Pack Topping E30 II DAC AK4493S + Topping L30 II Amplificateur Casque NFCA + Topping TCR2 Câble RCA 25cm Black
With this Topping pack composed of the E30 II DAC, the L30 II headphone amplifier and preamplifier and the TCR2 RCA cables, you will benefit from a complete set ideal for both headphone listening or to complete an audio system to enhance its sound performance.
By buying this product you get 33 loyalty points
Reference : 17155
330,00 €tax incl.
275,00 € tax excl.
Instead of 337,01 €
Pack content
Pack Topping E30 II + L30 II + TCR2 - black
DAC AK4493S + NFCA Headphone Amplifier + RCA Cables
Topping E30 II
Topping's E30 II is a compact and affordable high-performance DAC with a well thought-out technical structure and high quality components. Its digital/analog conversion stage is equipped with a pair of AKM AK4493S DAC chips connected in parallel and its USB input with an XMOS XU208 interface allowing precise sound reproduction and support of high-resolution streams up to PCM 32bit 768kHz and DSD512. In addition to these, an excellent low noise discrete LNRD power supply stage provides a clean and stable electrical signal to all circuits.
LEARN MORE ABOUT TOPPING E30 II
Topping L30 II
The Topping L30 II is an efficient headphone amplifier and preamplifier, featuring a Nested Feedback Composite Amplifier (NFCA) module that provides plenty of power to carry both sensitive headphones and high-impedance headphones. A versatility reinforced by the presence of a gain control with three levels.
LEARN MORE ABOUT TOPPING L30 II
Topping TCR2
The Topping TCR2 are excellent male to male RCA cables. It integrates silver plated OFC copper conductors to ensure a perfect conductivity and thus transmission of the signal. The contacts of its connectors are gold plated to maintain this very good conductivity while ensuring a better durability.
LEARN MORE ABOUT TOPPING TCR2
Topping E30 II specifications
Product typeDAC
DAC chips2* AKM AK4493S
Inputs1* USB-B
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
Supported sampling ratesUSB: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial: PCM up to 24bit 192kHz
THD+N @ 1kHz, A-Weighting< 0.00015%
THD @ 90kBw, No-Weighting< 0.0006% @ 20Hz-20kHz
SNR @ A-Weighting123dB @ 1kHz
Dynamic range @ A-Weighting123dB @ 1kHz
Frequency response20Hz-20kHz (±0.3dB)
20Hz-40kHz (±0.8dB)
Noise @ A-Weighting< 1.5µVrms
Crosstalk @ 1kHz-132dB
Channel balance< 0.3dB
Output impedance20Ω
Preamplifier
Amplification moduleNFCA
Input1* Stereo RCA
1* Jack 6.35mm headphone output
THD+N @ 1kHz, A-WeightingHeadphone output: < 0.00006% @ 500mW, 32Ω / < 0.00005% @ 80mW, 300Ω
Pre-Out : < 0.00006%
THD @ 90kBw, No-WeightingHeadphone output: < 0.00008% @ 500mW, 32Ω / < 0.00007% @ 80mW, 300Ω
Pre-Out : < 0.00007%
SNR @ Max out, 1kHz, A-WeightingHeadphone output: 144dB
Pre-Out : 144dB
Dynamic range @ 1kHz, A-WeightingHeadphone output: 144dB
Pre-Out : 144dB
Frequency responseHeadphone output: 20Hz-40kHz (±0.05dB)
Pre-Out : 20Hz-40kHz (±0.05dB)
Output levelHeadphone output: 14Vpp @ G=L / 31Vpp @ G=M / 37Vpp @ G=H
Pre-Out : 14Vpp @ G=L / 31Vpp @ G=M / 37Vpp @ G=H
Noise levelHeadphone output: < 0.3µVrms @ G=L / < 0.3µVrms @ G=M / < 1.4µVrms @ G=H
Pre-Out : < 0.3µVrms @ G=L / < 0.3µVrms @ G=M / < 1.4µVrms @ G=H
Crosstalk @ 1kHzHeadphone output: -92dB / Pre-Out : -92dB
Input sensitivityHeadphone output: 25Vrms @ G=L / 11.2Vrms @ G=M / 2.0Vrms @ G=H
Pre-Out : 25Vrms @ G=L / 11.2Vrms @ G=M / 2.0Vrms @ G=H
GainHeadphone output: -14dB @ G=L / 0dB @ G=M / 16.5dB @ G=H
Pre-Out : -14dB @ G=L / 0dB @ G=M / 16.5dB @ G=H
Output impedanceHeadphone output: < 0.1Ω
Pre-Out : 20Ω
Headphone output power2*3500mW @ 16Ω, THD+N < 0.1%
2*2700mW @ 32Ω, THD+N < 0.1%
2*2000mW @ 64Ω, THD+N < 0.1%
2*560mW @ 300Ω, THD+N < 0.1%
Topping TCR2-25 specifications
Product typeRCA cables
Length25cm
Conductor materialOFC copper
Conductor platingSilver
Total section2*0.533mm²
Conductor resistance26.9Ω/km
External diameterØ8mm
Connectors materialCopper
Connectors platingGold
With this Topping pack composed of the E30 II DAC, the L30 II headphone amplifier and preamplifier and the TCR2 RCA cables, you will benefit from a...
