First of all big thanks to the audiophonics team for shipping out this pack very quickly, even though the S17 was not in stock in black at the time of order, as i was very excited and didn't want to wait i asked if it was possible to send the amplifier in silver along with the headphones and so the order was modified immediately without any complications and shipped out the same day, what can i say....what a great service! ! !
Now on two both units:
The Aune AR-5000 are outstanding headphones in this price bracket, i have compared them to similar priced headphones from Fiio, Sennheiser, Hifiman and Audio-Technica and even though the burn-in phase has not been completed yet i'm already sure that they will compete with the best if not take the crown in the below 500 Euro price range.
The Aune S17 Pro, i was very excited to get my hands on this one as i had the opportunity to get a short listen at an exhibition show, so i knew already what to expect from this one and i think this a fantastic amp it drives all my headphones with ease even the Hifiman HE-6 SE V2 one of hardest headphones to drive it needs a lot of current which the s17 is able to deliver i think they reached now their full potential with this amp. Concerning the temperature issue that a lot of users complained over the internet is not happening in my used case, i have the unit placed on my desktop with some space left on each side and on top, i added also absorber feet to the bottom of the unit to elevate its position and this further improves the airflow around the unit to help to keep the unit cool (below 62 degrees celsius with 100 MA mode engaged for several hours) So i guess for me this is it, this unit will be my main amp for a very long time to come.....
This review has been posted for Pack Aune S17 Pro EVO Headphone Amplifier + Aune AR5000 Headphones
The Aune S17 Pro headphone amplifier/preamplifier and Aune AR5000 headphones package lets you enjoy audiophile headphone listening, as well as...
