Pack Fosi Audio ZD3 DAC + 2x ZA3 Amplifier + ATAudio King Wolf XLR Cables 50cm + Trigger Cable
This pack includes the ZD3 DAC and two ZA3 amplifiers from Fosi Audio, a pair of ATAudio XLR cables for balanced connections, and a double trigger cable to automate and synchronize power on/off.
By buying this product you get 42 loyalty points
Reference : 20430
429,00 €tax incl.
357,50 € tax excl.
Instead of 531,51 €
Pack content
Pack Fosi Audio ZD3 + ZA3 + DAC Cables + Amplifier + XLR Cables + Trigger Cable
Photo du pack Fosi Audio ZD3 + 2x ZA3 + XLR Cable + Trigger cable
This pack includes the ZD3 DAC and two ZA3 amplifiers from Fosi Audio, a pair of ATAudio XLR cables for balanced connections, and a double trigger cable to automate and synchronize power on/off. A high-performance, affordable package, featuring a DAC and two amplifiers designed by Fosi Audio to work perfectly together. The two devices are identical in design and form factor, for an impeccable aesthetic. The result is a complete system, to which all you need to do is add speakers to enjoy your music in the best possible conditions, without breaking the bank!
This pack contains two Fosi Audio ZA3 amplifiers, enabling you to set up a powerful, high-performance dual-mono amplification system.
Photo du Fosi Audio ZD3
Fosi Audio ZD3 DAC
Fosi Audio's ZD3 is a balanced DAC with excellent connectivity thanks to its multiple inputs and Bluetooth 5.0 chip. The ZD3's digital/analog conversion is based on an ESS ES9039Q2M DAC chip, supporting PCM up to 32bit 768kHz and DSD up to DSD512. Three DIP8-mounted OPAs can also be replaced if you wish to enjoy a different timbre.
FIND OUT MORE ABOUT THE FOSI AUDIO ZD3
2x Fosi Audio ZA3 amplifier
This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It integrates two TI TPA3255 amplifier chips mounted in DIP8, enabling it to deliver power up to 2x150W or 1x240W at 4Ω. It features a balanced stereo input on XLR in addition to its stereo RCA input, as well as speaker terminals and an active subwoofer output. It also features a 12V trigger. This makes it versatile, offering you the possibility of numerous types of Hi-Fi installations integrating one or more Fosi Audio ZA3 amplifiers.
This pack includes two Fosi Audio ZA3 amplifiers, enabling the installation of a dual-mono amplification system.
Learn more about the Fosi Audio ZA3
Photo du Fosi Audio ZA3
Photo câbles XLR ATAudio King Wolf
ATAudio King Wolf 50cm XLR cable
ATAudio XLR cables from the King Wolf range offer superb design quality, combined with excellent transmission performance, all at an affordable price. They feature OFC 6N copper conductors for excellent electrical conductivity, with braided copper shielding to effectively limit interference. The male and female XLR connectors feature 24k gold-plated copper contacts to maintain this excellent conductivity, while ensuring perfect resistance to oxidation. The cable is further protected by an attractive braided sheath.
Dual trigger cable
This 1.5m double trigger cable has been designed to enable you to trigger your mono amplifiers on and off with a single cable. It consists of a stereo 3.5mm jack connector to 2 stereo 3.5mm jack connectors.
Câble trigger double
Technical characteristcs
Pack content1x Fosi Audio ZD3 DAC
1x Pair of XLR cables
1x Trigger cable
Fosi Audio ZD3 specifications
Product typeDAC
DAC chipES9039Q2M
OPALME49720
Inputs1x USB-B
1x HDMI ARC
1x Coaxial
1x Optical Toslink
Bluetooth
Outputs1x Stereo XLR
1x Stereo RCA
Supported sampling ratesUSB : PCM up to 32bit 768kHz / DSD up to DSD512
Optical, Coaxial, HDMI : PCM up to 24bit 192kHz
Bluetooth : PCM up to 24bit 48kHz
Output levelXLR : 5Vrms
RCA : 2.5Vmrs
SNR126dB
SINAD≥ 120dB
THD+N< 0.00008%
DNR≥ 123dB
Noise level≤ 2µV
Bluetooth version5.0
Supported sampling ratesaptX HD, aptX, AAC, SBC
 USB compatibilityWindows 7, 8, 8.1, 10, 11 (driver required)
Mac OS X
Linux
Fosi Audio ZA3 spécifications
Product typeIntegrated amplifier
Amplification chipTI TPA3255
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
OutputsSpeaker terminals
Subwoofer output
Input sensitivity0.775V
SNR≥ 106dB
Dynamic range≥ 106dB
THD0.006%
Frequency response20Hz-20kHz (±0.1dB)
Supported speaker impedances2-4-8Ω
Output powerStereo mode: 2x150W @ 4Ω
Mono mode: 1x240W @ 4Ω
ATAudio King Wolf XLR cables specifications
Product typeXLR cables
Connectors2x Male XLR
2x Female XLR
Length50cm
Cable conductors materialCuivre OFC 6N
Cable shieldingCuivre tressé
Connectors contacts materialCopper
Connectors contacts platingGold 24k
Cable diameterØ6.5mm
Trigger cable
Product typeDual trigger cable
Connectors1x Jack 3.5mm stereo male
2x Jack 3.5mm stereo male
Length1.5m
This pack includes the ZD3 DAC and two ZA3 amplifiers from Fosi Audio, a pair of ATAudio XLR cables for balanced connections, and a double trigger...
