Pack Bluesound Node Icon Streamer + Topping LA90D Amplifier + Topping TCX1 25cm Cables
We're offering a Bluesound x Topping product pack consisting of the Bluesound Node Icon network player, a Topping LA90D amplifier, and a pair of Topping TCX1 XLR modulation cables (25cm). This all-in-one package lets you enjoy a connected hifi system with plenty of power reserve and cutting-edge sound reproduction.
By buying this product you get 189 loyalty points
Reference : 19823
1 899,00 €tax incl.
1 582,50 € tax excl.
Instead of 2 038,01 €
Pack content
Pack Bluesound x Topping Bluesound Node Icon Streamer + Topping LA90D Amplifier + Topping TCX1 25cm XLR Cables
Photo du pack Bluesound x Topping
We're offering a Bluesound x Topping product pack consisting of the Bluesound Node Icon streamer, a Topping LA90D amplifier, and a pair of Topping TCX1 XLR modulation cables (25cm). This package lets you enjoy a connected hifi system with plenty of power reserve and cutting-edge sound reproduction.
Bluesound Node Icon: Multiroom Streamer WiFi Bluetooth 5.2 24bit 192kHz DSD256 MQA
The Bluesound Node Icon is a headphone amplifier and multi-room streamer that gives you remote control of your HiFi system. Its extensive compatibility with, in particular, Airplay 2, Spotify Connect, TIDAL Connect and Roon Ready gives it great versatility, making it easy to adapt to a wide range of configurations.
Its THX AAA amplifier chip enables the Node Icon to boast an output power of 230mW at 32Ω. Furthermore, you'll be able to take advantage of its dual-mono digital-to-analogue conversion stage using a single-channel SABRE DAC chip, allowing the Node Icon to support 24bit PCM up to 192kHz and DSD up to DSD256.
View complete product page of Bluesound Node Icon Bluesound Node Icon
Topping LA90D: Discrete Amplifier Class AB 2x120W / 1x180W 4 Ohm Black
Topping now offers the excellent LA90 in a version using discrete circuits, the LA90 Discrete. The result is a powerful amplifier with incredible metering for a breathtaking listening experience. The new NFCA discrete amplifier circuitry ensures extremely clear and precise sound reproduction. The amplifier has the same features as the first LA90, with mono (1x180W @ 4 ohm) or stereo (2x120W @ 4 ohm) operationadjustable gain and a combined balanced input connector for 6.35mm jack or XLR.
View complete product page of Topping LA90D Topping LA90D
TOPPING TCX1: XLR Interconnect Cables 25cm (Pair)
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable has a beautiful and robust black and red braided nylon sheath.
View complete product page of TOPPING TCX1 TOPPING TCX1
Product typeStreamer + Amplifier + XLR cables
Package content1x Bluesound Node Icon
1x Topping LA90D
1x Topping TCX1 25cm
Bluesound node Specifications
Headphone amplifier
ConnectivityWi-Fi 5 (802.11ac) dual-band
Ethernet RJ45, GigE 1000Mbps
Bluetooth 5.2 bidirectional aptX Adaptive
Audio inputs1x HDMI eARC
1x Optical Toslink
1x Stereo RCA
1x USB-A (External storage only; local server mode)
1x USB-C (PC input)
Audio outputs1x Stereo RCA
1x Stereo XLR
1x Subwoofer
1x Coaxial
1x Optical Toslink
2x USB-A
1x Jack 6.3mm headphone output
Trigger12V
Supported file formatsMP3, AAC, WMA, WMA-L, OGG, ALAC, OPUS,FLAC, MQA, WAV, AIFF, MPEG-4 SLS
CPUARM Cortex A53 Quad-Core 1.8GHz/core
Supported sampling ratesPCM : up to 24bit 192kHz
DSD : up to DSD256
Amplification chipTHX AAA
Output level160mW @ 16Ω
230mW @ 32Ω
53mW @ 250Ω
22mW @ 600Ω
DAC chips2x ESS ES9039Q2M
ADC chip1x ESS ES9826
OSBluOS
Compatible OSiOS
Android
Windows
macOS
Transmission protocolsAirPlay 2
Spotify Connect
Tidal Connect
Roon Ready
Acoustic adjustmentDirac Live Ready
Voice controlAmazon Alexa
Control systemsCrestron
Control4
RTI
ELAN
URC
Lutron
ScreenColor HD 5"
Power supply100-240V AC 50/60Hz
Dimensions220 x 193 x 84
Package1x Bluesound Nano Icon
1x 120V AC power cord
1x 230V AC power cord
1x Stereo RCA to RCA cable
1x Ethernet cable
Topping LA90D Specifications
Product typeDiscrete amplifier
Inputs3x Combined Jack 6.35mm TRS / XLR
OutputsSpeaker terminals
Measurements
ParameterStereoMono
THD+N @ 1kHz (A-wt)< 0.00009% @ 4Ω 5W< 0.0002% @ 4Ω 5W
< 0.00009% @ 8Ω 5W< 0.0001% @ 8Ω 5W
THD+N @ 20Hz-20kHz, 90kBw (A-wt)< 0.0005% @ 4Ω 5W< 0.0007% @ 4Ω 5W
< 0.0003% @ 8Ω 5W< 0.0005% @ 8Ω 5W
SNR @ A-Weighting141dB143dB
Dynamic range @ A-Weighting141dB143dB
Frequency response20Hz-40kHz (±0.2dB)20Hz-40kHz (±0.2dB)
10Hz-100kHz (±0.4dB)10Hz-100kHz (±0.4dB)
Output level51Vpp @ 4Ω80Vpp @ 4Ω
58Vpp @ 8Ω106Vpp @ 8Ω
Noise @ A-Weighting< 1.8µVrms @ G=L< 2.5µVrms @ G=L
< 3.4µVrms @ G=H< 4.8µVrms @ G=H
Channel crosstalk @ 1kHz-138dB-
Input sensitivity7.3Vrms @ G=L6.9Vrms @ G=L
2.2Vrms @ G=H2.2Vrms @ G=H
Gain9.44dB @ G=L15.4dB @ G=L
19.4dB @ G=H25.4dB @ G=H
Channel balance0.2dB-
Output impedance< 3mΩ< 5mΩ
Output power2x 120W @ 4Ω THD+N < 10%1x 180W @ 4Ω THD+N < 1%
2x10W @ 4Ω THD+N < 1%
2x 66W @ 8Ω THD+N < 10%1x 220W @ 8Ω THD+N < 10%
2x 56W @ 8Ω THD+N < 1%1x 180W @ 8Ω THD+N < 1%
Load impedance≥ 4Ω≥ 4Ω
Dimensions220*205*90mm
Package1x Topping LA90D
1x Power supply
1x Speaker jumper cable
Topping TCX1 Specifications
Product typeXLR Cables
Connectors1x Male XLR 3 poles
1x Female XLR 3 poles
Length25cm
Cable overall diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Covering sheathBraided Nylon
ColorBlack and red
QuantitySold by pair (1 cable with red rings, 1 cable with black rings)
We're offering a Bluesound x Topping product pack consisting of the Bluesound Node Icon network player, a Topping LA90D amplifier, and a pair...
