Pack FX-Audio DS07 DAC + FX-Audio R07 Balanced Headphone Amplifier + Audiophonics Wire XLR Cables 30cm
We offer you a pack of FX-Audio products including their DS07 balanced DAC, the R07 balanced headphone amplifier and a pair of Audiophonics Wire XLR modulation cables. This desktop set, combined with headphones, will let you enjoy high-fidelity audio.
By buying this product you get 33 loyalty points
Reference : 19378
339,00 €tax incl.
282,50 € tax excl.
Instead of 377,90 €
Shipping date: 16-04-2025.
Pack content
Pack FX-Audio FX-Audio DS07 DAC + FX-Audio R07 Balanced Headphone Amplifier + Audiophonics Wire XLR 30cm
Photo of FX-Audio DS07 + R07 + Audiophonics Wire XLR pack
FX-Audio DS07 balanced DAC
FX-Audio's DS07 DAC features high-quality components such as an ES9068AS DAC chip, XMOS XU-216 USB interface, QCC5125 Bluetooth 5.1 receiver chip and no less than 5 OPA1612 OPAs. It supports high-resolution PCM 32bit 768kHz streams, native DSD up to DSD512 and even MQA streams. Its connectivity is made up of the essentials, with digital inputs (USB, optical, coaxial, Bluetooth) as well as two analog outputs: RCA and balanced XLR.
View complete product page of FX-AUDIO DS07 FX-Audio DS07 picture
FX-Audio R07 balanced headphone amplifier
The FX-Audio R07 is a balanced headphone amplifier based on the use of OPA1612 operational amplifiers for output power up to over 2000mW on its balanced 4.4mm jack and 4-pin XLR headphone outputs. Balanced XLR and RCA inputs are available for the R07.
View complete product page of FX-Audio R07 Photo du FX-Audio R07
Audiophonics Wire XLR interconnect cable (30cm)
These balanced XLR interconnect cables, assembled in our workshops in France, consists of a Mogami Neglex W2549 cable and Neutrik NC3FXX-B and NC3MXX-B XLR connectors. It features OFC copper conductors and full shielding, while the connector contacts are 24K gold-plated for increased resistance to corrosion and oxidation.
View complete product page of Audiophonics Wire XLR Photo of Audiophonics Wire XLR interconnect cables
Product typeDAC + Headphone amplifier + Interconnect cable
Package contents1x DAC FX-Audio DS07
1x FX-Audio R07 headphone amplifier
1x Paire of Audiophonics Wire XLR interconnect cables (30cm)
DS07 DAC SPECIFICATIONS
Product typeDAC
Dac chipES9068A
USB interfaceXMOS XU216
AOP5x OPA1612
Inputs1x USB-B input
1x Optical Toslink input
1x Coaxial SPDIF input
Bluetooth
Outputs1x RCA stereo output
1x XLR stereo output
THD+N0.00015%
Dynamic range120dB
SNR125dB
Frequency response10Hz-50kHz
USB transmissionAsynchronous
Supported sample ratesUSB: PCM 32bit 768kHz, native DSD up to DSD512, MQA.
Optical, coaxial: PCM 24bit 192kHz, DSD DoP64, MQA.
Bluetooth chipQCC5125
Bluetooth-compatible codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Power consumptionOperating : 5W
Standby : < 0.5W
Dimensions125 x 80 x 176mm
Weight896g
Package1x DAC FX-Audio DS07
1x Remote control
1x Bluetooth antenna
1x USB-A to USB-B cable
1x Power supply cable
R07 HEADPHONE AMPLIFIER SPECIFICATIONS
Amplification componentsOPA1612
Inputs1x RCA stereo input
1x XLR balanced stereo input
Outputs1x 6.35mm jack output
1x 4.4mm balanced jack output
1x XLR 4-pin balanced output
GainLow : 0dB High : 6dB
Volume control
Max. output power on balanced outputs5251mW @ 32 ohm (gain 0dB - THD+N 0.00029%)
114mW @ 150 ohm (gain 0dB - THD+N 0.00026%)
57.3mW @ 300 ohm (gain 0dB - THD+N 0.00029%)
28.5mW @ 600 ohm (gain 0dB - THD+N 0.00018%)
2095mW @ 32 ohm (gain 6dB - THD+N 0.00046%)
459mW @ 150 ohm (gain 6dB - THD+N 0.00025%)
228mW @ 300 ohm (gain 6dB - THD+N 0.00021%)
28.5mW @ 600 ohm (gain 6dB - THD+N 0.00018%)
Power supplyAC 100-240V
Dimensions120 x 80 x 135mm
Weight984g
Package1x FX-Audio R07 headphone amplifier
1x RCA-RCA stereo modulation cable
1x Mains power cable (EU)
XLR AUDIOPHONICS WIRE INTERCONNECT CABLE SPECIFICATIONS
Product typeStereo XLR cable
Connectors2* Male XLR
2* Female XLR
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Neutrik connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialPolyamide
We offer you a pack of FX-Audio products including their DS07 balanced DAC, the R07 balanced headphone amplifier and a pair of Audiophonics Wire...
