Pack Fosi Audio SK02 Headphone Amplifier + Audio Meze 99 Neo Headphones
We propose a product pack consisting of a Fosi Audio SK02 headphone preamplifier and Audio Meze 99 Neo headphones. This combo lets you enjoy quality headphone listening at an affordable price.
By buying this product you get 22 loyalty points
Reference : 19381
229,00 €tax incl.
190,83 € tax excl.
Instead of 298,00 €
Pack content
Pack Fosi Audio x Meze Pack Fosi Audio SK02 headphone amplifier + Audio Meze 99 Neo headphones
We propose a product pack consisting of a Fosi Audio SK02 headphone preamplifier and a Meze 99 Neo headphones. This combo lets you enjoy quality headphone listening at an affordable price.
Fosi Audio SK02 Headphone Amplifier / Portable Preamplifier / DAC ES9038Q2M
Fosi Audio's SK02 is a versatile headphone amplifier that can also be used as a portable preamplifier. It is also equipped with an ES9038Q2M DAC chip, enabling it to support high-resolution streams up to PCM 32bit 384kHz and DSD256. An SGM8262 amplifier chip provides output power of up to 1000mW. Thanks to its gain control, it can drive headphones with impedances ranging from 16 ohms to 300 ohms. As for inputs, the SK02 features USB-C and Toslink optical connectivity. Outputs include two balanced jack 3.5mm and jack 4.4mm headphone outputs, plus an auxiliary jack 3.5mm/mini-Toslink output for connection to an amplifier.
View complete product page of FOSI AUDIO SK02 Fosi Audio SK02 headphone amplifier
MEZE 99 NEO Portable High Fidelity Headphone 26 Ohm 103dB
The Audio Meze 99 NEO are closed-circumaural headphones with a 26-ohm impedance and a sensitivity of 103dB, making them easy to use. They feature dynamic transducers no less than Ø40mm in diameter, with a balanced response curve from 15Hz to 25kHz, for a sound reproduction that's both warm and extremely precise. These headphones feature a robust design with silicone suspension and noble mechanical parts in steel, zinc and manganese alloys. The headphones' double-arm system, ABS shells and weight of just 260g ensure long, fatigue-free listening.
View complete product page of Meze 99 Neo Meze 99 Neo audio headphones
Products typeHeadphone Amplifier + Headphones
Package contents1x Fosi Audio SK02
1x Meze 99 Neo
FOSI AUDIO SK02 SPECIFICATIONS
Product typeHeadphone amplifier / Potable Preamplifier / Portable DAC
DAC chipES9038Q2M
Amplification chipSGM8262
Inputs1x USB-C input
1x Optical Toslink input
Outputs1x 3.5mm jack headphone output
1x 4.4mm balanced jack headphone output
1x AUX jack 3.5mm/mini-Toslink output
Supported sampling ratesUSB: PCM 32bit 384kHz, native DSD up to DSD256
Toslink optical: PCM 24bit 192kHz
Gain adjustment
Headphone output power3.5mm headphone output: 90mW @ 32Ω (Low gain) / 280mW @32Ω (High gain)
Balanced 4.4mm headphone output: 350mW @ 32Ω (Low gain) / 1100mW @32Ω (High gain)
Recommended headphone impedance16Ω-300Ω
Frequency response20Hz-20kHz (+/-0.02dB)
SNR3.5mm jack headphone output: 110dB (Low gain) / 116dB (High gain)
Balanced 4.4mm jack headphone output: 102dB (Low gain) / 113dB (High gain)
THD> 0.001%
Noise level3.5mm jack headphone output: 6.2uV
Balanced 4.4mm headphone output: 13uV
Crosstalk3.5mm jack headphone output: 110dB (Low gain) / 118dB (High gain)
Balanced 4.4mm headphone output: 103dB (Low gain) / 104dB (High gain)
Power supply5V DC via USB-C
Dimensions121 x 51x 43mm
WeightApprox. 300g
Package1x Fosi Audio SK02 portable DAC headphone amplifier
1x USB-A/C to USB-C cable
MEZE 99 NEO SPECIFICATIONS
Product typeHeadphones
Headphone typeClosed
CouplingCircumaural
Drivers typeDynamic
Drivers diameterØ40mm
EarpadsMedium density shape memory foam, leatherette covered
Self-adjusting headband
ArceauSteel, zinc and manganese alloy
HullsPlastic
AssemblyWithout glue, only with screws
Frequency response15Hz - 25kHz
Sensitivity103dB @ 1kHz, 1mW
Impedance26 Ohm
Power handlingRMS : 30mW
Max : 50mW
Cable conductorsOFC Copper
Cable sheathKevlar reinforced
Cable connectorsGold plated Jack 3.5mm
Dimensions170 x 205 x 85mm
Weight260g
Package1x Meze 99 Neo headphone
1x Carrying case
1x Accessory pouch
1x Cable
1x Telephone cable with microphone 1.2m
1x Jack 3.5 to Jack 6.35mm adapter
We propose a product pack consisting of a Fosi Audio SK02 headphone preamplifier and Audio Meze 99 Neo headphones. This combo lets you enjoy...
