Pack Topping A50s Headphone Amplifier + D50s DAC + P50 Power Supply + TCR2 RCA Cable 25cm Silver
With this complete Topping pack, you have a turnkey solution to quickly and easily integrate an excellent audio system oriented towards high quality headphone listening. It consists of the D50s DAC, the A50s headphone amplifier, the P50 regulated linear power supply and the TCR2 RCA cables, all designed and optimized to work together.
By buying this product you get 61 loyalty points
Reference : 17675
615,00 €tax incl.
512,50 € tax excl.
Instead of 636,01 €
Pack content
Pack Topping A50s + D50s + P50 + TCR2
Headphone amplifier + DAC + Regulated linear power supply + RCA Cables Silver
Pack Topping Amplificateur Casque A50s + DAC D50s + Alimentation P50 + Câbles RCA TCR2 25cm Silver<span id=
With this complete Topping pack, you have a turnkey solution to quickly and easily integrate an excellent audio system oriented towards high quality headphone listening. It consists of the D50s DAC, the A50s headphone amplifier, the P50 regulated linear power supply and the TCR2 RCA cables, all designed and optimized to work together. Moreover, the A50s also plays the role of a preamplifier, so it can be associated with an amplifier (not supplied) to set up a classic HiFi system.
All the devices offered here have the same design and identical form factor for a clean and aesthetic installation.
Topping A50s Headphone amplifier
Topping unveils with the A50s a high quality headphone amplifier and preamplifier duo, integrating both balanced and single-ended connections. Its optimized circuits based on very good audio components allow a precise, detailed and musical sound reproduction. The A50s is also versatile. It is thus capable of adapting to the vast majority of headphones on the market, including the most demanding models.
Key features:
  • NFCA Amplifier
  • Balanced Jack 4.4mm output
  • Adjustable gain
  • THD+N: < 0.00007%
  • Dynamic range: 144dB
  • Noise: < 0.3µVrms
  • Output impedance: < 0.1Ω
  • Max output power: 2x 3500mW
VIEW MORE INFORMATION ON TOPPING A50S
Topping D50s DAC
The Topping D50s is the direct evolution of the D50, a DAC that has proven itself and is particularly appreciated by many audiophiles and music lovers. If this new model is largely based on the design and architecture of its predecessor, its main evolution is in its connectivity, now integrating a Bluetooth receiver. The device can now also be controlled with a supplied remote control and its audio performance has been upgraded.
For the rest, we find all the advanced components of the previous version such as two ESS ES9038Q2M digital/analog conversion chips, a last generation XMOS U208 USB interface module or OP1612 operational amplifiers, all integrated in a beautiful and robust aluminum case.
Key features:
  • Dual ES9038Q2M DAC
  • XMOS XU208 USB interface, custom Thesycon driver
  • Bluetooth 5.0 receiver with aptX, aptX HD and LDAC codecs supports
  • Sample rates support up to PCM 32bit 768kHz and DSD512
  • 7 PCM filters
  • THD+N: 0.0003%
  • IR Remote control
View more information on Topping D50s
Topping P50 Regulated linear power supply
The Topping P50 regulated linear power supply offers excellent performances and allows to supply cleanly a HiFi system and so to favour the quality of sound restitution of the latter. Particularly practical, the P50 has 2 USB-A outputs of 5V 1A and 1 DC 5.5/2.1mm jack output of 15V 1A. It is thus possible to supply several devices with a single power supply.
Key feaures:
  • Regulated linear power supply
  • Ultra-low noise level
  • Output voltage: 2x5V 1A + 15V 1A
  • Adjustable input voltage: AC220-240V or AC100-120V
  • Large filtering capacity
Voir plus d'informations sur le Topping P50
The P50 can provide its own power supply to other audio devices. However, when this power supply is used, the maximum balanced output power drops to 2x 2.4W. The other output power values do not change.
Topping TCR2 RCA cable
TCR2 RCA cables benefit from a very nice design quality with silver plated OFC copper conductors, ensuring excellent electrical conductivity and therefore signal transmission. The connectors are gold plated, material resistant to oxidation for a more durable cable.
