Pack Tonewinner AV Processor 16 Channels AT-300 + Power Amplifier 5 Channels AD-5100PA+
This Tonewinner package includes the AT-300 audio/video processor and home theater preamplifier, plus the AD-5100PA+ power amplifier. The result is an extremely powerful, high-performance home-cinema system. What's more, both devices feature a unique design for aesthetic integration into your audio system.
By buying this product you get 159 loyalty points
Reference : 18261
1 590,00 €tax incl.
1 325,00 € tax excl.
Instead of 2 019,00 €
Shipping date: 22-04-2025.
Pack content
Tonewinner AT-300 + AD-5100PA+ Pack
AV Processor 16 Channels AT-300 + Power Amplifier 5 Channels AD-5100PA+Pack Tonewinner AV Processor 16 Channels AT-300 + Power Amplifier 5 Channels AD-5100PA+
Tonewinner AT-300 AV processor / home theater preamplifier
The Tonewinner AT-300 is a 16-channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio formats, including Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-300 accepts video streams up to 4K UHD 60Hz, and is compatible with HDR, HDR10 and Dolby Vision technologies. This means you can enjoy the latest and greatest formats available for the most immersive sound and visual experience possible.
FIND OUT MORE ABOUT THE TONEWINNER AT-300
Tonewinner AD-5100PA+ 7-channel power amplifier
The Tonewinner AD-5100PA+ is a Class AB power amplifier with 5 channels capable of delivering 130W into 4Ω or 90W into 8Ω each. This makes it ideal for integration into a home theater system. It uses 5 pairs of Toshiba TTC5200 and TTA1943 transistors, ensuring rich, musical sound reproduction. The low-noise differential amplification circuit provides a clear improvement in SNR and dynamics.
FIND OUT MORE ABOUT THE TONEWINNER AD-5100PA+
Product typeA/V processor + power amplifier
Tonewinner AT-300 specifications
Home theater preamplifier
Channels16 channels
InputsBluetooth
6* HDMI 2.0
4* Stereo RCA
2* Coaxial
2* Optical Tolsink
1* Slot Micro SD
1* Mini USB (USB Audio)
1* USB-A (USB Host)
OutputsBluetooth
2* HDMI 2.0 (with 1 eARC)
RCA 9.3.4 channels
XLR 9.1.4
Other connectors1* RS232
1* 5V trigger output
Supported audio formatsDolby Atmos
Dolby True HD
Dolby Digital Plus
DTS/X
DTS Master
DTS Hi-Res
DTS Upmix
DTX Neural:X
Supported video formats / resolutions4K UHD
3D
Dolby Vision
HDR10 / HDR10+
HLG
HDCP version2.2
eARC supportOn one output
CEC supportOn 5 inputs
Automatic EQ calibration
Lip syncUp to 1000ms
DRC feature
Input impedance20kOhm
Output impedance1kOhm
Gain>= 14dB
THD<= 0.02% (1kHz)
SNR>= 98dB (A-wt)
Frequency response10Hz-50kHz (+1/-3dB)
Channel separation>= 80dB
Crosstalk>= 80dB
Supply voltage100-240VAC 50/60Hz
Dimensions431*326*100mm
Weight4.4kg
Tonewinner AD-5100PA+ Specifications
Product typePower amplifier
Amplification typeClass AB
Channels5
Inputs5* RCA
OutputsSpeaker terminals
Output power5x130W @ 4 Ohm
5x90W @ 8 Ohm
Impedance8 Ohm
Channel separation>= 70dB
THD<= 0.1%
SNR>= 100dB (A-wt)
Frequency response20Hz-30kHz (+1/-3dB)
Supply voltage115-230VAC 50/60Hz
Dimensions431*352*130mm
Weight9.6kg
This Tonewinner package includes the AT-300 audio/video processor and home theater preamplifier, plus the AD-5100PA+ power amplifier. The result is...
