By buying this product you get 40 loyalty points
The Aune Yuki portable DAC/headphone amplifier and Aune AR5000 headphones are the perfect package for audiophile headphone listening.
The Aune Yuki is a portable DAC/headphone amplifier featuring two CS43198 DAC chips and 16 transistors for the amplifier stage. It supports high-resolution streams up to PCM 32bit 768kHzand DSD512 via its USB-C input. Its 3.5mm jack output delivers up to 90mW into 30 ohm, and its balanced 4.4mm jack output up to 160mW into 30 ohm.
View complete product page of AUNE YUKIAune's AR5000 are open-back headphones with a dynamic MLD (“Multi-Layer Distributed”) driver of no less than Ø50mm. Thanks to its innovative driver, high-angle acoustic structure and concentric-circle port system, these headphones deliver rich, detailed reproduction over a wide soundstage. Its 28-ohm impedance and 108dB sensitivity make it easy to drive. A detachable 2x jack 3.5mm to jack 3.5mm termination cable accompanies the Aune AR5000.
View complete product page of AUNE AR5000Technical characteristics
Products type | Portable DAC/headphone amplifier + headphones |
Package contents | 1x Aune Yuki 1x Aune AR5000 |
AUNE YUKI SPECIFICATIONS | ||
Product type | Portable DAC | |
DAC chip | 2x CS43198 | |
Input | USB-C | |
Outputs | 1x 3.5mm jack 1x 4.4mm balanced jack | |
Supported sample rates | PCM 32bit 768kHz, native DSD up to DSD512 | |
3.5MM HEADPHONE OUTPUT | ||
Output level | 2Vrms | |
Noise floor | 2.6uV | |
THD+N | 0.00036% | |
Output power | 90mW @ 30 Ohm | |
BALANCED 4.4MM HEADPHONE OUTPUT | ||
Output level | 4Vrms | |
Noise floor | 2.9uV | |
THD+N | 0.00033% | |
Output power | 160mW @ 30 Ohm | |
Dimensions | 24 x 53.5 x 13mm | |
Color | Silver | |
Package | 1x Aune YUKI portable dac |
AUNE AR5000 Specifications | |
Product type | Open-back headphones |
Driver type | Dynamic with MLD technology |
Frequency response | 5Hz-41kHz |
Nominal impedance | 28 Ohm |
Sensitivity | 108dB (@ 1kHz, 1Vrms) |
THD | <0.03% (@ 1kHz, 100dB SPL) |
Cable type | Detachable |
Heaphone connectors | 2x Jack 3.5mm |
Cable terminaison | Jack 3.5mm |
Cable length | 1.5m |
Dimensions | 195 x 220 x 115mm (LxHxP) |
Net weight | 350g |
Package | 1x Aune AR5000 headphones 1x Cable 2x jack 3.5mm stereo to termination jack 3.5mm stereo |
