By buying this product you get 84 loyalty points
This package includes Triangle LN01A active speakers, Triangle Tales 340 subwoofer and LFE cable from Pangea. This set will enable you to enjoy precise, detailed sound reproduction, with deep, perfectly defined bass.
Triangle's Active Series speakers embody the new generation of ultra-connected HiFi speakers. So you can listen to your music from your phone, tablet or turntable, and enjoy immersive, dynamic stereo sound. A true all-in-one HiFi system, the LN01A incorporates a 2x50W Class D amplifier so you can enjoy your music to the full.
FIND OUT MORE ABOUT TRIANGLE LN01A SPEAKERSThe versatile Triangle Tales 340 active subwoofer is equally at home in a HiFi or Home Cinema installation. The subwoofer is equipped with a 25cm diameter long-throw driver and a Class D amplifier delivering 200W RMS (350W max). It will enable you to provide a stereo system with excellent bass response and great dynamism. The Tales is a full-featured model, with automatic on/off and crossover frequency control for optimum adjustment of the subwoofer within your system.
FIND OUT MORE ABOUT THE TRIANGLE TALES 340 SUBWOOFERThis exceptionally well-made cable features 100% Cardas Grade One (hot-spot) copper strands, considered to be the best copper on earth, and triple-insulated with silver-plated EMI / RFI and luminium mylar. What's more, these high-purity copper strands are sheathed in PE tubing (superior to PTFE) using air as a natural insulator, derived from Pangea's top-of-the-range cables. This subwoofer cable uses one shield per conductor, eliminating all parasitic noise for a dynamic, smooth bass.
The finishing touch on the Pangea Audio Premier Subwoofer is the beautifully crafted Prime 400 RCA plug. These premium RCAs feature a highly advanced form of copolymer core insulation wrapped around gold-plated brass connections. The one-piece gold-plated core is slotted, giving it grip at the connection point. The gold-plated Prime RCA 400 with four cuts snaps securely into place with the corresponding RCA connector. Its Black Carbon chrome finish adds a high-end touch, and is highly resistant to scratches and ageing over time.
FIND OUT MORE ABOUT LFE PANGEA CABLETechnical characteristics
Triangle Elara LN01A speakers specifications | |
Product type | Active speakers |
Speaker type | Bass reflex |
Number of drivers | 2 |
Drivers | Tweeter 25mm Woofer 13cm |
Recommended room area | De 15 à 30m² |
Sensitivity | 89dB/W/m |
Power handling | 2x50W |
Frequency response (+3dB) | 56Hz - 22kHz |
Min/max impedance | 4.5 / 8Ω |
Connectivity | Bluetooth 1x Stereo RCA 1x AUX Jack 3.5mm 1x Optical 1x Coaxial 1x Subwoofer output |
Supported Bluetooth codecs | aptX |
Dimensions | 165 x 235 x 291mm |
Weight | 9.5kg |
Color | Light oak |
Packaging | Pair |
Triangle Tales 340 subwoofer specifications | |
Product type | Active subwoofer |
Load type | Bass reflex |
Speaker diameter | Ø25cm |
Frequency response (+3dB) | 30Hz - 120Hz |
Amplification type | Class D |
Output power | 200W RMS |
Dimensions | 342 x 383 x 357mm |
Weight | 8.85kg |
Color | Light oak |
LFE Pangea cable specifications | |
Product type | LFE cable |
Length | 2m |
Connectors | Male RCA |
Conductor material | Cardas Grade One copper OFC copper |
Shielding | Triple |
Connectors contacts plating | Gold |
