Pack Triangle Elara LN01A Active Speakers + TALES 340 Subwoofer + Pangea 2m LFE Cable Black
This package includes Triangle LN01A active speakers, Triangle Tales 340 subwoofer and LFE cable from Pangea. This set will enable you to enjoy precise, detailed sound reproduction, with deep, perfectly defined bass.
By buying this product you get 84 loyalty points
Reference : 19102
849,00 €tax incl.
707,50 € tax excl.
Pack content
Pack Triangle Elara LN01A + TALES 340 + LFE Pangea cable Active speakers + Subwoofer + 2m LFE cable, Black
Pack Active Speakers LN01A + Subwoofer Tales 340 + Pangea LFE cable 2m
Triangle Elara LN01A active speakers
Triangle's Active Series speakers embody the new generation of ultra-connected HiFi speakers. So you can listen to your music from your phone, tablet or turntable, and enjoy immersive, dynamic stereo sound. A true all-in-one HiFi system, the LN01A incorporates a 2x50W Class D amplifier so you can enjoy your music to the full.
FIND OUT MORE ABOUT TRIANGLE LN01A SPEAKERS
Triangles LN01A speakers
Tales 340 subwoofer
The versatile Triangle Tales 340 active subwoofer is equally at home in a HiFi or Home Cinema installation. The subwoofer is equipped with a 25cm diameter long-throw driver and a Class D amplifier delivering 200W RMS (350W max). It will enable you to provide a stereo system with excellent bass response and great dynamism. The Tales is a full-featured model, with automatic on/off and crossover frequency control for optimum adjustment of the subwoofer within your system.
FIND OUT MORE ABOUT THE TRIANGLE TALES 340 SUBWOOFER
LFE cable 2m Pangea
This exceptionally well-made cable features 100% Cardas Grade One (hot-spot) copper strands, considered to be the best copper on earth, and triple-insulated with silver-plated EMI / RFI and luminium mylar. What's more, these high-purity copper strands are sheathed in PE tubing (superior to PTFE) using air as a natural insulator, derived from Pangea's top-of-the-range cables. This subwoofer cable uses one shield per conductor, eliminating all parasitic noise for a dynamic, smooth bass.
The finishing touch on the Pangea Audio Premier Subwoofer is the beautifully crafted Prime 400 RCA plug. These premium RCAs feature a highly advanced form of copolymer core insulation wrapped around gold-plated brass connections. The one-piece gold-plated core is slotted, giving it grip at the connection point. The gold-plated Prime RCA 400 with four cuts snaps securely into place with the corresponding RCA connector. Its Black Carbon chrome finish adds a high-end touch, and is highly resistant to scratches and ageing over time.
FIND OUT MORE ABOUT LFE PANGEA CABLE
Pangea LFE cable
Triangle Elara LN01A speakers specifications
Product typeActive speakers
Speaker typeBass reflex
Number of drivers2
DriversTweeter 25mm
Woofer 13cm
Recommended room areaDe 15 à 30m²
Sensitivity89dB/W/m
Power handling2x50W
Frequency response (+3dB)56Hz - 22kHz
Min/max impedance4.5 / 8Ω
ConnectivityBluetooth
1x Stereo RCA
1x AUX Jack 3.5mm
1x Optical
1x Coaxial
1x Subwoofer output
Supported Bluetooth codecsaptX
Dimensions165 x 235 x 291mm
Weight9.5kg
PackagingPair
Triangle Tales 340 subwoofer specifications
Product typeActive subwoofer
Load typeBass reflex
Speaker diameterØ25cm
Frequency response (+3dB)30Hz - 120Hz
Amplification typeClass D
Output power200W RMS
Dimensions342 x 383 x 357mm
Weight8.85kg
LFE Pangea cable specifications
Product typeLFE cable
Length2m
ConnectorsMale RCA
Conductor materialCardas Grade One copper
OFC copper
ShieldingTriple
Connectors contacts platingGold
This package includes Triangle LN01A active speakers, Triangle Tales 340 subwoofer and LFE cable from Pangea. This set will enable you to enjoy...
