Pack Topping D90 III + A90 Discrete + TCX1 25cm Black
We offer you a black product pack from Topping comprising the D90 III balanced DAC, the A90 Discrete headphone amplifier/preamplifier and TCX1 cables (25cm). This pack offers excellent sound performance. This combo is perfect for audiophile headphone listening, or for completing a Hi-Fi installation with a power amplifier and passive speakers.
By buying this product you get 144 loyalty points
Reference : 19374
1 449,00 €tax incl.
1 207,50 € tax excl.
Instead of 1 547,01 €
Pack content
Pack Topping D90 III DAC + A90 Discrete Headphone Amplifier / Preamplifier + TCX1 25cm XLR Cables Black
We offer you a product pack from Topping comprising the D90 III balanced DAC, the A90 Discrete headphone amplifier/preamplifier and TCX1 XLR cables (25cm). This pack offers excellent sound performance. This combo is perfect for audiophile headphone listening, or for completing a Hi-Fi installation with a power amplifier and passive speakers.
Topping D90 III balanced DAC
Topping's D90 III balanced DAC features one ES9039SPro DAC chip per channel for fully balanced signal processing. It also features an XMOS XU-316 USB interface and an Altera Max CPLD for exceptional performance. The D90 III supports high-definition sampling rates up to PCM 32 bit 768kHz, native DSD up to DSD512 and MQA streams. Numerous digital inputs and Bluetooth 5.1 functionality make it easy to integrate into any Hi-Fi system.
View complete product page of Topping D90 III Topping D90 III DAC
Topping A90 Discrete headphone amplifier/preamplifier
The A90 Discrete from Toppping is, as its name suggests, a headphone amplifier/preamplifier equipped with discrete components. Its NFCA amplifier stage can drive most headphones on the market, even the most demanding. Its balanced structure ensures consistent output power. In addition to its three headphone outputs (balanced 4.4mm jack, balanced XLR and 6.35mm jack), it has two line outputs for use as a preamplifier. This Topping device offers top-level performance.
View complete product page of Topping A90 Discrete Topping A90 Discrete headphone amplifier/preamplifier
Topping TCX1 XLR interconnect cables
The Topping TCX1 pair of modulation cables features a high-end structure with 6N copper conductors and silver plating for enhanced conductivity. The XLR connectors are gold-plated for corrosion and oxidation resistance. Red and black rings allow quick identification of each channel.
View complete product page of Topping TCX1 TCX1 XLR cables
Product typePack DAC + Headphone amplifier/preamplifier + XLR modulation cable
Package content1x Topping D90 III
1x A90 Discrete
1x Pair of XLR TCX1 interconnect cables
D90 III SPECIFICATIONS
Product typeBalanced DAC
DAC chip2x ES9039SPRO
USB interfaceXMOS XU-316
Inputs1x USB-B
1x AES/EBU
1x SPDIF Coaxial
1x Optical Toslink
1x I2S via HDMI
Bluetooth 5.1
Outputs1x Single-ended RCA stereo
1x Balanced XLR stereo
Supported sample ratesPCM 32bit 768kHz
DSD512
MQA
Supported Bluetooth codecsSBC, ACC, aptX, aptX HD, aptx Adaptative, LDAC
Trigger
DAC + preamplifier function
RCA LINE OUTPUT MEASUREMENTS (USB IN @96KHZ)
THD+N @ A-Weighted< 0.00006% @ 1kHz
THD @ No-Weighted, 90kBw< 0.0003% @20Hz-20kHz
SNR @ A-Weighted129dB @ 1kHz
Dynamic range @ A-Weighted129dB @ 1kHz
Frequency response20Hz - 20kHz (+/- 0.1dB)
20Hz - 40kHz (+/- 0.3dB)
Output level2.1Vrms @0dBFS (mode 4V)
2.6Vrms @0dBFS (mode 5V)
Noise @ A-Weighted< 1.1uVrms
