Pack Shanling M0 Pro DAP Black + M0 Pro Case Black + Moondrop ARIA 2 Earphones
We offer you a Shanling and Moondrop product pack comprising the DAP Shanling M0 Pro, its protective case and Moondrop ARIA 2 in-ear monitors. This pack will delight nomadic audiophiles on a budget.
By buying this product you get 20 loyalty points
Reference : 19489
209,00 €tax incl.
174,17 € tax excl.
Instead of 248,91 €
Pack content
Pack Shanling x Moondrop Shanling M0 Pro DAP Black + M0 Pro Case Black + Moondrop ARIA 2 Earphones
We offer you a Shanling and Moondrop product pack comprising the Shanling M0 Pro DAP, its protective case and Moondrop Aria 2 in-ear monitors. This pack will delight nomadic audiophiles on a budget.
Shanling M0 Pro : compact HiFi Digital Audio Player DAP DAC 2xES9219C Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD Black
The Shanling M0 Pro digital music player benefits from a pair of ESS ES9219C DAC/headphone amplifier chips, enabling it to achieve a high level of performance in terms of sound rendering. Indeed, this little DAP offers an SNR of 119dB and distortion of just 0.0004%, while supporting sampling rates up to PCM 32bit 384kHz for faithful, detailed sound reproduction. Ultra-compact, it features a Shanling Mtouch interface for quick and easy navigation, plus bi-directional Bluetooth 5.0 functionality enabling it to transmit or receive high-definition aptX HD and LDAC codecs. On the connectivity side, it features a bi-directional USB-C port and a 3.5mm jack output for a high level of compatibility. A 650mAh battery provides autonomy of up to 14.5 hours.
View complete product page of Shanling M0 Pro xxx
Shanling Leatherette Protective Case for DAP Shanling M0 Pro Black
This leatherette protective case has been specially designed to effectively protect the Shanling DAP M0 Pro, while allowing convenient access to all the device's controls. The inside of the case is reinforced by a metal frame for added durability.
View complete product page of leatherette protective case for DAP Shanling M0 Pro Housse de protection similicuir pour DAP Shanling M0 Pro
Moondrop Aria 2: IEM Dynamic In-ear monitors 122dB 33 Ohm 16Hz-22kHz
The Moondrop Aria 2 in-ear monitors feature dynamic drivers and composite domes for low distortion and high dynamics. Their 33-ohm impedance and 22dB sensitivity make them easy to drive. Their extended frequency response of 16Hz-22kHz delivers rich, detailed sound reproduction. They come with an easily replaceable acoustic filter and an audiophile-quality cable. This cable features a litz-wire structure and silver-plated copper conductors, as well as interchangeable 3.5mm and balanced 4.4mm jack terminanals.
View complete product page of MOONDROP ARIA 2 MOONDROP ARIA 2
Products typeDAP + Protective Case + In-ear monitors
Package contents1x DAP M0 Pro
1x Protective case for Shanling M0 Pro
1x Moondrop Aria 2
SHANLING M0 PRO DAP SPECIFICATIONS
Product typeDigital audio player (DAP)
DAC chips2* ES9219C
InputsBluetooth 5.0
1* Slot Micro SD
OutputsBluetooth 5.0
1* Jack 3.5mm
Touchscreen1.54" 240*240px
Battery650mAh
Autonomy14.5h
Supported Bluetooth codecsTransmitter: SBC, AAC, aptX, LDAC
Receiver: SBC, AAC, LDAC
Supported file formatsDSD (.iso, .dsfl, .dff)
DXD
APE
ALAC
WAV
AIFF
AIF
DTS
MP3
WMA
AAC
OFF
MP2
M4A
AC3
CUE
M3U
Switchable gainLow
Medium
High
Output powerSingle-ended output: 1.7V @ 32 Ohm (90mW @ 32Ω)
Balanced output: 2.75V @ 32 Ohm (236mW @ 32Ω)
Frequency responseSingle-ended output: 20Hz - 40kHz (-0.5dB)
Balanced output: 20Hz - 40kHz (-0.5dB)
THD+NSingle-ended output: 0.0006% @ 32Ω (A-Weighted @ 720mV)
Balanced output: 0.0004% @ 32Ω (A-Weighted @ 1V)
Dynamic rangeSingle-ended output: 119dB @ 32Ω (A-Weighted)
Balanced output: 121dB @ 32Ω (A-Weighted)
Channel separationSingle-ended output: 72dB @ 32Ω
Balanced output: 109dB @ 32Ω
SNRSingle-ended output: 118dB @ 32Ω (A-Weighted)
Balanced output: 119dB @ 32Ω (A-Weighted)
Output impedanceSingle-ended output: < 0.4Ω
Balanced output: < 0.8Ω
Dimensions43.8*45*13.8mm
Weight36.8g
Package1* Shanling M0 Pro
1* USB cable
CASE SPECIFICATIONS
Product typeDAP protective cover
CompatibilityShanling M0 Pro
MaterialLeatherette
Dimensions43.8*45*13mm
Dimensions12g
Product typeIn-Ear Monitors IEM
Speaker driver typeDynamic
Connector2 pins 0.78mm
Impedance33 Ohm @1kHz
Sensitivity122dB/Vrms @1kHz
Frequency response16Hz - 22kHz
Total harmonic distortion (THD)≤ 0.05% @1kHz
Package1x Moondrop Aria 2
1x Earphone Cables
12x Eartips
1x Storage Case
1x User Manual
We offer you a Shanling and Moondrop product pack comprising the DAP Shanling M0 Pro, its protective case and Moondrop ARIA 2 in-ear monitors. This...
