Pack FiiO M11 Plus II DAP + Monolith M1060 Headphones
We offer you a pack of FiiO and Monolith products consisting of the Shanling M11 Plus II DAP and the Monolith M1060 headphones. These top-of-the-range products will let you enjoy uncompromising sound reproduction quality.
By buying this product you get 101 loyalty points
Reference : 19458
1 019,00 €tax incl.
849,17 € tax excl.
Instead of 1 039,00 €
Pack content
Pack FiiO x Monolith FiiO DAP M11 Plus II + Monolith M1060 Headphones
Pack FiiO DAP M11 Plus II + Monolith M1060 headphones
We offer you a pack of FiiO and Monolith products consisting of the FiiO M11 Plus II DAP and the Monolith M1060 headphones. These top-of-the-range products will let you enjoy uncompromising sound reproduction quality.
FIIO M11 PLUS II Digital Portable Audio Player DAP 2x ES9068AS 2x THX AAA-78 Balanced Bluetooth WiFi AirPlay2 MQA 32bit 768kHz DSD512
FiiO's M11 Plus II is a top-of-the-range portable music player designed to deliver the best sound quality wherever you are. It features a dual ES9068AS DAC and dual THX-AAA-79 headphone amplifier for exceptional performance. Indeed, it supports 32bit 768kHz, DSD512 and MQA sampling rates, all with an output power of up to 660mW sous 32Ω, THD+N < 1%. Naturally, this DAP takes advantage of bidirectional Bluetooth 5.0 and WiFi. The entire package is powered by an octacore Snapdragon 660 processor and Android 10 interface. A 6000mAh battery gives it up to 11.5h of autonomy in continuous use.
View complete product page of FIIO M11 PLUS II FIIO M11 PLUS II
MONOLITH M1060 Over Ear Open Back Planar Magnetic Headphone 96dB 50 Ohm 10Hz - 50kHz
Monolith M1060 headphones are the ideal listening solution for getting the most out of your music. Featuring large 106mm Planar Magnetic drivers, the M1060 delivers precise, rich reproduction, allowing you to capture every detail of your music. With a spectacular sound image, low distortion and perfectly balanced sound, the Monolith M1060 is a true audiophile headphone.
View complete product page of MONOLITH M1060 MONOLITH M1060
Product typeDAP + Headphones
Package contents1x FIIO M11 PLUS II
1x MONOLITH M1060
FIIO M11 PLUS II Specifications
Product typeDigital Audio PLayer (DAP)
DAC Chip2x ESS ES9068AS
Amplification chip2x THX AAA-78
LPF3x OPA1642
TouchscreenIPS 5.5" 1440x720px
Connectivity / ConnectorsTwo-way USB-C
Two-way Bluetooth
AirPlay2
FiiO Link
WiFi 2.4GHz/5GHz
UpNP
Outputs1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 2.5mm headphone output
1x Balanced Jack 4.4mm headphone output
Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
RAM4GB
StorageROM : 64GB
Expandable via Micro SD (not included)
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
DXD up to 24bit 352.8kHz
MQA
Recommended headphone impedanceSingle-ended output : 16-150Ω
Balanced output : 16-300Ω
EQ10 bands, ±12dB
8 presets
Battery6000mAh
Quick Charge QC4.0 / PD2.0
Single-ended headphone output @ High gain
Output power≥ 300mW @ 16Ω, THD+N < 1%
≥ 210mW @ 32Ω, THD+N < 1%
≥ 33mW @ 300Ω, THD+N < 1%
Output impedance≤ 1Ω
THD+N 0.00054% @ 1kHz, 32Ω
Crosstalk≥ 76dB @ 1kHz, 32Ω
Noise floor≤ 2.5µV (dBA)
SNR≥ 122dB (dBA)
Frequency response20Hz ~ 20kHz (-1dB)
Single-ended line output
THD+N 0.0006% @ 1kHz, 10kΩ
SNR 118dB (dBA)
Frequency response20Hz ~ 50kHz (-0.5dB)
Noise floor 2.5µV (dBA)
Crosstalk 105dB @ 1kHz, 10kΩ
Line out level2V @ 1kHz, 10kΩ
Balanced headphone output @ High gain
Output power≥ 400mW @ 16Ω, THD+N < 1%
≥ 660mW @ 32Ω, THD+N < 1%
≥ 90mW @ 300Ω, THD+N < 1%
Output impedance≤ 2Ω
THD+N 0.00085% @ 1kHz, 32Ω
Crosstalk≥ 111dB @ 1kHz, 32Ω
SNR≥ 126dB (dBA)
Frequency response20Hz ~ 80kHz (-1dB)
Balanced line output
THD+N 0.0004% @ 1kHz, 10kΩ
SNR 125dB (dBA)
Frequency response20Hz - 50kHz (-0.5dB)
Noise floor 2µV (dBA)
Crosstalk 104dB @ 1kHz, 10kΩ
Line out3V @ 1kHz, 10k
Dimensions136.6 x 75.7 x 17.6mm
Weight310g
Monolith M1060 Specifications
Product typeHeadphone
Headphone typeOpen Back
Over-Ear
Drivers typePlanar Magnetic
Drivers diameterØ106mm
Magnets structureLinear symmetry
Magnets materialNeodymium
Max power handling10W (for 200ms)
Max SPL> 130dB
Frequency response10Hz - 50kHz
THD< 1% @ 1mW, 1kHz
Impedance50Ω
Efficiency96dB/1mW
Optimal power200mW - 4W
Cable length1.90m
Weight500g
Package1x Monolith M1060
1x Braided Jack 3.5mm cable
1x Jack 3.5mm to Jack 6.35mm adapter
1x Transport bag
We offer you a pack of FiiO and Monolith products consisting of the Shanling M11 Plus II DAP and the Monolith M1060 headphones. These...
