Pack Shanling Onix Overture XM5 DAP + Protective Case + Monolith M1060 Headphones
We offer you a Shanling and Monolith product pack comprising the Onix Overture XM5 portable player, its protective case and the Monolith M1060 headphones. This pack will delight the most demanding audiophiles.
By buying this product you get 112 loyalty points
Reference : 19494
1 129,00 €tax incl.
940,83 € tax excl.
Instead of 1 187,01 €
Pack content
Pack Shanling x Monolith DAP Shanling Onix Overture XM5 + Protective Case + Monolith M1060 Headphones
Pack DAP Shanling Onix Overture XM5 + Protective Case + Monolith M1060 Headphones
Shanling Onix Overture XM5 : Portable digital audio player DAP ES9039PRO 2x TPA6120 32bit 768kHz DSD512
Shanling's Onix Overture XM5 is a high-end DAP designed with state-of-the-art components to deliver the best possible performance. In fact, the Overture XM5 incorporates a latest-generation ES9039PRO DAC chip combined with a 16-core XMOS XU316 USB processor, for optimum decoding of high-resolution audio signals up to PCM 32 bit 768kHz and DSD512. With the help of a powerful amplifier section consisting of two TPA6120 chips, the Overture XM5 also boasts a powerful output of up to 1070mW at 32Ω, which, coupled with its gain control, means it can drive the vast majority of headphones and earphones on the market, maintaining a clear, low-distortion output in all circumstances.
View complete product page of Shanling Onix Overture XM5 Shanling Onix Overture XM5
Shanling protective leather case for Onix Overture XM5 DAP
This Shanling leather protective cover has been specially designed for the DAP Onix Overture XM5. It not only looks good, but also protects the device effectively while leaving the control buttons and screen accessible.
View complete product page of protective leather case for DAP Onix Overture XM5 Housse de protection similicuir pour DAP Shanling M0 Pro
Monolith M1060 : Over-ear open back planar magnetic headphones 96dB 50 Ohm 10Hz - 50kHz
The Monolith M1060 headphones are the ideal listening solution to get the most out of your music. Featuring large 106mm Planar Magnetic drivers, the M1060 delivers a precise and rich sound reproduction, allowing you to capture every detail of your music. With a spectacular sound image, low distortion and perfectly balanced sound, the Monolith M1060 is a true audiophile headphone.
View complete product page of MONOLITH M1060 MONOLITH M1060
Products typeDAP + Protective case + Headphones
Package contents1x Shanling Onix Overture XM5
1x Protective Cover
1x MONOLITH M1060
ONIX OVERTURE XM5 Specifications
Product typeDigital Audio Player (DAP)
DAC ChipESS ES9039PRO
Amplification chips2x TPA6120
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
ConnectivityWifi
Bluetooth 5.2
Supported Bluetooth codecsLDAC, aptX HD, aptX, SBC, AAC
Wifi protocols supportedDLNA, Airplay, Online Tidal Streaming
Touch screenOLED 3" 720p
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Compatible file formatsDSD (iso, dsf, dff, DST not supported), ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DST, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS
Power outputBalanced outputs : 1069mW @ 32Ω
Single-end outputs : 310mW @ 32Ω
Signal-to-noise ratio (SNR)Balanced outputs : 121dB
Single-end outputs : 120dB
Total harmonic distortion (THD)Balanced outputs : 0.0006%
Single-end outputs : 0.0014%
Output impedanceBalanced outputs :6.6Ω
Single-end outputs : 4.7Ω
Channel separationBalanced outputs :100dB
Single-end outputs : 80dB
Dynamic rangeBalanced outputs : 121dB
StorageMicro SD slot (up to 2TB, not included)
Battery7000mAh
AutonomyBalanced outputs : 12 hours
Single-end outputs : 14 hours
Dimensions115 x 70 x 19mm
Weight275g
Housing materialAluminum
Package1x Shanling Onix Overture XM5
1x USB-A to USB-C cable
Protective case Specifications
Product typeProtective case for DAP
CompatibilityShanling Onix XM5
MaterialLeather
Package1x Leather protective case for DAP Onix Overture XM5
MONOLITH M1060 Specifications
Product typeHeadphone
Headphone typeOpen Back
Over-Ear
Drivers typePlanar Magnetic
Drivers diameterØ106mm
Magnets structureLinear symmetry
Magnets materialNeodymium
Max power handling10W (for 200ms)
Max SPL> 130dB
Frequency response10Hz - 50kHz
THD< 1% @ 1mW, 1kHz
Impedance50Ω
Efficiency96dB/1mW
Optimal power200mW - 4W
Cable length1.90m
Weight500g
Package1x Monolith M1060
1x Braided Jack 3.5mm cable
1x Jack 3.5mm to Jack 6.35mm adapter
1x Transport bag
We offer you a Shanling and Monolith product pack comprising the Onix Overture XM5 portable player, its protective case and the Monolith M1060...
