By buying this product you get 40 loyalty points
We offer you a Triangle pack comprising the BR02 bookshelf speakers in walnut color and the S01 speaker stands. The S01 speaker stands will enable you to position the BR02s optimally and enjoy high-quality sound reproduction.
Compact but powerful, the Triangle Borea BR02 speakers are an excellent entry point into the world of high fidelity. They feature a 25mm EFS dome tweeter and a 13cm driver with natural cellulose pulp cone. Their 80W power handling delivers immersive, full-bodied sound for spaces up to 20m².
View complete product page of TRiangle Borea BR02Triangle's S01 speaker stands allow you to position your speakers at ear height, in a seated position, thanks to their 60cm height. Each stand comes with adjustable decoupling spikes for precise adjustment, and a cable feed-through for discreet installation. Made of steel, these durable stands can support loads of up to 20kg.
View complete product page of Triangle S01Technical characteristics
Product type | Speakers + Stands |
Package contents | 1x Triangle Borea BR02 (pair) 1x Triangle S01 speaker stands (pair) |
TRIANGLE BOREA BR02 BOOKSHELF SPEAKER SPECIFICATIONS | |
Product type | Bookshelf speakers |
Number of drivers | 2 |
Number of ways | 2 |
Power handling | 80W |
Sensitivity | 89dB/W/m |
Frequency response (+/-3dB) | 51Hz-22kHz |
High frequency roll-off | 2500Hz |
Rated impedance (min/max) | 3.6 / 8Ω |
Recommended room size | Up to 20m² |
Dimensions | 176 x 310 x 274mm |
Unit weight | 4.87kg |
Color | Walnut |
Quantity | Pair |
TRIANGLE S01 SPEAKER STANDS SPECIFICATIONS | |
Product type | Speaker stands |
Height without spikes | 600mm |
Base width | 230 x 270mm |
Top plate width | 165 x 215mm |
Cable passage | |
Spikes | Adjustable |
Dimensions | 270 x 600 x 230mm |
Weight | 8.1kg |
