By buying this product you get 273 loyalty points
We offer you a Gustard pack featuring top-of-the-range products. It includes the R2R R26 discrete DAC, the H26 headphone preamplifier/amplifier and a pair of Pangea Premier SE Balanced XLR modulation cables (60cm).
Gustard's DAC-R26 is an exceptional digital-to-analog converter. It uses R2R architecture and high quality discrete components, perfectly optimized to deliver exceptional sound performance. In addition to full connectivity, it features Bluetooth and network connectivity for remote control of your music playback. The whole unit is housed in a sublime, modern and luxurious chassis.
View complete product page of Gustard R26Gustard's H26 is a balanced Class A audiophile headphone preamplifier/amplifier featuring discrete components. It features 8 pairs of power transistors, two dual LME49720 AOPs, two toroidal transformers, a relay volume control matrix and balanced architecture. Whether on its preamplified line outputs or its available headphone outputs, the H26 offers exceptional performance on all levels.
View complete page product of Gustard H26This pair of XLR modulation cables features Grade One Cardas copper conductors (hot end) and OFC copper conductors (cold end) for enhanced conductivity. A double shield against EMI/RFI interference in silver-plated braided copper and AL Mylar aluminum foil protects this cable effectively. The overall structure is completed by PE tube insulation and PVC jackets. XLR connectors feature gold-plated contacts for corrosion and oxidation resistance, and a high-end “Black Carbon” finish.
View complete product page of PANGEA PREMIER SE BALANCEDTechnical characteristics
Product type | R2R DAC + Preamplifier / Headphone amplifier + XLR modulation cables |
Package contents | 1x Gustard R26 1x Gustard H26 1x PANGEA PREMIER SE BALANCED XLR-XLR balanced interconnect cables (Pair) |
Product type | Discrete R2R DAC |
Inputs | 1x USB-C 1x USB-B 1x RJ45 1x I2S (HDMI) 1x AES/EBU 1x Coaxial 1x Optical Toslink Bluetooth 5.0 |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
Supported sampling rates | USB / I2S / LAN : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256 AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 MQA |
USB Compatibilité | Windows 7/8/10/11 Mac OSX Linux |
Network protocol | Roon AirPlay UPnP |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX LL, aptX HD, LDAC |
Frequency response | 20Hz-20kHz ±0.2dB |
Dynamic range | > 115dB |
SNR | > 122dB |
Crosstalk | -134dB @ 1kHz |
THD+N | ≤ 0.003% @ 1kHz |
IMD | 0.008% à 0dBFS |
Output levels | RCA : 2.5Vrms (fixed volume) XLR : 5Vrms (fixed volume) |
Outpu timpedance | RCA : 100Ω XLR : 100Ω |
Supply voltage | 115-230VAC 50/60Hz |
Consumption | < 30W |
Dimensions | 330 x 260 x 65mm |
Color | Black |
Package | 1x Gustard DAC-R26 1x Remote control 1x Power cable 1x Antenna 1x USB-A to USB-B cable |
GUSTARD H26 PREAMPLIFIER SPECIFICATIONS | |
Product type | Preamplifier Headphone amplifier |
OPA | LME49720 |
Inputs | 1x RCA stereo 2x XLR balanced |
Outputs | 1x Stereo RCA output 1x XLR stereo balanced output 1x 6.35mm headphone output 1x Balanced headphone output 4.4mm jack 1x XLR 4-pin balanced headphone output |
Input sensitivity | RCA : 2-3Vrms XLR : 4-6Vrms, max. 12Vrms |
Input impedance | RCA : 4 KΩ XLR : 8 KΩ |
PREAMPLIFIER SECTION MEASUREMENTS | |
Output impedance | RCA : 100Ω XLR : 100Ω |
Frequency response | 20-80kHz / -0.1dB |
SNR | > 123dB |
Crosstalk | < -123db 1khz |
THD+N | < 0.0002% |
IMD | < 0.0003% |
HEADPHONE AMPLIFIER SECTION MEASUREMENTS | |
Output impedance | 6.35mm jack: 0.05Ω Balanced outputs (jack 4.4 and XLR 4 pins): 0.1Ω |
SNR | 20-80kHz / -0.1dB |
Crosstalk | < -120db 1khz |
THD+N | < 0.0005% @ 9700mW 32Ω load |
IMD | < 0.0005% @ 9700mW 32Ω load |
Max. undistorted output power | 6000mW @32ohm load |
Max. output power | 12000mW @32ohm load (THD=1%) |
Load power (per channel) | 64Ω 7350mW 150Ω 3125mW 300Ω 1576mW 600Ω 788mW |
Power supply | 100-240V AC (Selector on rear panel) |
Power consumption | < 30W |
Dimensions | 330x 260 x 65mm |
Color | Black |
Gross weight | 7Kg |
Package | 1x Gustard H26 preamplifier/headphone amplifier 1x Power supply cable 1x Remote control |
PANGEA PREMIER SE BALANCED XLR CABLE SPECIFICATIONS | |
Conductor type | Pur Cardas Grade One Copper (Hot point) OFC 100% Copper (Cold point) |
Insulation | PE AIR TUBE |
EMI / RFI shield | Insulation with Aluminium Mylar Silver plated foil |
Sheath material | High-strength thermoplastic sheath |
Contacts plating | Gold |
Soldering type | Hand made |
Lenght | 0.6m |
Package | The pair |
