Pack Tonewinner AV Processor 13 Channels AD-7300HD + Power Amplifier 7 Channels AD-7300PA+
This Tonewinner pack includes the AD-7300HD audio/video processor and home theater preamplifier, plus the AD-7300PA+ power amplifier. The result is an extremely powerful, high-performance home theater system. What's more, both devices feature a unique design for aesthetic integration into your audio system.
By buying this product you get 299 loyalty points
Reference : 18259
2 990,00 €tax incl.
2 491,67 € tax excl.
Instead of 3 298,00 €
Pack content
Tonewinner AD-7300HD + AD-7300PA+ Pqck
AV Processor 13 Channels + Power Amplifier 7 Channels
Pack Tonewinner Processeur Audio-Vidéo 13 Canaux AD-7300HD + Amplificateur de Puissance 7 Canaux AD-7300PA+
Tonewinner AT-7300HD AV Processor / Preamplifier home theater
The Tonewinner AT-7300HD is a 13-channel audio/video processor and preamplifier, ideal for home theater integration in configurations up to 7.2.4. It supports all current audio formats, including Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-7300HD accepts video streams up to 4K UHD 60Hz and is compatible with HDR, HDR10 and Dolby Vision technologies. This means you can enjoy the latest and greatest formats available for the most immersive sound and visual experience possible.
FIND OUT MORE ABOUT THE TONEWINNER AD-7300HD
Tonewinner AD-7300HD Processeur Audio-Vidéo / Préamplificateur Home-Cinéma Dolby Atmos 13 Canaux 7.2.4
TONEWINNER AD-7300PA+ Amplificateur de Puissance Class AB 7 Canaux 7x500W 4 Oh
Tonewinner AD-7300PA+ 7-channel power amplifier
The Tonewinner AD-7300PA+ is a 7-channel Class AB power amplifier, ideal for home theater integration. Capable of developing significant power, measured at 584W RMS for one channel powered at 4Ω or 7x190W for 7 channels powered at 8Ω, this amplifier offers great dynamics and ensures low noise levels.
FIND OUT MORE ABOUT THE TONEWINNER AD-7300PA+
Product typeAV processor + power amplifier pack
Tonewinner AD-7300HD specifications
Home theater preamplifier
Channels7.2.4 (13 channels)
InputsBluetooth
6* HDMI 2.0
3* Stereo RCA
3* Stereo RCA (karaoke)
2* Coaxial
2* Optical Toslink
1* Micro SD slot
1* Mini USB (USB Audio)
1* USB-A (USB Host)
2* Microphone inputs (karaoke)
OutputsBluetooth
2* HDMI 2.0 (with 1 eARC)
RCA
XLR
Other connectors1* RS232
1* 5V trigger output
Connectors for measuring microphone
Supported audio formatsDolby Atmos
Dolby True HD
Dolby Digital Plus
Dolby Digital
Dolby Mat
DTS/X
DTS Master
DTS Hi-Res
DTS ES
DTS NEO6
Supported video formats / resolutions4K UHD 60Hz
3D
Dolby Vision
HDR10 / HDR10+
HLG
HDCP version2.2
eARC support
CEC support
Automatic EQ calibration
Input impedance20kOhm
Output impedance100 Ohm
Gain>= 13dB
THD<= 0.02% (A-wt, 1kHz)
SNR>= 98dB (A-wt)
Frequency response10Hz-50kHz (+1/-3dB)
Channel separation>= 80dB
Crosstalk>= 80dB
Supply voltage100-240VAC 50/60Hz
Dimensions440*330*130mm
Weight5.5kg
Tonewinner AD-7300PA+ specifications
Product typePower amplifier
Amplification typeClass AB
Channels7
Inputs7* Mono single-ended RCA
7* Mono balanced XLR
1* Trigger input
1* LINK input
Outputs7* Speaker terminals
Output power584W RMS @ 1 channel driver, 4Ω, 20Hz-20kHz, THD < 0.1%
307W RMS @ 2 channels driven, 8Ω, THD < 0.1%
500W RMS @ 2 channels driven, 4Ω, THD < 0.1%
190W RMS @ 7 channels driven, 8Ω, THD < 0.1%
SNR>= 100dB (A-wt)
THD<= 0.09% (1kHz)
THD+N< 0.006% @ 100W RMS, 1kHz, 8 Ohm
Frequency response20Hz-50kHz (+1/-3dB)
Rated impedance8 Ohm
Gain28dB
Damping factor> 149 @ 8 Ohm
Input sensitivity1.5V @ 8 Ohm
Supply voltage110-230VAC 50/60Hz
Dimensions440*445*197mm
Weight25kg
This Tonewinner pack includes the AD-7300HD audio/video processor and home theater preamplifier, plus the AD-7300PA+ power amplifier. The result is...
