Pack Topping L70 Headphone Amplifier + E70 VELVET DAC + TCX1 XLR Cables 25cm Silver
This Topping pack consists of the L70 headphone amplifier, the E70 Velvet DAC and the TCX1 XLR cables. A coherent and performing set integrating complementary devices thought to work together, both from a technical and aesthetic point of view. This combo allows a very high quality headphone listening, with a rich, precise and dynamic sound reproduction. Moreover, the L70 and the E70 can be connected to each other via a 12V trigger connector for a synchronized automatic switch-on and switch-off. The L70 can also be used as a preamplifier in a home HiFi system, thanks to its RCA and XLR outputs.
By buying this product you get 70 loyalty points
Reference : 17693
709,00 €tax incl.
590,83 € tax excl.
Pack content
Pack Topping L70 + E70 Velvet + TCX1
Headphone amplifier + DAC + XLR Cables Silver
Pack Topping Amplificateur Casque L70 + DAC E70 Velvet + Câbles XLR TCX1 25cm Argent
Topping L70 headphone amplifier
With the L70, Topping offers an extremely well designed NFCA headphone amplifier and balanced preamplifier combo, ensuring excellent sound performance and adapting to a wide range of use scenarios. It is equally at home with demanding headphones or high-sensitivity in-ear monitors, or even in combination with a power amplifier. The L70 is the ideal ally for pure, rich and dynamic listening.
Key features:
  • Headphone amplifier / preamplifier
  • NFCA amplification modules
  • Balanced 4 pins XLR / Balanced Jack 4.4mm / Single-ended Jack 6.35mm headphone outputs
  • High precision relay volume control with volume level memory
  • THD+N: 0.000055%
  • Dynamic range: 146dB
  • Noise: < 0.3µVrms
  • Output impedance: < 0.1 Ohm
  • Output power: 2x 7500mW @ 32 Ohm / 2x 1150mW @ 300 Ohm
View more informations on Topping L70
Topping E70 DAC
The Topping E70 is a high-performance DAC, providing excellent measurements and high-quality, accurate and transparent sound reproduction. It also incorporates smart and practical features, such as Bluetooth, a 12V trigger and an adjustable output level.
Key features:
  • ES9028Pro DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.1 receiver with aptX, aptX HD, aptX Adaptive and LDAC codecs support
  • Sample rates support up to PCM 32bit 768kHz and DSD512
  • XMOS XU316 USB interface
  • New I/V conversion circuit
  • THD+N: 0.00006%
  • Balanced and single-ended outputs
  • Ultra low noise preamplifier
  • IR remote control
View more informations on Topping E70 Velvet
Topping TCX1 XLR cable
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
  • Length: 25cm
  • 6N copper and silver plated 6N copper conductors
  • Gold plated connectors
View more informations on Topping TCX1
Topping L70 specificaitons
Preamplifier
Inputs1* Balanced stereo XLR/Jack 6.35mm combo
1* Single-ended stereo RCA
Outputs1* Single-ended Jack 6.35mm headphone output
1* Balanced Jack 4.4mm headphone output
1* Balanced 4 pins XLR headphone output
1* Single-ended stereo RCA pre-out
1* Balanced stereo XLR pre-out
AmplifierNFCA
Dimensions222*160*45mm
ColorSilver
Topping E70 Velvet Specifications
Product typeDAC
InputsBluetooth 5.1
1* USB-B
1* Coaxial
1* Optical Toslink
Outputs1* Single-ended stereo RCA
DAC chipAKM AK4499EX
USB interfaceXMOS XU316
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
Supported sample ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Dimensions200*138*45mm
ColorSilver
Topping TCX1 specifications
Product typeMale/female XLR cables
Length25cm
Conductors materialCuivre 6N
Silver plated 6N copper
Conductors section0.533mm² (19AWG)
Cable outer diameterØ8mm
Connectors contacts platingGold
Outer sheathBraided nylon
Cable colorBlack and red
This Topping pack consists of the L70 headphone amplifier, the E70 Velvet DAC and the TCX1 XLR cables. A coherent and performing set integrating...
