Pack Fosi Audio DA2120A + Eltax Monitor III + Eltax SW800 + Speaker cables + RCA LFE Cable
We're offering you a product pack that gives you a ready-to-use 2.1-channel Hi-Fi / Home Cinema system at an affordable price. The pack includes a Fosi Audio DA21220A amplifier, a pair of Eltax Monitor 3 speakers, an Eltax SW800 subwoofer and all the modulation cables needed to connect them. These include a pair of Dynavox banana plug interconnect cables and an RCA LFE subwoofer interconnect cable.
By buying this product you get 41 loyalty points
Reference : 19384
419,00 €tax incl.
349,17 € tax excl.
Instead of 506,81 €
Pack content
Pack Fosi Audio x Eltax Fosi Audio DA2120A Amplifier + Eltax Monitor III Speakers + Eltax SW800 Subwoofer + Speaker Cables + RCA LFE Cable
Pack Fosi Audio DA2120A + Eltax Monitor III + Eltax SW800 + Speaker cables + RCA LFE cable
We're offering you a product pack that gives you a ready-to-use 2.1-channel Hi-Fi / home cinema system at an affordable price. The pack includes a Fosi Audio DA21220A amplifier, a pair of Eltax Monitor 3 speakers, an Eltax SW800 subwoofer and all the modulation cables needed to connect them. These include a pair of Dynavox banana plug interconnect cables and an RCA LFE subwoofer interconnect cable.
Fosi Audio DA2120A : Class D amplifier Bluetooth 5.0 aptX 2x50W 4 Ohm
The Fosi Audio DA2120A integrated amplifier is a Class D amplifier based on TI NE5532 AOPs. It is capable of delivering 2x 50W at 4 ohms. A subwoofer output is available, enabling it to be coupled with an active subwoofer for a 2.1-channel system. Full connectivity with USB-B, Toslink optical, SPDIF coaxial and 3.5mm jack inputs lets you enjoy a wide range of audio sources. In addition, a QCC3031 Bluetooth receiver enables you to enjoy high-quality wireless transmission thanks to aptX and aptX HD codecs. The CM6642 USB interface supports sampling rates up to PCM 24bit 192kHz. Versatile and high-performance, this little amplifier offers a wide range of possibilities.
View complete product page of FOSI AUDIO DA2120A Fosi Audio DA2120A amplifier
Eltax Monitor III : 2-Way Bookshelf Speakers 90W 89db 50Hz-22kHz Black (Pair)
Eltax Monitor III bookshelf speakers are powered by two drivers, a bass-reflex-loaded midrange and a soft-dome tweeter. These speakers deliver deep bass while remaining compact. The upper-midrange remains detailed, with a rich, dynamic overall sound reproduction. The Eltax Monitor III has a power handling capacity of 90W, a sensitivity of 89dB and an extended frequency response from 50Hz to 22kHz.
View complete product page of Eltax Monitor III Eltax Monitor III speakers
Eltax SW800 : Active Subwoofer 60W 40-150Hz Ø20cm
The Eltax SW800 active subwoofer features a driver of no less than 20cm in diameter for 60W output power and a frequency response of 40Hz to 150Hz. This model is ideal for integration into a small or medium-sized HiFi or home theater installation.
View complete product page of Eltax SW800 Eltax SW800 subwoofer
DYNAVOX Banana speaker cables OFC copper 2m (Pair)
Dynavox banana speaker cables feature OFC copper conductors for enhanced conductivity.
View complete product page of Dynavox speaker cables Speaker cables
Pangea Premier Interconnect Cable RCA Subwoofer LFE 2m (Unit)
The RCA LFE interconnect cable is a high-quality subwoofer cable. It incorporates a conductor made of 100% Cardas Grade One copper strands (hot spot) and a conductor made of OFC copper (cold bridge). Triple shielding and efficient insulation complete the structure. Both sides of the cable feature Pangea Prime 400 RCA plugs with gold-plated contacts.
View complete product page of Pangea Premier speaker cables RCA LFE cable
Products typeIntegrated amplifier + Speakers + Subwoofer + Speaker cables + RCA LFE cable
Package contents1x Fosi Audio DA2120A
1x Eltax Monitor III
1x Eltax SW800
1x Dynavox speaker cables
1x Pangea Premier RCA LFE cable
FOSI AUDIO DA2120A AMPLIFIER SPECIFICATIONS
Product typeAmplifier
Amplification typeClass D
InputsBluetooth 5.0
1* Jack 3.5mm
1* USB-B
1* Optical Toslink
1* Coaxial
OutputsSpeaker terminals
1* Subwoofer output (RCA)
Bluetooth reception chipQCC3031
USB InterfaceCM6642
OPANE5532
Output power2*50W @ 4Ω
Supported sampling ratesPCM up to 24bit 192kHz
USB CompatibilityWindows XP / 7 / 8 /10
Mac
Linux
Supported Bluetooth codecsAAC, SBC, aptX
THD≤ 0.01%
SNR≥ 105dB
Input sensitivity≤ 280mV
Tone controlBass / Treble via remote control
Dimensions (L*P*H)134*130*34mm
Package1* Fosi Audio DA2120A
1* Power supply
1* Remote control
1* USB cable
1* Optical cable
ELTAX MONITOR III SPEAKER SPECIFICATIONS
Product typeSpeakers
System type2 Ways Bass-Reflex
Power90W
WooferØ130mm, isolated
TweeterØ25mm, soft dome
Frequency response (±4dB)50Hz - 22kHz
Sensitivity89dB
Impedance4-8Ω
Dimensions (LxPxH)195 x 300 x 230mm
Weight5kg (The pair)
ELTAX SW800 SUBWOOFER SPECIFICATIONS
Product typeActive subwoofer
Load typeBass Reflex
Driver diameterØ20cm
Frequency response40-150Hz
Adjustable cut-off frequencyFrom 40Hz to 150Hz
Power60W
Connectivity1x Stereo RCA line input
1x LFE input
Vent positionLateral
Dimensions (WxHxD)290 x 330 x 350mm
Cabinet materialMDF
Weight6.7kg
DYNAVOX SPEAKER CABLES SPECIFICATIONS
Product typeSpeaker cables
Length2x 2m
ConductorsOFC Copper (purity = 99.99%)
Section4x 2.5mm²
Conductor composition50 strands of 0.25mm diameter
Total diameterØ12mm
Covering sheathNylon
ColorRed and Black
Weight / Cable420g
QuantitySold in pair (2 cables of 2m)
PANGEA PREMIER RCA LFE CABLE SPECIFICATIONS
Conductor typePure Copper Cardas Grade One ( on hot point pin ) OFC ( cold point )
IsulationPE AIR TUBE
EMI / RFI shieldTriple insulation with aluminium mylar silver-plated foil
Jacket typeHigh-strength thermoplastic case
RCA conductorHigh quamity profil contact Gold plated
Soldering typeHand made assembled
Pack Fosi Audio DA2120A Amplifier + Eltax Monitor III Speakers + Eltax SW800 Subwoofer + Speaker Cables + RCA LFE Cable
We're offering you a product pack that gives you a ready-to-use 2.1-channel Hi-Fi / Home Cinema system at an affordable price. The pack...