Key features:
  • Length: 25cm
  • Silver plated OFC copper conductors
  • Gold plated connectors
View more informations on Topping TCR2
Topping A50s Specifications
Preamplifier
Input1* Stereo RCA
Outputs1* Single-ended Jack 6.35mm headphone output
1* Balanced Jack 4.4mm headphone output
1* Stereo RCA pre-out
THD+NSingle-ended headphone output: < 0.00007% @ 850mW, 32Ω, 1kHz, A-Weighted / < 0.00006% @ 90mW, 300Ω, 1kHz, A-Weighted
Balanced headphone output: < 0.00007% @ 3.4W, 32Ω, 1kHz, A-Weighting / < 0.00006% @ 367mW, 300Ω, 1kHz, A-Weighted
THDSingle-ended headphone output: < 0.0004% @ 720mW, 32Ω, 20Hz-20kHz, 90kBW / < 0.0002% @ 77mW, 300Ω, 20Hz-20kHz, 90kBW
Balanced headphone output: < 0.001% @ 2.88W, 32Ω, 20Hz-20kHz, 90kBW / < 0.0005% @ 307mW, 300Ω, 20Hz-20kHz, 90kBW
SNRSingle-ended headphone output: 137dB @ Max out, 1kHz, A-Weighted
Balanced headphone output: 143dB @ Max out, 1kHz, A-Weighted
Dynamic rangeSingle-ended headphone output: 138dB @ 1kHz, A-Weighted
Balanced headphone output: 144dB @ 1kHz, A-Weighted
Frequency response20Hz - 200kHz (±0.05dB)
Output levelSingle-ended headphone output: 21Vpp
Balanced headphone output: 42Vpp
Noise levelSingle-ended headphone output: < 0.3µVrms @ G=L, A-Weighted / < 0.45µVrms @ G=H, A-Weighted
Balanced headphone output: < 0.6µVrms @ G=L, A-Weighted / < 0.95µVrms @ G=H, A-Weighted
CrosstalkSingle-ended headphone output: -86dB @ 1kHz
Balanced headphone output: -128dB @ 1kHz
IMD CCIF-116dB @ 18kHz + 19kHz
IMD SMPTE-110dB, SMPTE4:1 @ 60Hz + 7kHz
-118dB, SMPTE1:1 @ 60Hz + 7kHz
Input sensitivity7.5Vrms G=0dB
3.8Vrms @ G=6dB
GainSingle-ended headphone output: 0dB @ G=0dB / 6dB @ G=6dB
Balanced headphone output: 6dB @ G=0dB / 12dB @ G=6dB
Output impedanceSingle-ended headphone output: < 0.1Ω
Balanced headphone output: 0.2Ω
Output level @ THD+N < 1%Single-ended headphone output: 2x 1.4W @ 32Ω / 2x 192mW @ 300Ω
Balanced headphone output: 2x 3.5W @ 32Ω / 2x 760mW @ 300Ω
Output power @ 2Vrms INSingle-ended headphone output: 2x 485mW @ 32Ω / 2x 52mW @ 300Ω
Balanced headphone output: 2x 1950mW @ 32Ω / 2x 208mW @ 300Ω
Load impedance> 8Ω
Supply voltage15VDC
Housing materialAluminum
Dimensions110*123*26mm
ColorSilver
Topping D50s Specifications
Product typeDAC
Inputs1* USB-B
1* Optical Toslink
1* Coaxial SPDIF
Bluetooth 5.0
Output1* Stereo RCA
Supported sampling ratesUSB: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP64
Bluetooth version5.0
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
THD+N @ A-Weighting< 0.0003% @ 1kHz
< 0.0004% @ 10Hz-20kHz
SNR @ A-Weighting> 122dB @ 1kHz
Frequency response20Hz-20kHz (±0.1dB)
Output level2Vrms @ 0dBFS
Noise< 2µVrms
Crosstalk-130dB @ 1kHz
Supply voltage5V DC 1A
Dimensions110*119*26mm
Housing materialCNC machined aluminum
Weight510g
ColorSilver
Topping P50 Specifications
Product typeRegulated linear power supply
Input voltage110-220VAC 50/60Hz
Input connectorIEC C14
Output voltages2* 5VDC 1A
15VDC 1A
Output connectors2* USB-A
1* Jack DC 5.5/2.1mm
Noise< 1mVrms
Dimensions110*110*52mm
Weight880g
ColorSilver
Topping TCR2 Cables specifications
Product typeMale/Male RCA cables
Length25cm
Conductors materialOFC Copper
Conductors platingSilver
Total section2* 0.533mm²
Conductors resistance26.9Ω/km
Outer diameterØ8mm
Connectors materialCopper
Connectors platingGold
ColorBlack and red
With this complete Topping pack, you have a turnkey solution to quickly and easily integrate an excellent audio system oriented towards high...
