Pack Topping A90 Discrete Headphone Amplifier + D90SE DAC + TCX1 XLR Cables 25cm Black
This Topping pack, consisting of the A90 Discrete headphone amplifier, the D90SE DAC and the TCX1 XLR cables. A perfect combo to enjoy a headphone listening solution of exceptional quality, ensuring notably a level of distortion and extremely low noise. The result is a sound reproduction of sublime richness, precision and musicality. The set is thought, both in its technical conception but also by its design, for a complementary use.
By buying this product you get 146 loyalty points
Reference : 17680
1 469,00 €tax incl.
1 224,17 € tax excl.
Pack content
Pack Topping A90 Discrete + D90SE + TCX1
Headphone amplifier + DAC + XLR cables black
Pack Topping Amplificateur Casque A90 Discrete + DAC D90SE + Câbles XLR TCX1 25cm Noir
This Topping pack, consisting of the A90 Discrete headphone amplifier, the D90SE DAC and the TCX1 XLR cables. A perfect combo to enjoy a headphone listening solution of exceptional quality, ensuring notably a level of distortion and extremely low noise. The result is a sound reproduction of sublime richness, precision and musicality. The set is thought, both in its technical conception but also by its design, for a complementary use. The D90SE can also be used as a preamplifier in a home HiFi system, thanks to its RCA and XLR outputs.
Topping A90 Discrete headphone amplifier
The Topping A90 Discrete, an improvement of the previous A90, is now equipped with discrete components. Both a headphone amplifier and a preamplifier, it features a discrete NFCA amplifier stage capable of supporting the vast majority of headphones on the market. Its careful design using numerous high-end components allows it to deliver a rich, clear and transparent sound.
Key features:
  • Headphone amplifier / preamplifier
  • Discrete NFCA modules
  • Balanced XLR 4 pins / Balanced Jack 4.4mm / Single-ended Jack 6.35mm headphone output
  • High precision relay volume control
  • 2 gain level
  • THD+N: 0.000055%
  • Dynamic range: 145dB
  • Output power: 2x 9800mW
View more informations on Topping A90 Discrete
Topping D90SE DAC
The Topping D90SE is a high-end DAC, benefiting from an intelligent and careful design for high performance. It features an ESS ES9038Pro conversion chip, a USB XMOS interface and an Altera MAX II CPLD. The D90SE is also versatile with a complete connectivity and an integrated Bluetooth receiver.
Key features:
  • ES9038Pro DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.0 receiver with aptX, aptX HD and LDAC codecs support
  • Support sample rates up to PCM 32bit 768kHz and DSD512
  • MQA files support
  • THD+N: 0.00005%
  • Balanced and single-ended outputs
  • IR remotre control
View more informations on Topping D90SE
Topping TCX1 XLR cables
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
  • Length: 25cm
  • 6N copper and silver plated 6N copper
  • Gold plated connectors
View more informations on Topping TCX1
Topping A90 Discrete specifications
Preamplifier
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
Outputs1* Single-ended Jack 6.35mm headphone output
1* Balanced Jack 4.4mm headphone output
1* Balanced 4 pins XLR headphone output
1* Single-ended stereo RCA pre-out
1* Balanced stereo XLR pre-out
Supply voltage100-240VAC 50/60Hz
Dimensions222*160*45mm
Topping D90SE specifications
Product typeDAC
Inputs1* USB-B
1* AES/EBU
1* Coaxial
1* Optical Toslink
1* I2S LVDS via HDMI
Bluetooth 5.0
Outputs1* Stereo RCA
1* Stereo XLR
DAC chipESS ES9038Pro
USB interfaceXMOS XU216
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Topping TCX1 specifications
Product typeMale/female XLR cables
Length25cm
Conductors material6N copper
Silver plated 6N copper
Conductors section0.533mm² (19AWG)
Cable outer diameterØ8mm
Connectors contacts platingGold
Outer sheathBraided nylon
Cable colorBlack and red
This Topping pack, consisting of the A90 Discrete headphone amplifier, the D90SE DAC and the TCX1 XLR cables. A perfect combo to enjoy a headphone...