Channel crosstalk-133dB @ 1kHz
Channel balance0.3dB
Output impedance50 Ohm
XLR LINE OUTPUT MEASUREMENTS (USB IN @96KHZ)
THD+N @ A-Weighted< 0.000045% @ 1kHz
THD @ No-Weighted, 90kBw< 0.0001% @20Hz-20kHz
SNR @ A-Weighted135dB @ 1kHz
Dynamic range @ A-Weighted135dB @ 1kHz
Output level4.2Vrms @0dBFS (mode 4V)
5.2Vrms @0dBFS (mode 5V)
Channnel separation-149dB @ 1kHz
Output impedance100 Ohm
Dimensions222 x 160 x 45mm
Package1x Topping D90 III Sabre Black
1x Bluetooth remote control
1x USB cable
1x Bluetooth antenna
1x Power cable
A90 DISCRETE specifications and measurements
Preamplifier
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo XLR
1x Balanced Jack 4.4mm headphone output
1xBalanced XLR 4 pins headphone output
1x Single-ended Jack 6.35mm headphone output
Discrete headphone amplifier performance
SE Input/ SE OutputBAL Input / SE OutputSE Input / BAL OutputBAL Input / BAL Output
THD+N @ 1kHz (A-Weighting)< 0.000065% @ 500mW, 32Ω< 0.00008% @ 500mW, 32Ω< 0.000065% @ 2000mW, 32Ω< 0.00008% @ 2000mW, 32Ω
< 0.000055% @ 80mW, 300Ω< 0.00006% @ 80mW, 300Ω< 0.000055% @ 320mW, 300Ω< 0.00006% @ 500mW, 300Ω
THD+N @ 20Hz-20kHz (90kBW)< 0.0003% @ 500mW, 32Ω< 0.0003% @ 500mW, 32Ω< 0.0006% @ 2000mW, 32Ω< 0.0006% @ 2000mW, 32Ω
< 0.00025% @ 80mW, 300Ω< 0.00025% @ 80mW, 300Ω< 0.00025% @ 320mW, 300Ω< 0.00025% @ 320mW, 300Ω
SNR @ Max Out, 1kHz (A-Weighting)141dB137dB145dB138dB
Dynamic range @ 1kHz (A-Weighting)141dB137dB145dB138dB
Frequency response20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)
Output level25Vpp25Vpp49Vpp49Vpp
Measured noise level @ A-Weighting< 0.7µVrms @ G=L< 0.7µVrms @ G=L< 1µVrms @ G=L< 1µVrms @ G=L
< 1.1µVrms @ G=H< 1.1µVrms @ G=H< 1.8µVrms @ G=H< 1.8µVrms @ G=H
Actual noise level @ A-Weighting< 0.2µVrms @ G=L< 0.2µVrms @ G=L< 0.7µVrms @ G=L< 0.7µVrms @ G=L
< 0.6µVrms @ G=H< 0.6µVrms @ G=H< 1.6µVrms @ G=H< 1.6µVrms @ G=H
Channel crosstalk @ 1kHz-107dB-105dB-116dB-113dB
Input sensitivity9.1Vrms @ G=L9.3Vrms % @ G=L9.1Vrms % @ G=L9.3Vrms % @ G=L
3Vrms @ G=H3Vrms @ G=H3Vrms @ G=H3Vrms @ G=H
Gain0db @ G=L-0.2dB @ G=L6dB @ G=L5.8dB @ G=L
9.5dB @ G=H9.3dB @ G=H15.5dB @ G=H15.3dB @ G=H
Output power< 0.1Ω< 0.1Ω< 0.2Ω< 0.2Ω
Output impedance2x 3300mW @ 16Ω, THD+N < 0.1%
2x 2000mW @ 32Ω, THD+N < 0.1%
2x 1100mW @ 64Ω, THD+N < 0.1%
2x 250mW @ 300Ω, THD+N < 0.1%
2x 9800mW @ 16Ω, THD+N < 0.1%
2x 6700mW @ 32Ω, THD+N < 0.1%
2x 4000mW @ 64Ω, THD+N < 0.1%
2x 1000mW @ 300Ω, THD+N < 0.1%
2x 500mW @ 600Ω, THD+N < 0.1%
Load impedance> 8Ω
Discrete preamplifier performances
SE Input / SE OutputBAL Input / SE OutputSE Input / BAL OutputBAL Input / BAL Output
THD+N @ 1kHz (A-Weighting)< 0.000055%< 0.00006%< 0.000055%< 0.00006%
THD+N @ 20Hz-20kHz (90kBW)< 0.00025%< 0.00025%< 0.00025%< 0.00025%
SNR @ 1kHz (A-Weighting)141dB137dB145dB138dB
Dynamic range@ 1kHz (A-Weighting)141dB137dB145dB138dB
Load impedance20Ω20Ω20Ω20Ω
Supply voltage100-240VAC 50/60Hz
Package1x Topping A90 Discrete
1x Remote control
1x Powre cable
1x Male Jack 6.35mm to female Jack 3.5mm adapter
TCX1 cable specifications
Product typeXLR Cables
Connectors1x Male XLR 3 poles
1x Female XLR 3 poles
Length25cm
Cable overall diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Covering sheathBraided Nylon
ColorBlack and red
QuantitySold by pair (1 cable with red rings, 1 cable with black rings)
We offer you a black product pack from Topping comprising the D90 III balanced DAC, the A90 Discrete headphone amplifier/preamplifier and TCX1...
