By buying this product you get 40 loyalty points
We offer you a Triangle pack comprising the BR02 bookshelf speakers in light oak color and the S01 speaker stands. The S01 speaker stands will enable you to position the BR02s optimally and enjoy high-quality sound reproduction.
Compact but powerful, the Triangle Borea BR02 speakers are an excellent entry point into the world of high fidelity. They feature a 25mm EFS dome tweeter and a 13cm driver with natural cellulose pulp cone. Their 80W power handling delivers immersive, full-bodied sound for spaces up to 20m².
View complete product page of TRiangle Borea BR02Triangle's S01 speaker stands allow you to position your speakers at ear height, in a seated position, thanks to their 60cm height. Each stand comes with adjustable decoupling spikes for precise adjustment, and a cable feed-through for discreet installation. Made of steel, these durable stands can support loads of up to 20kg.
View complete product page of Triangle S01Technical characteristics
Product type | Speakers + Stands |
Package contents | 1x Triangle Borea BR02 (pair) 1x Triangle S01 speaker stands (pair) |
TRIANGLE BOREA BR02 BOOKSHELF SPEAKER SPECIFICATIONS | |
Product type | Bookshelf speakers |
Number of drivers | 2 |
Number of ways | 2 |
Power handling | 80W |
Sensitivity | 89dB/W/m |
Frequency response (+/-3dB) | 51Hz-22kHz |
High frequency roll-off | 2500Hz |
Rated impedance (min/max) | 3.6 / 8Ω |
Recommended room size | Up to 20m² |
Dimensions | 176 x 310 x 274mm |
Unit weight | 4.87kg |
Color | Light Oak |
Quantity | Pair |
TRIANGLE S01 SPEAKER STANDS SPECIFICATIONS | |
Product type | Speaker stands |
Height without spikes | 600mm |
Base width | 230 x 270mm |
Top plate width | 165 x 215mm |
Cable passage | |
Spikes | Adjustable |
Dimensions | 270 x 600 x 230mm |
Weight | 8.1kg |
