Pack Phono Aiyima T3 Pro Preamplifier + Dayton Audio TT-1BT Turntable + Pangea Premier SE Phono RCA Cable
We offer you a phono product pack consisting of the AIYIMA T3 Pro phono preamplifier, the Dayton Audio TT-1BT turntable and the Pangea Premier SE RCA phono cable. Coupled with an amplifier and passive speakers, this pack will let you enjoy your vinyl collection.
By buying this product you get 41 loyalty points
Reference : 19398
419,00 €tax incl.
349,17 € tax excl.
Instead of 467,00 €
Pack content
Pack Phono Phono preamplifier AIYIMA T3 PRO + Turntable Dayton audio TT-1BT + Phono RCA cable PANGEA PREMIER SE
Pack Phono Aiyima T3 Pro + Dayton Audio TT-1BT + Pangea Premier SE Phono
We offer you a phono product pack consisting of the Aiyima T3 Pro phono preamplifier, the Dayton Audio TT-1BT turntable and the Pangea Premier SE RCA phono cable. Coupled with an amplifier and passive speakers, this pack will let you enjoy your vinyl collection.
Aiyima T3 Pro Phono Preamplifier MM/MC NE5532 + JRC2068
The Aiyima T3 Pro is a compact yet powerful phono preamplifier. Compatible with both MM and MC cells, it can be easily adapted to any vinyl turntable. Its front panel features gain (0-39dB) and volume controls. For rich, musical sound reproduction, the Aiyima T3 Pro uses two NE5532 and two JRC2068 AOPs, the latter dedicated to gain control. It also features input impedance adjustment for a high level of compatibility.
View complete product page of Aiyima T3 Pro AIYIMA T3 PRO
Dayton Audio TT-1BTW turntable
Dayton Audio's TT-1BTW vinyl turntable offers a blend of vintage and modernism. In addition to playing vinyl through its Audio-Technica AT-VM95E pickup, this turntable features a USB port and Bluetooth functionality for an extended level of connectivity. Bluetooth functionality lets you stream the warm sound of your vinyl to any Bluetooth receiver, be it your speakers or wireless headphones, while the USB-B port lets you encode your vinyl into MP3s for enjoyment on a variety of devices.
Viex complete product page of Dayton Audio TT-1BTW Turntable Photo of Dayton Audio TT-1BTW turntable
PANGEA PREMIER SE Phono Cable RCA / RCA with Ground 1.25m
Pangea's Premier SE is an excellent RCA cable for turntables, featuring a grounding conductor. To ensure optimum conductivity, the brand uses extremely pure Cardas and OFC copper for its conductors, as well as gold-plated connectors. Each cable is made up of several conductors of different cross-sections with a layer of PE dielectric and a double shield of aluminum foil and braided OFC copper for real noise attenuation and transparent reproduction.
View complete product page of PANGEA PREMIER SE PANGEA PREMIER SE Phono RCA cable
Product typePhono preamplifier + Turntable + RCA phono cable
Package contents1x Aiyima T3 Pro
1x Dayton Audio TT-1BT
1x PANGEA PREMIER SE Phono RCA cable
AIYIMA T3 Pro specification
InputStereo RCA
OutputStereo RCA
GND termnalYes
Compatible cartridgeMM
MC
Gain control range0-39dB
Switchable input impedance75Ω
82Ω
100Ω
330Ω
510Ω
910Ω
1kΩ
8200kΩ
Chips2x NE5532
2x JRC2068
Frequency responseRIAA ±3dB
Distortion0.02%
SNR≥ 76dB
Output levelMM Mode: 5mV
MC Mode: 0.5mV
Max output amplitude450mV
Supply voltage12V AC 1.5A
Dimensions120 x 104 x 32mm
Weight425g
Package1x Aiyima T3 Pro
1x 12V Power supply
Spécifications de la platine DAYTON AUDIO TT-1BT
Product typeVinyl tunrtable
Driver typeBelt drive
Playback speeds33T 45T
Playback speed variation±1.0%
Wow et flutter≤ 0.15%
SNR55dB
Tonearm
Type of tonearmStraight with static balance
Toenarm materialAluminum
Effective length218.5mm
Overhang18.5mm
Headshell terminalØ1.2mm 4 pins
Audio-Technica AT-VM95E cartridge
Cell typeMM cell
Output voltage4mV(@1 kHz, 5 cm/sec.)
Channel balance< 2.0dB
Channel separation> 20dB
Recommanded impedance load resistance47kΩ
Mass6.1g (0.22 oz)
Recommanded vertical tracking force1.8-2.2 g (2.0g standard)
Digital outputs
Bluetooth version5.0
Supported Bluetooth codecsQualcomm aptX
USB output sample rates44.1kHz / 48kHz
Power consumption6W
Power supply12V DC 500mA
Total dimensions415 x 340 x 148mm
Weight6.2kg
Package1x DAYTON AUDIO TT-1BTW turntable with Audio-Technica AT-VM95E cartridge
1x USB-B to USB-A cable
1x RCA cable with ground wire
1x Power cable
Spécifications du câble phono pangea premier SE
Cable typeRCA / RCA Phono cable with ground wire
Length1.25m
Conductors materialCardas Copper and OFC
Connectors platingGold
Ground connectors formatSpades
Insulation materialPE
ShieldingDual : Aluminium foil and braided OFC Copper
SheathNylon
Pack Phono Aiyima T3 Pro Preamplifier + Dayton Audio TT-1BT Turntable + Pangea Premier SE Phono RCA Cables
We offer you a phono product pack consisting of the AIYIMA T3 Pro phono preamplifier, the Dayton Audio TT-1BT turntable and the Pangea Premier SE...
