Pack Eversolo DMP-A6 Master Edition + Eversolo AMP-F2 + Audiophonics Wire XLR 30cm
We offer you an Eversolo product pack consisting of the DMP-A6 Master Edition network player, the AMP-F2 amplifier and a pair of XLR interconnect cables for balanced connection. This high-end package is perfect for anyone who wants to enjoy a high power reserve and a connected system for a wide range of streaming services. Coupled with passive speakers, this combination is capable of reproducing the best of your music.
By buying this product you get 189 loyalty points
Reference : 19483
1 899,00 €tax incl.
1 582,50 € tax excl.
Instead of 1 907,90 €
Pack content
Pack Eversolo DMP-A6 Master Edition Streamer + Eversolo AMP-F2 Amplifier + Audiophonics Wire XLR 30cm
We offer you an Eversolo product pack consisting of the DMP-A6 Master Edition streamer, the AMP-F2 amplifier and a pair of Audiophonics Wire XLR interconnect cables for balanced connection. This high-end package is perfect for anyone who wants to enjoy a high power reserve and a connected system for a wide range of streaming services. Coupled with passive speakers, this combination is capable of reproducing the best of your music.
Eversolo DMP-A6 Master Edition: Streamer 2xES9038Q2M WiFi DLNA AirPlay 2 Roon Bluetooth 5.0 aptX HD 32bit 768kHz DSD512 MQA
With its DMP-A6 Master Edition, Eversolo presents a network player as powerful as it is intuitive and stylish. It lets you stream your music with ease, while enjoying excellent sound quality, all controlled via a high-quality LCD screen and ergonomic interface, or from a dedicated mobile application. It features two ES9038Q2M DAC chips and an XMOS XU316 USB interface, enabling it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, plus an MQA decoder. It is also equipped with a preamplifier circuit and a fully balanced architecture.
View complete product page of EVERSOLO DMP-A6 MASTER EDITION EVERSOLO DMP-A6 MASTER EDITION
EverSolo AMP-F2: Class D Amplifier 2x250W 4Ω / 1x450W 2Ω
The EverSolo AMP-F2, developed in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. The result is a high power reserve of up to 2x250W RMS power at 4 Ohm (1% THD), great dynamics and extremely accurate sound. The all-new SAPS switch-mode power supply provides the audio circuit with a clean electrical signal, ensuring low noise and distortion. Bridgeable, the AMP-F2 is a versatile model that can be used in stereo or mono.
View complete product page of EverSolo AMP-F2 EverSolo AMP-F2
Audiophonics Wire: Stereo XLR Interconnect Cable Gold-plated OFC Copper 30cm (Pair)
These balanced XLR modulation cables, assembled in our workshop in France, comprise a Mogami Neglex W2549 cable and Neutrik NC3FXX-B and NC3MXX-B XLR connectors. They feature OFC copper conductors and integral shielding, while the connector contacts are 24K gold-plated for enhanced resistance to corrosion and oxidation.
View complete product page of AUDIOPHONICS WIRE XLR 30 cm AUDIOPHONICS WIRE XLR 30 cm
Technical  characteristics
Products typeStreamer + Power amplifier + Modulation cables
Package contents1x Eversolo DMP-A6 Master Edition
1x EverSolo AMP-F2
1x Audiophonics Wire XLR 30cm (pair)
Eversolo DMP-A6 MAster Edition Specifications
Product typeStreamer
Touch screenLCD 6"
CPUARM Cortex-A55 (Quad-core)
Internal memory4Go DDR + 32Go eMMC
Support SSD M.2 NVME 3.0 until 4 Tb (not included)
DAC Chip2x ES9038 Q2M
Audio decodingPCM : 32bit 768kHz
DSD : DSD512
MQA
USB InterfaceXU316 (3rd generation)
HDMI decoding chip2x DOH chips
Bluetooth ChipsQualcomm QCC5125 Bluetooth 5.0
AOP ChipsOPA1612
Connectivity
WiFiDual-band 2.4G+5G
EthernetRJ45 (10/100/1000Mbps)
Input USB portUSB-C  3.0
Systeme compatibility : Windows (7, 10), Mac, Android, IOS
Audio compatibility :Stereo DSD512, PCM 768KHz 32Bit, MQA
Output audio HDMIMulti-channel : DSD64 Native
Raw Multi-channel : PCM 192KHz
Input Bluetooth 5.0QCC5125 Chip
Supported Codecs : SBC, AAC, aptX, aptX LL, aptX HD, LDAC
Digital audio inputsBluetooth
1x USB-C
1x Coaxial
1x Optical Toslink
Digital audio outputsBluetooth
1x Coaxial
1x Optical Toslink
1x HDMI
2x USB-A
Analog audio outputs1* unbalanced stereo RCA
1* balanced stereo XLR
Integrated music servicesTidal, Qobuz, Highresaudio, Amazon, WebDAV, UPnP, Presto music
Compatible streaming servicesAir Play, DLNA, Roon Ready, Spotify, Tidal Connect, Qobuz Connect etc.
Supported network protocolNFS / SMB v1-v2-V3 / UPnP
Mesurements
Balanced XLR outputOutput level: 5.2V
Frequency Response: 20Hz~20KHz(±0.15dB)
Dynamic range: > 128dB
SNR: >128dB
THD+N: <0.00009%(-120dB) @A-wt
Crosstalk: >-125dB
Unbalanced RCA outputOutput level: 2.6V
Frequency response: 20Hz~20KHz (±0.2dB)
Dynamic range: > 124dB
SNR: >124dB
THD+N: <0.00011%(-119dB)@A-WT
Crosstalk: >-124dB
Power supply110-240V AC 50/60Hz
Rated Power13W
Dimensions (L*P*H)180*270*90mm
Package1* EVERSOLO DMP-A6 Master Edition
1* Power cable
1* USB cable
1* Screwdriver
1* User manual
AMP-F2 Specifications
Product typeAmplifier
Amplification typeClass D
Output power2x250W RMS @ 4Ω (1% THD)
2x145W @ 8Ω (1% THD)
Output power (BTL)280W RMS @ 4Ω (1% THD)
450W RMS @ 2Ω (1% THD)
InputsSingle-ended RCA
Balanced XLR
OutputsSpeaker terminals (beryllium copper)
Gain21.5dB
Frequency response10Hz - 20kHz (-1dB)
Max. output current per channel16.5A
33A (BTL)
THD0.003% @ 10W, 1kHz
SNR> 110dBA @ 4Ω, 260W
Input impedanceRCA : 11kΩ
XLR : 22kΩ
Input sensitivity2.7V
Output impedance0.136Ω (5Hz à 100kHz)
Minimum load impedance0.8Ω
Damping factor100
Balanced circuit
Trigger 5-12VInput and output
Supply voltage115VAC - 230VAC (switchable)
Heat65BTU / hour
ConsumptionStandby: ≤ 0.5W
Idle: ≤ 14W
Max: 900W
Dimensions270 x 228 x 80mm
Housing materialAluminum
Weight3.65kg
Audiophonics Wire XLR Specifications
Product typeStereo XLR cables (pair)
Connectors2* Male XLR
2* Female XLR
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Neutrik connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialPolyamide
Pack Eversolo DMP-A6 Master Edition Streamer + Eversolo AMP-F2 Amplifier + Audiophonics Wire XLR Cables 30cm
We offer you an Eversolo product pack consisting of the DMP-A6 Master Edition network player, the AMP-F2 amplifier and a pair of XLR interconnect...
