Pack FERRUM HYPSOS V2 HiFi Power Supply + DAC ES9038PRO WANDLA + FPL Cable
The Ferrum Hypsos V2 power supply and the Ferrum Wandla DAC were mainly designed to work together. They form a perfect duo in order to benefit from a high quality digital/analogue conversion, thanks to an optimized electrical signal. This pack is therefore ideal for taking advantage of a system offering excellent sound reproduction. In addition, the Ferrum FPL cable ensures a perfect link between the two devices thanks to its proprietary Ferrum Power Link technology.
By buying this product you get 399 loyalty points
Reference : 17660
3 990,00 €tax incl.
3 325,00 € tax excl.
Instead of 4 293,00 €
Pack content
Pack Ferrum
HYPSOS V2 HiFi Power Supply + WANDLA ES9038PRO DAC + FPL Cable
FERRUM Pack HYPSOS V2 HiFi Power Supply + DAC ES9038PRO WANDLA + FPL Cable
Ferrum WANDLA
Ferrum offers with its WANDLA a versatile and extremely efficient DAC, capable of very high quality digital/analog conversion for the most precise and faithful sound reproduction.
  • A fully balanced signal : The balanced design ensures clean sound on the stereo RCA output and a truly balanced output on stereo XRL.
  • Ferrum Power Link (FPL) : While the OOR offers excellent basic performance, it can also be combined with the Ferrum Hypsos power supply (sold separately) using Ferrum Power Link (FPL) technology for optimal performance and musicality.
  • ESS ES9038Pro chip : Recognized for its incredible performance and its ability to provide particularly precise and transparent sound reproduction.
  • Optimized digital inputs : The Wandla has many inputs; Specially programmed USB, coaxial and optical S/PDIF ports, ARC (TV) and I2S optimized for audio.
  • MQA Decoder : The Wandla includes an MQA decoder to play these files in order to offer the best possible audio quality.
more about Ferrum Wandla
Ferrum HYPSOS V2
The Ferrum Hypsos V2 is a high-end power supply, offering exceptional technology and performance to give your HiFi system an extremely clean power supply for optimal sound reproduction. It has features that are unheard of in this price range. The device is software controlled, with as few hardware dependent elements as possible.
  • Hybrid power supply : The Hypsos V2 is a hybrid power supply model, taking advantage of both the benefits of a linear power supply and those of a switched-mode power supply. It provides low noise and ripple, as well as excellent transient response and high efficiency.
  • Sweet Spot Tuning (SST) : The Hypsos V2 power supply allows you to fine-tune its output voltage to achieve the best possible sound. The voltage level can be safely changed on the fly for easy comparison testing.
  • Advanced automation : Compatible with the Apple TV Remote and having an input/output trigger connector, it is possible to automate the switching on of devices in standby mode, even without a dedicated trigger connection
  • Detailed sound : The Hypsos V2 allows your audio system to perform at its best. Improve sound reproduction by adjusting the voltage level on the fly and using the best combination of 4T Sensing and Spectrum Diffusion Mode parameters.
  • User profiles : Use the predefined settings from the list of supported devices or create your user profile manually. The Hypsos power supply offers a wide range of DC output voltage, from 5V to 30V, with a current of up to 6A.
  • 4T Sensing Design (4TSD) : Ensure the correct voltage level at the DC input terminal of the powered device. A specially designed cable and a feedback function ensure a linear voltage at all times. This eliminates the adverse effects of cable resistance and significantly improves transient response.
  • Fully secured : The Hypsos V2 power supply integrates an automatic transformer voltage adjustment (ATVA), an electronic polarity switch for the output voltage as well as protection against overvoltage, overcurrents and short circuits. Parameters can be locked to prevent accidental changes.
More about Ferrum HypsoS V2
Ferrum FPL
The Ferrum FPL cable connects the Hypsos power supply to the OOR preamplifier/headphone amplifier to take advantage of Ferrum's proprietary Power Link (FPL) technology. This technology allows for a perfectly stable and clean transmission of the power supply to promote a very pure sound.
Technical Charateristics
FERRUM WANDLA Specifications
Product typeDAC
Digital inputs1* USB-C
1* Optical Toslink
1* Coaxial
1* AES/EBU
1* HDMI ARC (TV with CEC)
1* I2S
Analog inputsRCA 47kΩ (Vmax : 9,5V RMS / 2 – 3,5V RMS recommended)
Ouputs1x RCA stereo unbalanced
1x XLR stéréo balanced
DAC ChipESS ES9038Pro
Supported sample ratesUSB: PCM 32bit 768kHz, DSD512, DSD DoP up to DSD256, MQA
I2S: PCM 32bit 768kHz, DSD512, DSD DoP up to DSD512, MQA (PS AUDIO compatible)
HDMI ARC: PCM 192kHz/24bit), MQA, TV with CEC
AES/EBU: PCM 24bit 196kHz, DSD DoP until DSD64, MQA
Coaxial, Optical : PCM 24bit 192kHz, DSD DoP up to DSD64, MQA
Frequency response10Hz – 200kHz +/- 0,1dB
Output levelRCA: 4,65V RMS unbalanced @0dBFS
XLR: 9,3V RMS balanced @0dBFS
CAD THD :-121dB (0,00009%); THD+N : -115dB (unweighted)
THD analog input-123dB @ Output level 2V RMS
Dyn.Analog: 127dB (A-weighted)
Digital: 127dB (A-weighted)
Crosstalk-120dB for 1kHz, better than -100dB for 20Hz
-20KHz
Output impedenceUnbalanced: 22Ω
Balanced: 44Ω
Volume controlAnalog with bypass option / Digital with DAC operation only
Power consumptionStandby : 10W
Max : 15W
Power imputsJack DC 5.5/2.5mm connector, centre positive
Proprietary FPL (FPL) 4-pin DC connector
22-30VDC
Power adaptator100-240VAC to 24VDC
Dimensions271*206*50mm
Weight1.8Kg
Package1x Ferrum WANDLA DAC
1x Power cable
1x Remote control
Ferrum Hypsos V2 Specifications
Product typeHiFi power supply
Input supply voltage110-240VAC / 50-60Hz
Input connectorIEC C14
With fuse, power button and two-stage EMI filter
Output cablesJack DC 5.5/2.5mm / Jack DC 5.5/2.1mm
Output voltage range5-30V adjustable
Max continuous output current6A
Max continuous output power 60W
Primary winding fuseIEC 5x20mm fuse, 250V 3.15A
Dimensions217 x 206 x 50mm
Weight3.05kg
Housing materialAluminum
Ferrum FPL Specifications
Product typePower cable
Number of conductors4
Contacts platingGold
Length50cm
The Ferrum Hypsos V2 power supply and the Ferrum Wandla DAC were mainly designed to work together. They form a perfect duo in order to benefit from...
