Pack Topping PA7 PLUS Amplifier + E70 VELVET DAC + TCX1 XLR Cables 25cm Silver
This Topping pack, composed of the PA7 Plus Class D amplifier, the E70 Velvet DAC and the TCX1 XLR cables, represents an excellent set, very efficient and coherent both from a technical and aesthetic point of view. It will allow you to have a complete audio system, powerful, efficient and capable of a precise and rich sound restitution, to which it will be enough to add speakers (sold separately) to enjoy your music in ideal conditions.
By buying this product you get 98 loyalty points
Reference : 17709
989,00 €tax incl.
824,17 € tax excl.
Pack content
Pack Topping PA7 Plus + E70 Velvet+ TCX1
Amplifier + DAC + XLR Cables Silver
Pack Topping Amplificateur PA7 Plus + DAC E70 Velvet + Câbles XLR TCX1 25cm Argent
Topping PA7 Plus amplifier
The Topping PA7 Plus is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of the PA7 provides effective transmission noise reduction.
Key features:
  • Class D amplifier
  • Output power: 2x245W @ 4 Ohm, THD+N <1%
  • SNR: 126dB
  • XLR, Jack 6.35mm TRS and RCA inputs
  • Balanced conception
  • 12V trigger
  • Two gain levels
View more informations on Topping PA7 Plus
Topping E70 Velvet DAC
With the E70 Velvet, Topping offers a new version of the excellent E70 DAC featuring the new AKM AK4499EX high-end DAC chip. For the rest, it takes the excellent technical base of its elder, combining a careful design and high-end components for exceptional sound performance with smart and practical features, such as Bluetooth, a 12V trigger or an adaptable output level.
Key features:
  • AKM AK4499EX DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.1 receiver with aptX, aptX LL, aptX HD, aptX Adaptive and LDAC codecs support
  • Sample rates support up to PCM 32bit 768kHz and DSD512
  • XMOS XU316 USB interface
  • THD+N: 0.00006%
  • Balanced and single-ended outputs
  • Low noise power supply
  • Ultra low noise preamplifier
  • IR remote control
View more informations on Topping E70 Velvet
Topping TCX1 XLR cables
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
  • Length: 25cm
  • 6N copper and silver plated 6N copper
  • Gold plated connectors
View more informations on Topping TCX1
Topping PA7 Plus specifications
Product typeAmplifier
Inputs1* Balanced XLR/Jack 6.35mm TRS combo
1* Single-ended stereo RCA
OutputSpeaker terminals
Amplification typeClass D
Dimensions200*155*41mm
ColorSilver
Topping E70 Velvet specifications
Product typeDAC
InputsBluetooth 5.1
1* USB-B
1* Coaxial
1* Optical Toslink
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
DAC ChipAKM AK449EX
USB interfaceXMOS XU316
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
Supported sample ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Dimensions200*138*44mm
ColorSilver
Topping TCX1 specifications
Product typeMale/female XLR cables
Length25cm
Conductors material6N copper
Silver plated 6N copper
Conductors section0.533mm² (19AWG)
Cable outer diameterØ8mm
Connectors contacts platingGold
Outer sheathBraided nylon
Cable coloBlack and red
This Topping pack, composed of the PA7 Plus Class D amplifier, the E70 Velvet DAC and the TCX1 XLR cables, represents an excellent set, very...
