Pack iBasso DX260 DAP Black + Hifiman Sundara Silver Headphones
We offer you a pack of IBasso and HiFiman products, comprising the DAP DX260 and HiFiman Sundara Silver headphones. These top-of-the-range products will let you enjoy uncompromising sound reproduction quality.
By buying this product you get 123 loyalty points
Reference : 19462
1 239,00 €tax incl.
1 032,50 € tax excl.
Pack content
Pack iBasso x Hifiman Sundara Silver DAP DX260 Black + Hifiman Sundara Silver headphones
Pack iBasso DAP DX260 Black + Hifiman Sundara Silver headphones
We offer you a pack of IBasso and HiFiMAN products, comprising the DX260 DAP and HiFiMAN Sundara Silver headphones. These top-of-the-range products will let you enjoy uncompromising sound reproduction quality.
iBasso DX260 Digital Portable Audio Player DAP 8x CS43198 Balanced Bluetooth WiFi
The iBasso DX260 is a high-end DAP featuring an octa-DAC matrix with 6 CS43198 chips. These DAC chips are supported by a high-performance FGPA and two NDK femtosecond clocks. A little gem of technology, the DX260 supports high-resolution codecs up to PCM 24bit 384kHz and DSD DoP128 on its coaxial output. Ultra-high-performance, it has a dynamic range of 134dB and a THD+N of -123dB. The entire system is powered by a Qualcomm Snapdragon 660 processor and Android 11. Connectivity features include a bi-directional USB-C port, a micro SD slot, a balanced 4.4mm jack output, a 3.5mm jack output, Bluetooth 5.0 and WiFi. Thanks to a perfectly optimized design and audiophile-grade components, it offers a wonderfully rich listening experience.
View complete product page of iBasso DX260 iBasso DX260
HIFIMAN SUNDARA SILVER Planar Magnetic Open-Back Headphones High sensitivity 94db
HiFiman Sundara Silver headphones offer many advantages, with their lightweight diaphragms, 94dB efficiency and 32-ohm impedance, enabling a wide range of use for nomadic or sedentary high-fidelity listening. It benefits from a bandwidth beyond the audible spectrum (6Hz-76kHz) to reveal the finest details of your favorite recordings. Its design and ergonomics make these headphones both visually pleasing and comfortable for long listening sessions.
View complete product page of HIFIMAN SUNDARA SILVER HIFIMAN SUNDARA SILVER
Tecnhical characteristics
Products typeDAP + Heaphones
Package contents1x iBasso DX260
1x HIFIMAN SUNDARA SILVER
iBasso DX260 specifications
Product typeDigital audio player (DAP)
TouchscreenIPS Sharp 5", 1080x1920px
Audio formatsAPE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST
ConnectivityUSB-C 3.1
OutputsJack 4.4mm balanced headphone output
Jack 3.5mm single-ended headphone output
Jack 4.4mm line output
Jack 3.5mm line outpuit
Jack 3.5mm coaxial output
USB OTG output
WiFi802.11b/g/n/ac (2.4GHz/5GHz)
Bluetooth5.0
RAM4Go LPDDR4X
ROM64Go
BatteryLiPo 3.8V 4400mAh
Charging time2.5h
Average playback lifetime14h (may vary depending on the files played, the volume used and the impedance of the headphones/earphones)
Jack 4.4mm balanced headphone output measurements
Max output level6Vrms
Output power2x1015mW @ 32Ω, THD < 0.5%
Frequency response10Hz ~ 75kHz (-1dB)
SNR133dB
Dynamic range133dB
THD+N-121dB (A-wt, 600Ω)
-114dB (A-wt, 32Ω)
Crosstalk145dB
Noise floor< 930nV (gain faible)
Jack 3.5mm single-ended headphone output measurements
Max output level3Vrms
Output power2x280mW @ 32Ω, THD < 0.5%
2x586mW @ 16Ω, THD < 0.1%
SNR128dB
Dynamic range128dB
THD+N-115dB (A-wt, 600Ω)
-110dB (A-wt, 32Ω)
Crosstalk118dB
Noise floor< 850nV (gain faible)
Jack 4.4mm balanced line output measurements
Max output level4Vrms
SNR133dB
Dynamic range134dB
THD+N-123dB
Crosstalk145dB
Jack 3.5mm single-ended line output measurements
Max output level2Vrms
SNR128dB
Dynamic range128dB
THD+N-112dB
Crosstalk115dB
Dimensions123 x 74.5 x 17.5mm
Weight229g
Package1x iBasso DX260
1x USB-C cable
1x Coaxial cable
1x TPU cover
Screen protections
HiFiman Sundara Silver specifications
Product typeHeadphone
Headphone typeOpen back
Headphone formatCircumaurale
Headphone technologyPlanar Magnetic
Headphone connecticJack 3.5mm
Frequency response6Hz - 75000Hz
Impedance32 Ohm
Sensitivity94dB
Weight342g
ColorSilver
Package1x HIFIMAN Sundara Silver
1x Headphone cable 3.5mm Jack 1.5m
1x Travel case
We offer you a pack of IBasso and HiFiman products, comprising the DAP DX260 and HiFiman Sundara Silver headphones. These top-of-the-range products...
