Pack Fosi Audio ZD3 DAC + ZA3 Amplifier + ATAudio King Wolf XLR Cables 50cm
With this pack, we offer you a set comprising Fosi Audio's ZD3 DAC and ZA3 amplifier, as well as a pair of ATAudio XLR cables to connect the two devices symmetricall. A package that's as powerful as it is affordable, incorporating a DAC and amplifier designed by Fosi Audio to work perfectly together.
Reference : 19863
299,00 €tax incl.
249,17 € tax excl.
Instead of 347,90 €
Pack content
Pack Fosi Audio ZD3 + ZA3 + Câbles DAC + Amplificateur + Câbles XLR
Photo du pack Fosi Audio ZD3 + ZA3 + Câbles XLR + Câble trigger
With this pack, we offer you a set comprising Fosi Audio's ZD3 DAC and ZA3 amplifier, as well as a pair of ATAudio XLR cables to connect the two devices symmetrically. A package that's as powerful as it is affordable, incorporating a DAC and amplifier designed by Fosi Audio to work perfectly together. Both devices feature identical design and form factor for impeccable aesthetics. The result is a complete system, to which all you need to do is add speakers to enjoy your music in the best possible conditions, without breaking the bank!
Photo du Fosi Audio ZD3
Fosi Audio ZD3 DAC
Fosi Audio's ZD3 is a balanced DAC with excellent connectivity thanks to its multiple inputs and Bluetooth 5.0 chip. The ZD3's digital/analog conversion is based on an ESS ES9039Q2M DAC chip, supporting PCM up to 32bit 768kHz and DSD up to DSD512. Three DIP8-mounted OPAs can also be replaced if you wish to enjoy a different timbre.
FIND OUT MORE ABOUT THE FOSI AUDIO ZD3
Fosi Audio ZA3 amplifier
This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It integrates two TI TPA3255 amplifier chips mounted in DIP8, enabling it to deliver power up to 2x150W or 1x240W at 4Ω. It features a balanced stereo input on XLR in addition to its stereo RCA input, as well as speaker terminals and an active subwoofer output. It also features a 12V trigger. This makes it versatile, offering you the possibility of numerous types of Hi-Fi installations integrating one or more Fosi Audio ZA3 amplifiers.
Learn more about the Fosi Audio ZA3
Photo du Fosi Audio ZA3
Photo câbles XLR ATAudio King Wolf
ATAudio King Wolf 50cm XLR cable
ATAudio XLR cables from the King Wolf range offer superb design quality, combined with excellent transmission performance, all at an affordable price. They feature OFC 6N copper conductors for excellent electrical conductivity, with braided copper shielding to effectively limit interference. The male and female XLR connectors feature 24k gold-plated copper contacts to maintain this excellent conductivity, while ensuring perfect resistance to oxidation. The cable is further protected by an attractive braided sheath.
Technical characteristcs
Pack content1x Fosi Audio ZD3 DAC
1x Fosi Audio ZA3 amplifier
1x Pair of XLR cables
Fosi Audio ZD3 specifications
Product typeDAC
DAC chipES9039Q2M
OPALME49720
Inputs1x USB-B
1x HDMI ARC
1x Coaxial
1x Optical Toslink
Bluetooth
Outputs1x Stereo XLR
1x Stereo RCA
Supported sampling ratesUSB : PCM up to 32bit 768kHz / DSD up to DSD512
Optical, Coaxial, HDMI : PCM up to 24bit 192kHz
Bluetooth : PCM up to 24bit 48kHz
Output levelXLR : 5Vrms
RCA : 2.5Vmrs
SNR126dB
SINAD≥ 120dB
THD+N< 0.00008%
DNR≥ 123dB
Noise level≤ 2µV
Bluetooth version5.0
Supported sampling ratesaptX HD, aptX, AAC, SBC
 USB compatibilityWindows 7, 8, 8.1, 10, 11 (driver required)
Mac OS X
Linux
Fosi Audio ZA3 spécifications
Product typeIntegrated amplifier
Amplification chipTI TPA3255
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
OutputsSpeaker terminals
Subwoofer output
Input sensitivity0.775V
SNR≥ 106dB
Dynamic range≥ 106dB
THD0.006%
Frequency response20Hz-20kHz (±0.1dB)
Supported speaker impedances2-4-8Ω
Output powerStereo mode: 2x150W @ 4Ω
Mono mode: 1x240W @ 4Ω
ATAudio King Wolf XLR cables specifications
Product typeXLR cables
Connectors2x Male XLR
2x Female XLR
Length50cm
Cable conductors materialCuivre OFC 6N
Cable shieldingCuivre tressé
Connectors contacts materialCopper
Connectors contacts platingGold 24k
Cable diameterØ6.5mm
Depasse mes esperances
Le meilleur compliment que l'on puisse faire à cet ensemble, c'est de se faire oublié. La musicalité est remarquable. Des les premières minutes d'écoute, on oublie tout sens critique pour se laisser envouter par la musique. Couplé avec des petites Dali Oberon 1 le mariage est parfait, C'est à ce genre d'appareil que l'on peut voir les progrès effectués sur les amplis classe D et les DAC d'entrée de gamme. Une belle offre d'audiopnonics,
This review has been posted for Pack Fosi Audio ZD3 DAC + ZA3 Amplifier + ATAudio King Wolf XLR Cables 50cm
With this pack, we offer you a set comprising Fosi Audio's ZD3 DAC and ZA3 amplifier, as well as a pair of ATAudio XLR cables to connect the...
