Pack Topping D50 III DAC + A50 III Headphone Amplifier + TCT1 Jack 6.35mm TRS 25cm Cables Black
This Topping pack includes the D50 III DAC, the A50 III headphone amplifier and preamplifier, and TCT1 6.35mm TRS jack cables for balanced interconnection. This package will enable you to enjoy high-quality headphone listening, while offering the possibility of integration within a more complete audio system.
By buying this product you get 45 loyalty points
Reference : 19077
454,00 €tax incl.
378,33 € tax excl.
Instead of 477,91 €
Pack content
Pack Topping D50 III + A50 III + TCT1 - Black DAC 2x ES9039Q2M + NFCA Headphone amplifier + Jack 6.35mm TRS cables
Pack Topping DAC D50 III + Headphone amplifier A50 III + Jack 6.35mm TCT1 cables
Topping A50 III Headphone amplifier / Preamplifier
Topping A50 III headphone amplifier
With its A50 III headphone amplifier, Topping unveils a compact, high-performance device. It retains the features of its predecessor, with improvements such as a 3-level gain control and a balanced input on a 6.35mm TRS jack. Its amplifier circuit incorporates an NCFA (Nested Feedback Composite Amplifier) module for exceptional performance. What's more, the A50 III has a maximum output power of 2x 3500mW, a comfortable reserve that enables it to drive many of the headphones available on the market, including models requiring up to 300 ohms impedance without difficulty.
FIND OUT MORE ABOUT TOPPING A50 III
Topping D50 III DAC
Topping's D50 III desktop DAC offers a number of upgrades to improve performance over its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB interface, enabling it to support high-resolution streams up to PCM 32bit 768kHz and DSD512. It also features a latest-generation Qualcomm QCC5125 Bluetooth chip for superior wireless reception.
Topping has chosen to offer the possibility of operating its D500 II as a DAC but also as a preamplifier with volume control, by connecting it to active speakers or a power amplifier. In addition, the D50 III offers numerous digital inputs: coaxial, optical and USB-C. Outputs can be balanced via 6.35mm TRS jack or unbalanced via RCA.
FIND OUT MORE ABOUT TOPPING D50 III
Topping D50 III DAC
Jack 6.35mm TRS Topping TCT1 cables
Topping TCT1 Jack 6.35mm TRS 25cm cable
Topping's TCT1 cables are high-quality 6.35mm jack cables. They feature 6N copper and 6N silver-plated copper conductors for perfect signal transmission. Each conductor has a cross-section of 0.533mm² (19AWG). Connector contacts are gold-plated for excellent conductivity and resistance to oxidation. Each cable is covered by a robust black and red braided nylon sheath.
Find out more about Topping TCT1
Topping A50 III specifications
Preamplifier
Inputs1x Single-ended stereo RCA
1x Balanced dual Jack 6.35mm TRS
Outputs1x Single-ended 6.35mm jack headphone output
1x Balanced 4.4mm jack headphone output
Trigger 12VYes
Full specifications on the A50 III page
Topping D50 III specifications
Product typeDAC
DAC chips2x ES9039Q2M
USB interfaceXMOS XU316
Bluetooth 5.1 chipQualcomm QCC5125
Inputs1x USB-C
1x Coaxial
1x Optical Toslink
Bluetooth
1x Balanced dual  Jack 6.35mm TRS symétrique
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
EQYes
Trigger 12VYes
Remote controlYes
Full specifications on the D50 III page
Topping TCT1 specifications
Product typeBalanced Jack 6.35mm TRS cables
ConnectorsMale Jack 6.35mm TRS
Length25cm
Cable outer diameterØ8mm
Conductors materialCopper
Silver plated copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Outer sheathBraided nylon
Sheath colorBlack and red
This Topping pack includes the D50 III DAC, the A50 III headphone amplifier and preamplifier, and TCT1 6.35mm TRS jack cables for balanced...
