Pack Topping DX3 Pro+ DAC + PA3s Amplifier + TCR2 RCA Cables 25cm Silver
Composed of the DX3 Pro+ DAC, the PA3S amplifier and the TCR2 RCA cables from Topping, this pack represents an ideal solution to have a powerful and affordable HiFi system, capable of a precise and musical sound reproduction. It also offers a great versatility with a complete input connector on the DAC while being able to support high resolution audio streams. The amplifier, for its part, provides a nice power reserve, more than enough for a home audio system.
By buying this product you get 37 loyalty points
Reference : 17686
379,00 €tax incl.
315,83 € tax excl.
Instead of 387,01 €
Pack content
Pack Topping DX3 Pro+ + PA3s + TCR2
DAC + Amplifier + RCA Cables Silver
Pack Topping DAC DX3 Pro+ + Amplificateur PA3s + Câbles RCA TCR2 25cm Argent
Direct evolution of the DX3 Pro, the DX3 Pro+ from Topping is an excellent compact DAC, also offering headphone amplification and preamplification functions. Embedding an ESS ES9038Q2M digital/analog conversion chip and a XMOS XU208 USB interface, it ensures a particularly precise and lively sound reproduction. It also benefits from a Bluetooth receiver, practical to broadcast its music remotely from a smartphone for example.
Key features:
  • ESS ES9038Q2M DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.0 receiver with aptX, aptX LL, aptX LL and LDAC codecs support
  • Support sample rates up to PCM 32bit 768kHz and DSD512
  • XMOS XU208 USB interface
  • THD+N: 0.00015%
  • Integrated NFCA headphone amplifier
  • IR remote control
View more informations on Topping DX3 Pro+
Topping PA3s amplifier
Topping offers with its PA3s a small balanced Class D amplifier, simple, powerful and affordable. It is based on two Infineon MA12070 amplification chips allowing it to develop a power of 2x 65W under 4 Ohm and integrates two balanced and single-ended inputs.
Key features:
  • Dual Class D Infineon Merus MA12070 amplification chip
  • Balanced architecture
  • Output power: 2x 65W under 4 Ohm (1% THD+N)
  • Balanced and single-ended inputs
  • THD+N: < 0.004%
View more informations on Topping PA3s
Pack Topping DAC DX3 Pro+ + Amplificateur PA3s + Câbles RCA TCR2 25cm Noir
Topping TCR2 RCA cables
TCR2 RCA cables benefit from a very nice design quality with silver plated OFC copper conductors, ensuring excellent electrical conductivity and therefore signal transmission. The connectors are gold plated, material resistant to oxidation for a more durable cable.
Key features:
  • Length: 25cm
  • Silver plated OFC copper conductors
  • Gold plated connectors
View more informations on Topping TCR2
Topping DX3 Pro+ specifications
Product typeDAC
Headphone amplifier
Preamplifier
Inputs1* USB-B
1* Optical Toslink
2* Coaxial
Bluetooth 5.0
Outputs1* Stereo RCA
1* Jack 3.5mm headphone output
DAC chipES9038Q2M
Bluetooth chipQCC5125
Supported sample ratesUSB: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Coaxial / Optical: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Headphone amplifier chipTPA 6120A2
Dimensions120*168*40mm
Housing materialAluminum
ColorSilver
Topping Pa3s specifications
Product typeAmplifier
Amplification typeClass D
Amplification chip2* Infineon MA12070
Inputs1* Single-ended RCA
1* Balanced Jack 6.35mm
OutputSpeaker terminals
Output power2x 80W @ 4 Ohm, THD+N < 10%
2x 45W @ 8 Ohm, THD+N < 10%
2x 65W @ 4 Ohm, THD+N < 1%
2x 37W @ 4 Ohm, THD+N < 1%
Supply voltage26VDC
ColorSilver
Topping TCR2 specifications
Product typeMale/male RCA cables
Length25cm
Conductors materialOFC copper
Conductors platingSilver
Conductors section2x 0.533mm² (19AWG)
Conductors resistance26.9 kOhm/km
Cable outer diameterØ8mm
Connectors contacts materialCopper
Connectors contacts platingGold
ColorBlack and red
Composed of the DX3 Pro+ DAC, the PA3S amplifier and the TCR2 RCA cables from Topping, this pack represents an ideal solution to have a powerful...
