By buying this product you get 79 loyalty points
We offer you a Fosi x Eltax x WiiM product pack comprising the Wiim Pro + network player, a Fosi MC351 amplifier, a pair of Eltax Monitor III speakers and Audiophonics Wire speaker cable. This all-in-one package gives you a connected hifi system with plenty of power reserve and a quality sound reproduction.
The Fosi Audio MC351 integrated amplifier is a small all-in-one amplifier featuring two TI TPA3255 amplifier chips, enabling it to deliver up to 2x165W+350W of power at 4 ohms. This makes it possible to set up a 2.1-channel system for an immersive listening or TV experience with deep bass. A built-in DAC gives it the benefit of digital and optical inputs such as a USB-C input (24bit/96kHz), a Toslink optical input and a coaxial SPDIF input (24bit 192kHz). Digital inputs are complemented by Bluetooth 5.3 functionality supporting standard SBC and AAC codecs, as well as an analog RCA stereo input. The front panel features three potentiometers for volume, bass and treble control, as well as a small round Vumeter for an aesthetically pleasing vintage effect.
View complete product page of Fosi MC351The Eltax Monitor III are bookshelf loudspeakers offering excellent sound performance at a very affordable price. The bass delivered is incredible considering the compactness of these speakers and the rest of the spectrum is perfectly covered, with a very beautiful richness, dynamics and sound image. The Monitor IIIs are powered by two speakers. The first is a bass-midrange speaker with Bass-Reflex load located underneath the cabinet. The second is a soft dome tweeter. This combination provides a wide frequency response from 50Hz to 22kHz. The tweeter is solidly motorized to offer a very detailed high-midrange register, revealing a beautiful relief and excellent precision. The speakers are also equipped with decoupling spikes (plastic) and terminals speakers.
View complete product page of Eltax Monitor IIIThe WiiM Pro+ is a compact, extremely versatile and high-performance audiophile streamer that transforms a conventional audio system into a connected system. It opens the door to music streaming via WiFi and Bluetooth 5.1, and is compatible with numerous transmission modes such as DLNA/UPnP, AirPlay 2, Google Chromecast, Alexa Music Cast, Spotify Connect and Tidal Connect. Several units can also be used in combination to set up a true multi-room system, with full remote control via the WiiM App mobile application or a voice assistant such as Alexa, Google Assistant or Siri. The WiiM Pro+ is an improved version of the WiiM Pro, incorporating a better DAC and ADC as well as more efficient OPAs. Its performance, particularly with regard to its line input and output, has been revised upwards, with improved SNR and THD+N for even more accurate and transparent sound reproduction.
View complete product page of WiiM Pro+These speaker cables from the Audiophonics Wire series feature banana plugs with gold-plated OFC 4N copper contacts for corrosion and oxidation resistance, as well as enhanced conductivity. Wiring is carried out using ELBAC HP-240 cable with an external diameter of Ø9.4mm and OFC copper conductors with a cross-section of 2x 0.4mm² (AWG21). These speaker cables are shielded and insulated. They represent an excellent choice in terms of quality/price for wiring the speakers in your Hi-Fi installation.
View complete product page of AUDIOPHONICS WIRe HP cableTechnical characteristics
Product type | Amplifier + Speakers + Network player + Speaker cables |
Package content | 1x Fosi MC351 1x Eltax Monitor III 1x Wiim Pro+ 1x Audiophonics Wire HP cables |
FOSI MC351 specifications | |
Product type | Integrated amplifier |
Amplification type | Class D |
Channel | 2.1 channel |
Amplification chip | TI TPA3255 |
Inputs | 1x RCA analog stereo 1x USB-C 1x SPDIF coaxial 1x Optical Toslink Bluetooth |
Outputs | Speaker terminals 1x Passive subwoofer output on terminal block 1x Pre-out on 3.5mm jack |
Output power | 2x 165W @ 4 ohm |
Subwoofer output power | 350W @ 4 ohm |
Subwoofer output frequency | 20Hz-250Hz |
Termination impedance | 4-8 ohm |
Frequency response | 20Hz-20KHz (±0.1dB) |
THD | ≤0.03% |
SNR | ≥100dB |
Supported sample rates | USB: 24bit/96kHz Toslink optical and SPDIF coaxial: 24bit/192kHz |
Bluetooth standard | Bluetooth 5.3 |
Suppported Bluetooth codecs | SBC et AAC |
Bluetooth range | 10m obstacle-free |
Tone control | Bass and treble |
Power supply | 24/48V DC (32V 5A supplied) |
Dimensions | 330.6 x 228.6 x 76.2mm |
Color | Gray |
Package | 1x Fosi Audio MC351 amplifier 1x Bluetooth antenna 1x USB-A to USB-C cable 1x Toslink optical cable 1x 32V 5A DC power adapter |
ELTAX MONITOR III specifications | |
Product type | Speakers |
System type | 2 Ways Bass-Reflex |
Power | 90W |
Woofer | Ø130mm, isolated |
Tweeter | Ø25mm, soft dome |
Frequency response (±4dB) | 50Hz - 22kHz |
Sensitivity | 89dB |
Impedance | 4-8Ω |
Dimensions (LxPxH) | 195 x 300 x 230mm |
Weight | 5kg (The pair) |
Color | Black |
WIIM PRO+ specification | |
Product type | Streamer |
Inputs | WiFi Bluetooth 5.1 1* Ethernet RJ45 1* Optical Toslink 1* Stereo RCA |
Outputs | Bluetooth 5.1 A2DP Sink 1* Stereo RCA 1* Coaxial 1* Optical Toslink 1* Trigger 12V on Jack 2.5mm |
Wireless connectivity | WiFi 2.4G/5G IEEE 802.11b/g/n/ac Bluetooth 5.1 Chromecast |
Supported audio codecs | MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG |
Suppported streaming services and webradios | Spotify Deezer Qobuz Amazon Music Tidal Pandora Napster Apple Music TuneIn iHeartRadio LinkPlay Radio Spotify Connect Tidal Connect Roon Ready certified |
Supported network protocols | Spotify Connect Tidal Connect Amazon Music Cast AirPlay 2 DLNA Chromecast |
Supported output sampling rates | PCM 24bit 192kHz |
Bit-Perfect | |
Gapless playback | |
EQ | 10 bands 24 presets |
DAC chip | AKM AK4493SEQ |
ADC chip | TI Burr-Brown PCM1861 |
Line output level | Max 2.1V RMS |
SNR | 120dB |
THD+N (line out) | 0.0004% (-108dB) |
Supply voltage | 5VDC 2A via USB-C |
Dimensions | 140*140*41mm |
Weight | 320g |
Package | 1* WiiM Pro 1* Power adapter 1* Voice remote control 1* USB-C cable 1* RCA cable 1* Optical cable |
Audiophonics Wire HP Cable specifications | |
Product type | Speakers câble |
Connectors | Banana plugs |
Length | 3m |
COnductor material | OFC Copper |
Conductors section | 0.4mm² (AWG21) |
Connectors contact plating | Gold |
Shielding | |
External sheath | Extra-flexible PVC |
Identification | Black and red |
Color | Black |
Weight | 500g / cable |
Package | Sold by pair |
