Pack Hidizs DAP AP80 Pro-X Black + Case AP80 Pro-X Black + Earphones Letshuoer S12 Pro
We offer you a pack of Hidizs and Letshuoer products consisting of the DAP AP80 Pro-X, its case and Letshuoer S12 earphones. This pack is sure to delight audiophiles on the move.
By buying this product you get 32 loyalty points
Reference : 19485
329,00 €tax incl.
274,17 € tax excl.
Instead of 362,91 €
Pack content
Pack Hidizs x Letshuoer Hidizs DAP AP80 Pro-X Black + Case AP80 Pro-X Black + Earphones Letshuoer S12 Pro
We offer you a pack of Hidizs and Letshuoer products consisting of the Hidizs AP80 Pro-X DAP, its protective case and Letshuoer S12 earphones. This pack is sure to delight audiophiles on the move.
Hidizs AP80 Pro-X: Balanced DAP Digital Player 2x ES9219C Bluetooth 32bit 384kHz DSD256 MQA Black
The Hidizs AP80 Pro-X DAP is a compact, high-performance digital music player. It features a beautiful 2.45" IPS touchscreen and several high-end components: two ES9219C DACs, a powerful FPGA and a bidirectional Bluetooth 4.2 chip. This DAP is capable of supporting high-resolution streams up to PCM 32bit 384kHz, DSD256 and MQA. In terms of connectivity, there's a balanced 4.4mm jack output and a 3.5mm jack output for a high level of compatibility. The whole system is powered by an 800mAh battery, providing 6-8 hours of balanced listening time.
View complete product page of Hidizs AP80 PRO-X xxx
Hidizs Leatherette Protective Case for Hidizs AP80 Pro-X Black
This Hidizs protective cover has been designed to provide effective protection for the Hidizs AP80 Pro-X portable digital player. It leaves all the DAP's buttons and screen accessible, and at the same time gives it a sober, modern look, with its leatherette design.
View complete product page Hidizs AP80 PRO-X Housse pour Hidizs AP80 PRO-X
Letshuoer S12 Pro: Dynamic IEM In-Ear Monitors Planar Diaphragm 16 Ohm 102dB 20Hz-20kHz
Letshuoer's S12 Pro earphones feature a 14.8mm planar diaphragm that brings clarity and resolution to the sound reproduction of your favorite tunes. These in-ear monitors are great companions for everyday use. Sensitivity rises to 102dB, and the adjustments made to tone management deliver clear highs and punchy bass, as well as professional reproduction of many audio details.
View complete product page of LETSHUOER S12 PRO LETSHUOER S12 PRO
Product typeDAP + Protective case + In-ear monitors
Package contents1x Hidizs AP80 Pro-X
1x Protective case for Hidizs AP80 Pro-X
1x Letshuoer S12 Pro
HIDIZS AP80 PRO-X DAP SPECIFICATIONS
Product typeDigital Audio Player (DAP)
InputsBluetooth 4.2
1x Micro SD Slot
USB-C
OutputsBluetooth 4.2
USB-C
1x Single-ended Jack 3.5mm
1x Balanced Jack 2.5mm
CPUIngenic X1000
DAC Chip2x ES9219C
Pedometer sensorKX126
TouchscreenSamsung 2.45" (480x360) IPS HD
FPGAHBC3000
PotentiometerALPS
OSHiBy OS 3.0
Supported Bluetooth codecsaptX, LDAC, UAT
DSD up to DSD256
MQA
Battery800mAh 3.7V Li-Polymer
Gain settingHigh
Low
Antialiasing filters8
MSEB feature10
Supply voltage5VDC 2A
Dimensions61 x 54.5 x 13.8mm
Protective case Specifications
Product typeProtective cover for Hidizs AP80 PRO-X
MaterialLeatherette
LETSHUOER S12 Pro specifications
Type of productIn-Ear Monitors (IEM)
Type of driversPlanar membrane
Headphone connectors
0.78mm 2PIN
Cable connectorJack 2.5mm
Jack 3.5mm
Jack 4.4mm
Impedance16Ω
Sensitivity102dB/mW
Cable length1.25m
ColorSilver
Package1x In-ear headphones (IEM)
1x Storage pocket
1x 0.78mm 2 Pin cable
1x 2.5mm Jack
1x 3.5mm Jack
1x 4.4mm Jack
6x pairs of ear tips (S / M / L)
Pack Hidizs AP80 Pro-X DAP Black + AP80 Pro-X Case Black + Letshuoer S12 Pro Earphones
We offer you a pack of Hidizs and Letshuoer products consisting of the DAP AP80 Pro-X, its case and Letshuoer S12 earphones. This pack is sure to...
