Pack Topping D90 III Discrete DAC + A90 Discrete Headphone Amplifier Preamplifier + TCX1 25cm Cables Silver
We offer you a Topping product pack comprising the TOPPING D90 III Discrete DAC, a Topping A90 Discrete preamplifier headphone amplifier and a pair of Topping TCX1 XLR modulation cables (25cm). This pack lets you enjoy the most pleasant headphone listening experience with excellent performance.
By buying this product you get 149 loyalty points
Reference : 19828
1 499,00 €tax incl.
1 249,17 € tax excl.
Instead of 1 647,01 €
Pack content
Pack Topping Topping D90 III Discrete DAC + A90 Discrete Headphone Amplifier Preamplifier + TCX1 25cm Cables Silver
Photo du pack Topping
We offer you a Topping product pack comprising the Topping D90 III Discrete DAC, a Topping A90 Discrete preamplifier / headphone amplifier and a pair of Topping TCX1 XLR modulation cables (25cm). This pack lets you enjoy the most pleasant headphone listening experience with excellent performance.
Topping D90 III Discrete: Balanced Discrete DAC Bluetooth 5.1 32bit 768kHz DSD512 Silver
The D90 III Discrete balanced DAC from Topping is the parallel to the D90III using a 100% discrete digital/analogue conversion module. Here, conversion is performed by a PSRM module per channel, enabling conversion up to PCM 32bit 768kHz and DSD 512. This DAC also incorporates a Qualcomm QCC5125 Bluetooth 5.1 chip and a 12V trigger input and output on the rear panel. The high-end components found in the previous version, such as the Altera Max CPLD, are also included.
View complete product page of  Topping D90 III Discrete Topping D90 III Discrete
Topping A90 Discrete: Discrete Balanced Headphone Amplifier Preamplifier Silver
Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it incorporates a discrete NFCA amplifier stage capable of supporting most headphones on the market. Its careful design using many high-end components allows it to deliver a rich, clear and transparent sound.
View complete product page of Topping A90 DISCRETE Topping A90 DISCRETE
Topping TCX1: XLR Interconnect Cables 25cm (Pair)
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable has a beautiful and robust black and red braided nylon sheath.
View complete product page of TOPPING TCX1 TOPPING TCX1
Product typeDAC + Headphone amplifier / preamplifier+ XLR cables
Package content1x Topping D90 Discrete
1x Topping A90 Discrete
1x Topping TCX1 25cm
Topping D90 III Specifications
Product typeBalanced DAC
DACPSRM module
USB interfaceXMOS XU-316
Inputs1x USB-B
1x AES/EBU
1x Coaxial
1x Optical Toslink
1x I2S via HDMI
Bluetooth 5.1
Outputs1x Single-ended RCA stereo
1x Balanced XLR stereo
Supported sample ratesPCM 32bit 768kHz
DSD512
Supported Bluetooth codecsSBC, ACC, aptX, aptX HD, aptx Adaptative, LDAC
Trigger12V
RCA LINE OUTPUT MEASUREMENTS (USB IN @96KHZ)
THD+N @ A-Weighted< 0.00007% @ 1kHz
THD @ No-Weighted, 90kBw< 0.0004% @ 20Hz-20kHz
SNR @ A-Weighted127dB @ 1kHz
Dynamic range @ A-Weighted126dB @ 1kHz
Frequency response20Hz - 20kHz (± 0.5dB)
20Hz - 40kHz (± 1.8dB)
Output level2.1Vrms @0dBFS (mode 4V)
2.6Vrms @0dBFS (mode 5V)
Noise @ A-Weighted< 1.5uVrms
Channel crosstalk-122dB @ 1kHz
Channel balance0.3dB
Output impedance50Ω
XLR LINE OUTPUT MEASUREMENTS (USB IN @96KHZ)
THD+N @ A-Weighted< 0.00006% @ 1kHz
THD @ No-Weighted, 90kBw< 0.0002% @ 20Hz-20kHz
