Pack FiiO DAP M15s + Hifiman Ananda Nano Headphones
We offer you a pack of FiiO and HiFiman products consisting of the DAP M15s and HiFiman Ananda Nano headphones. These top-of-the-range products will let you enjoy uncompromising sound reproduction quality.
By buying this product you get 147 loyalty points
Reference : 19464
1 479,00 €tax incl.
1 232,50 € tax excl.
Pack content
Pack FiiO x HiFiman FiiO DAP M15s + Hifiman Ananda Nano Headphones
Pack FiiO DAP M15s + Hifiman Ananda Nano headphones
We offer you a pack of FiiO and HiFiMAN products consisting of the DAP M15s and HiFiman Ananda Nano headphones. These top-of-the-range products will let you enjoy uncompromising sound reproduction quality.
FIIO M15S Digital HiFi Player DAP ES9038Pro Snapdragon 660 Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA
With the M15S, FiiO unveils a high-end audiophile digital music player. An improvement on the M15, it features a new Qualcomm Snapdragon 660 processor, more powerful amplification and an ES9038Pro 8-channel DAC. Versatile, it can play files on micro SD, on a network or via music streaming services such as Spotify, Amazon Music, Deezer, Apple Music, Qobuz or Tidal, for example. Its capabilities enable it to decode up to PCM 32bit 768kHz, DSD512 and MQA. Its Bluetooth 5.0 QCC5124 chip also enables it to transmit and receive SBC, AAC, aptX, aptX HD, aptX Adaptive and LDAC formats. With its capabilities, 10h30 battery life and 3 outputs (balanced and unbalanced), the FiiO M15S is an extremely versatile, high-performance DAP.
View complete product page of FIIO M15S FIIO M15S
HiFiMAN Ananda Nano Planar Magnetic Open-Back Headphones 14Ω 94dB 5Hz-55kHz
With a sensitivity of 94dB and an impedance of 14Ω, the Ananda Nano headset has been designed to be easy to drive, so that it can easily accompany you in your daily life. The Ananda Nano is equally at home in a sedentary environment or in a nomadic configuration in conjunction with a DAP. These open, circumaural, magnetic planar headphones feature an ultra-fine membrane and a magnet network optimized for very low distortion.
View complete product page of HiFiman Ananda Nano HiFiman Ananda Nano
Products typeDAP + Headphones
Package contents1x FiiO M15s
1x HiFiman Ananda Nano
FiiO M15s SPECIFICATIONS
Product typeDigital Audio Player (DAP)
Dac chipES9038Pro
SoCQualcomm Snapdragon 660 + Android 10
RAM4GB
Storage64GB
OPAOPA926
Inputs1* USB-C 3.0 (Charge + OTG, USB DAC, USB Audio)
1* Micro SD slot
Bluetooth 5.0
WiFi (DLNA, AirPlay)
Outputs1* Single-ended Jack 3.5mm
1* Balanced Jack 2.5mm
1* Balanced Jack 4.4mm
1* Coaxial (shared with Jack 3.5mm headphone output)
Touchscreen5.5" HD 1440*720px
Volume control
Gain settingsLow / Medium / High
Over-ear: Super High / Ultra High
Equalizer (EQ)Adjustable 10-band dynamic equalizer (±12dB)
8 built-in preset equalizers
Custom EQ support
Recommended headphone impedance8-150Ω (single-ended output)
8-350Ω (balanced outputs)
Supported sample ratesNative: PCM up to 32bit 384kHz, DSD up to DSD256
USB DAC: PCM up to 32bit 384kHz, DSD up to DSD256
USB Audio: PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial: PCM up to 32bit 384kHz, DSD up to DSD128 (DoP)
Supported audio formats
MP3, OGG, WMA, AAC, DSD, DXD, APE Fast/High/Normal, APE Extra High, APE Insane, Apple Lossless, AIFF, FLAC, WAV, WMA Lossless, DTS, MQA
WiFiWiFi 2.4GHz/5GHz
DLNA
AirPlay
Roon Ready
Supported Bluetooth codecsReception: SBC, AAC, aptX, aptX HD, aptX LL, LDAC and aptX Adaptive
Transmission: SBC, AAC, aptX, aptX HD, LDAC and LHDC
Single-ended Jack 3.5MM OUTPUT measurements
Output power2* 535mW (16Ω / THD+N<1% / Ultra high gain)
2* 580mW (32Ω / THD+N<1% / Ultra high gain)
2* 93mW (300Ω / THD+N<1% / Ultra high gain)
2* 475mW (16Ω / THD+N<1% / Super high gain)
2* 395mW (16Ω / THD+N<1% / Super high gain)
2* 57mW (16Ω / THD+N<1% / Super high gain)
Crosstalk≥ 80dB (1kHz/32Ω)
Frequency response20Hz-20kHz (-0.15dB)
20Hz-50kHz (-1.0dB)
Output impedance≤ 1.4Ω (32Ω)
THD+N≤ 0.0005% (1kHz/32Ω)
SNR≥ 122.5dB (A-weighted)
Noise≤ 3.2μV (A-weighted)
Balanced Jack 2.5mm / 4.4mm outputs measurements
Ouput power2* 531mW (16Ω / THD+N<1% / Ultra high gain)
2* 1200mW (32Ω / THD+N<1% / Ultra high gain)
2* 368mW (300Ω / THD+N<1% / Ultra high gain)
2* 531mW (16Ω / THD+N<1% / Super high gain)
2* 990mW (16Ω / THD+N<1% / Super high gain)
2* 226mW (16Ω / THD+N<1% / Super high gain)
Channel separation≥ 105dB (1kHz/32Ω / Ultra high gain)
≥ 105.6dB (1kHz/32Ω / Super high gain)
20Hz-50kHz (-1.0dB)
Output impedance≤ 2.3Ω (32Ω)
THD+N≤ 0.00075% (1kHz/32Ω)
SNR≥ 121.5dB (A-weighted / Ultra high gain)
≥ 120.5dB (A-weighted / Super high gain)
Noise≤ 5.2μV (A-weighted)
Battery
Power supplyVia USB-C (QC3.0, QC4.0 / PD2.0, PD3.0 quick charge support)
Battery capacity6200mAh
Charging time3.5h
Battery life9h-10h30
Dimensions140*80*18.9mm
Weight345g
ColorNoir
Package1* FiiO M15S
1* Leather protective cover
1* Stand with heat dissipation system
1* USB 3.0 OTG power cable
1* Power cable for stand
1* USB adapter
HiFiman Ananda Nano SPECIFICATION
Product typeHeadphone
Headphone typeOpen back
Headphone formatCircumaurale
Headphone technologyPlanar Magnetic
Headphone connecticJack 3.5mm
Frequency response5Hz - 55kHz
Impedance14Ω
Sensitivity94dB
Weight420g
ColorSilver
Package1x HiFiMAN Ananda Nano
1x Headphone cable Jack 3.5mm stereo to 2x Jack 3.5mm stereo 3m
1x 6.35mm Jack to 3.5mm Jack Adapter
1x Travel bag
Pack FiiO M15s DAP + HifiMAN Ananda Nano Headphones
We offer you a pack of FiiO and HiFiman products consisting of the DAP M15s and HiFiman Ananda Nano headphones. These top-of-the-range products...
