Pack Topping LA90D Amplifier + D90SE DAC + TCX1 XLR Cables 25cm Black
With this Topping pack we propose a complete set to integrate a HiFi system of very high quality, capable of a detailed, clear and precise sound reproduction. It consists of the LA90D Class AB discrete amplifier, the D90SE balanced DAC and the TCX1 XLR cables. A set that presents a great coherence and evolutivity, as well from a technical point of view as from the design with a perfectly adjusted form factor.
By buying this product you get 175 loyalty points
Reference : 17699
1 755,00 €tax incl.
1 462,50 € tax excl.
Pack content
Pack Topping LA90D + D90SE + TCX1
Amplifier + DAC + XLR Cables Black
Pack Topping Amplificateur LA90D + DAC D90SE + Câbles XLR TCX1 25cm Noir
Topping LA90D amplifier
Topping now offers the excellent LA90 in a version using discrete circuits: the LA90 Discrete. This is a powerful amplifier, offering incredible measurements for a breathtaking listening experience. The new NFCA discrete amplifier circuitry ensures extremely clear and precise sound reproduction. The amplifier has the same features as the first LA90, with mono or stereo operation, adjustable gain and a combined balanced input connector for 6.35mm jack or XLR.
Key features:
  • Class AB discrete amplifier
  • NFCA amplification circuit
  • Stereo output power: 2x120W @ 4 Ohm / 2x66W @ 8 Ohm
  • Mono output power: 180W @ 4 Ohm / 220W @ 8 Ohm
  • THD+N  < 0.0001%
  • SNR: 143dB
  • 2 gain level
View more informations on Topping LA90D
Topping D90SE DAC
The Topping D90SE is a high-end DAC with an intelligent and careful design for high performance. It features an ESS ES9038Pro conversion chip, a XMOS XU216 USB interface and an Altera MAX II CPLD. The D90SE is also versatile, with a full set of connectivity and a built-in Bluetooth receiver.
Key features:
  • ESS ES9038Pro DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.0 receiver with aptX, aptX LL, aptX HD and LDAC codecs support
  • Sample rates support up to PCM 32bit 768kHz and DSD512
  • MQA files support
  • XMOS XU216 USB interface
  • THD+N: 0.00005%
  • Balanced and single-ended outputs
  • Ultra low noise preamplifier
  • IR remote control
View more informations on Topping D90SE
Topping TCX1 XLR cables
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
  • Length: 25cm
  • 6N copper and silver plated 6N copper conductors
  • Gold plated contacts
View more informations on Topping TCX1
Topping LA90D specifications
Product typeDiscrete amplifier
Inputs3* Combo Jack 6.35mm/XLR
OutputSpeaker terminals
AmplifierNFCA
Dimensions220*205*90mm
Topping D90SE specifications
Product typeBalanced DAC
InputsBluetooth 5.0
1* USB-B
1* AES/EBU
1* Coaxial
1* Optical Toslink
1* I2S LVDS via HDMI
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
DAC chipESS ES9038Pro
USB interfaceXMOS XU216
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Supported sample ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Dimensions222*160*45mm
Topping TCX1 specifications
Product typeMale/female XLR cables
Length25cm
Conductors material6N copper
Silver plated 6N copper
Conductors section0.533mm² (19AWG)
Cable outer diameterØ8mm
Connectors platingGold
Outer sheathBraided nylon
Cable colorBlack and red
With this Topping pack we propose a complete set to integrate a HiFi system of very high quality, capable of a detailed, clear and precise sound...