SNR @ A-Weighted131dB @ 1kHz
Dynamic range @ A-Weighted130dB @ 1kHz
Output level4.2Vrms @0dBFS (mode 4V)
5.2Vrms @0dBFS (mode 5V)
Noise @ A-Weighted< 1.8uVrms
Channnel separation-143dB @ 1kHz
Output impedance150Ω
Dimensions220 x 160 x 45mm
ColorSilver
Package1x Topping D90 III Discrete
1x Remote control
1x USB cable
1x Bluetooth antenna
1x Power cable
Topping A90 Discrete Specifications
Preamplifier
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo XLR
1x Balanced Jack 4.4mm headphone output
1xBalanced XLR 4 pins headphone output
1x Single-ended Jack 6.35mm headphone output
Discrete headphone amplifier performance
SE Input/ SE OutputBAL Input / SE OutputSE Input / BAL OutputBAL Input / BAL Output
THD+N @ 1kHz (A-Weighting)< 0.000065% @ 500mW, 32Ω< 0.00008% @ 500mW, 32Ω< 0.000065% @ 2000mW, 32Ω< 0.00008% @ 2000mW, 32Ω
< 0.000055% @ 80mW, 300Ω< 0.00006% @ 80mW, 300Ω< 0.000055% @ 320mW, 300Ω< 0.00006% @ 500mW, 300Ω
THD+N @ 20Hz-20kHz (90kBW)< 0.0003% @ 500mW, 32Ω< 0.0003% @ 500mW, 32Ω< 0.0006% @ 2000mW, 32Ω< 0.0006% @ 2000mW, 32Ω
< 0.00025% @ 80mW, 300Ω< 0.00025% @ 80mW, 300Ω< 0.00025% @ 320mW, 300Ω< 0.00025% @ 320mW, 300Ω
SNR @ Max Out, 1kHz (A-Weighting)141dB137dB145dB138dB
Dynamic range @ 1kHz (A-Weighting)141dB137dB145dB138dB
Frequency response20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)
Output level25Vpp25Vpp49Vpp49Vpp
Measured noise level @ A-Weighting< 0.7µVrms @ G=L< 0.7µVrms @ G=L< 1µVrms @ G=L< 1µVrms @ G=L
< 1.1µVrms @ G=H< 1.1µVrms @ G=H< 1.8µVrms @ G=H< 1.8µVrms @ G=H
Actual noise level @ A-Weighting< 0.2µVrms @ G=L< 0.2µVrms @ G=L< 0.7µVrms @ G=L< 0.7µVrms @ G=L
< 0.6µVrms @ G=H< 0.6µVrms @ G=H< 1.6µVrms @ G=H< 1.6µVrms @ G=H
Channel crosstalk @ 1kHz-107dB-105dB-116dB-113dB
Input sensitivity9.1Vrms @ G=L9.3Vrms % @ G=L9.1Vrms % @ G=L9.3Vrms % @ G=L
3Vrms @ G=H3Vrms @ G=H3Vrms @ G=H3Vrms @ G=H
Gain0db @ G=L-0.2dB @ G=L6dB @ G=L5.8dB @ G=L
9.5dB @ G=H9.3dB @ G=H15.5dB @ G=H15.3dB @ G=H
Output power< 0.1Ω< 0.1Ω< 0.2Ω< 0.2Ω
Output impedance2x 3300mW @ 16Ω, THD+N < 0.1%
2x 2000mW @ 32Ω, THD+N < 0.1%
2x 1100mW @ 64Ω, THD+N < 0.1%
2x 250mW @ 300Ω, THD+N < 0.1%
2x 9800mW @ 16Ω, THD+N < 0.1%
2x 6700mW @ 32Ω, THD+N < 0.1%
2x 4000mW @ 64Ω, THD+N < 0.1%
2x 1000mW @ 300Ω, THD+N < 0.1%
2x 500mW @ 600Ω, THD+N < 0.1%
Load impedance> 8Ω
Discrete preamplifier performances
SE Input / SE OutputBAL Input / SE OutputSE Input / BAL OutputBAL Input / BAL Output
THD+N @ 1kHz (A-Weighting)< 0.000055%< 0.00006%< 0.000055%< 0.00006%
THD+N @ 20Hz-20kHz (90kBW)< 0.00025%< 0.00025%< 0.00025%< 0.00025%
SNR @ 1kHz (A-Weighting)141dB137dB145dB138dB
Dynamic range@ 1kHz (A-Weighting)141dB137dB145dB138dB
Load impedance20Ω20Ω20Ω20Ω
Supply voltage100-240VAC 50/60Hz
Dimensions222 x 160 x 45mm
ColorSilver
Package1x Topping A90 Discrete
1x Remote control
1x Powre cable
1x Male Jack 6.35mm to female Jack 3.5mm adapter
Topping TCX1 XLR Specifications
Product typeXLR Cables
Connectors1x Male XLR 3 poles
1x Female XLR 3 poles
Length25cm
Cable overall diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Covering sheathBraided Nylon
ColorBlack and red
QuantitySold by pair (1 cable with red rings, 1 cable with black rings)
We offer you a Topping product pack comprising the TOPPING D90 III Discrete DAC, a Topping A90 Discrete preamplifier headphone amplifier and a pair...
