Pack Eversolo DMP-A8 Streamer + AMP-F2 Amplifier + Audiophonics Wire XLR Cables 30cm
We offer you a pack of Eversolo products consisting of the famous DMP-A8 streamer, the AMP-F2 amplifier and a pair of Audiophonics Wire XLR modulation cables. This top-of-the-range pack promises powerful sound reproduction with great purity and precision.
By buying this product you get 259 loyalty points
Reference : 19401
2 599,00 €tax incl.
2 165,83 € tax excl.
Instead of 2 718,90 €
Pack content
Pack Eversolo Streamer DMP-A8 + Amplificateur AMP-F2 + Audiophonics Wire XLR 30cm
We offer you a pack of Eversolo products consisting of the famous DMP-A8 streamer, the AMP-F2 amplifier and a pair of Audiophonics Wire XLR modulation cables (30cm). This top-of-the-range pack promises powerful sound reproduction with great purity and precision.
EverSolo DMP-A8 : Streamer AK4191EQ AK4499EX XMOS XU316 WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512
The Eversolo DMP-A8 network player is an all-in-one device featuring a DAC and preamplification circuitry. In addition to its streamer function, the AK4499EX + AK4191EQ chip combo and a USB XMOS XU316 interface enable it to support high-resolution sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Added to this is a fully balanced analog preamplifier circuit with R2R volume controller. As well as offering access to a wide range of streaming services, this device offers exceptional performance in all areas. A true centerpiece of today's HiFi system, it offers a wide range of possible uses.
View complete product page of DMP-A8 Eversolo DMP-A8 streamer
EverSolo AMP-F2 Class D Amplifier 2x250W 4Ω / 1x450W 2Ω
The Eversolo AMP-F2 is a Class D amplifier, developed in collaboration with the Stark Sound team. The integration of an NS600 module gives it a nice power reserve with up to 2x250W at 4 ohm and 1x450W at 2 ohm in bridge mode. Not to mention the 600W SAPS switching power supply, which provides the audio circuit with a clean electrical signal for very low noise and distortion. In terms of connectors, it has all the essentials, with an RCA and XLR input and speaker terminals for output.
View complete product page of EverSolo AMP-F2 Eversolo Amp-F2 amplifier
AUDIOPHONICS WIRE XLR Interconnect Cable Stereo RCA OFC Copper Gold Plated 30cm (Pair)
Audiophonics Wire XLR modulation cables are hand-assembled in our workshops in France. They consist of Mogami Neglex W2549 interconnect cable and Neutrik NC3MXX-B and NC3FXX-B male and female XLR connectors. OFC copper conductors offer enhanced conductivity, while shielding protects the signal from EMI/RFI interference. Furthermore, Neutrik connectors feature 24k gold-plated contacts for enhanced resistance to corrosion and oxidation.
View complete product page of AUDIOPHONICS WIRE XLR Audiophonics Wire XLR cables
Product typeNetwork player + Amplifier + XLR modulation cables
Package contents1x Eversolo DMP-A8
1x Eversolo AMP-F2
1x Câbles de modulation XLR audiophonics wire
DMP-A8 SPECIFICATIONS
Product typeStreamer
Touchscreen6" LCD Full HD
RAM4Go DDR4
ROM64Go eMMC
DACAK4191EQ + AK4499EX
USB interfaceXMOS XU316
OPAOPA1612
Power supplyDual low-noise linear + digital power supplies
Support SSDM.0 NVME 3.0 2280 protocol up to 4Go (SSD sold separately)
Inputs1x Ethernet RJ45 (10/100/1000Mbps)
1x Balanced XLR
1x Single-ended RCA
1x HDMI ARC
2x Coaxial
1x USB-B
2x Optical
Outputs1x Balanced XLR
1x Single-ended RCA
2x USB-A 3.0
1x HDMI I2S
1x Coaxial
1x Optical
Wireless connectivityWiFi 2.4G+5G dual band
Bluetooth 5.0
Supported sampling ratesUSB / I2S: PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP64
HDMI ARC : PCM up to 24bit 192kHz
Supported streaming servicesTidal
Qobuz
Amazon Music
Deezer
Apple Music
Highresaudio
Paradise Radio
Supported network protocolsWebDAV
UPnP
AirPlay
DLNA
Tidal Connect
Roon Ready
Supported Bluetooth codecsSBC
AAC
aptX
aptX HD
aptX LL
LDAC
Compatible OS (USB)Windows 10 / 11
Android
iOS
RCA output
Output level2.1Vrms
Frequency response20Hz - 20kHz (±0.25dB)
THD+N< 0.000010% (-119dB) @ A-wt
Crosstalk> -121dB
Dynamic range> 125dB
SNR> 125dB
XLR output
Output level4.2Vrms
THD+N< 0.00009% (-120dB) @ No-wt
Crosstalk> -121dB
Dynamic range> 128dB
SNR> 128dB
Supply voltage110-240VAC 50/60Hz
Rated power16W
Dimensions388*248*90mm
Package1x EverSolo DMP-A8
1x Power cable
1x Remote control
1x Screwdriver
AMP-F2 SPECIFICATIONS
Product typeAmplifier
Amplification typeClass D
Output power2x250W RMS @ 4Ω (1% THD)
2x145W @ 8Ω (1% THD)
Output power (BTL)280W RMS @ 4Ω (1% THD)
450W RMS @ 2Ω (1% THD)
InputsSingle-ended RCA
Balanced XLR
OutputsSpeaker terminals (beryllium copper)
Gain21.5dB
Frequency response10Hz - 20kHz (-1dB)
Max. output current per channel16.5A
33A (BTL)
THD0.003% @ 10W, 1kHz
SNR> 110dBA @ 4Ω, 260W
Input impedanceRCA : 11kΩ
XLR : 22kΩ
Input sensitivity2.7V
Output impedance0.136Ω (5Hz à 100kHz)
Minimum load impedance0.8Ω
Damping factor100
Balanced circuit
Trigger 5-12VInput and output
Supply voltage115VAC - 230VAC (switchable)
Heat65BTU / hour
ConsumptionStandby: ≤ 0.5W
Idle: ≤ 14W
Max: 900W
Dimensions270 x 228 x 80mm
Housing materialAluminum
Weight3.65kg
Audiophonics Wire XLR SPECIFICATIONS
Product typeStereo XLR cable
Connectors2* Male XLR
2* Female XLR
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Neutrik connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialPolyamide
Pack Eversolo DMP-A8 Streamer + AMP-F2 Amplifier + Audiophonics Wire XLR 30cm
We offer you a pack of Eversolo products consisting of the famous DMP-A8 streamer, the AMP-F2 amplifier and a pair of Audiophonics Wire XLR...
