Pack Triangle Vinyl Turntable LUNAR 1 Black + AIO TWIN Active Speakers Eggplant
We offer you this product pack from Triangle, comprising the Lunar 1 turntable and AIO TWIN active speakers. This pack allows you to enjoy your vinyl library to the full, as well as taking advantage of the many additional functions of the AIO TWIN speakers.
By buying this product you get 103 loyalty points
Reference : 19636
1 039,00 €tax incl.
865,83 € tax excl.
Instead of 1 088,00 €
Pack content
Photo du pack pack Triangle Platine Vinyle LUNAR 1 + Enceintes Actives AIO TWIN
TRIANGLE LUNAR 1 : Ninym Turntable 33/45 RPM Ortofon OM-5E Black
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
View complete product page of Triangle Lunar 1 turntable Photo de la platine Lunar 1
TRIANGLE AIO TWIN : Enceintes Bibliothèques Actives Bluetooth 5.0 aptX HD WiFi 2x50W 24bit 192kHz Eggplant (La paire)
Triangle's AIO Twin active bookshelf loudspeakers are a real concentrate of technology and know-how. Versatile, with extensive connectivity, they are perfectly adapted to today's uses. They also offer excellent sound performance, revealing a rich, precise and detailed sound.
Equipped with WiFi and Bluetooth 5.0 connectivity, the remote broadcasting of your music is done easily, directly from your smartphone or computer, with a resolution that can reach 24bit 192kHz. Still in this perspective of versatility, the AIO Twin has a Phono input to connect a vinyl turntable.
View complete product page of Triangle AIO TWIN Photo des enceintes AIO TWIN
Product typeVinyl Turntable + Active Speakers
Package content1x Triangle Lunar 1
1x Triangle AIO TWIN speakers pair
Lunar 1 Vinyl Turntable specifications
Product typeVinyl turntable
Turntable typeManual
Drive systemBy belt
Playback speeds33 and 45 RPM
CartridgeOrtophon OM-5E
Diamond typeElliptical
Tone arm typeStraight
Tone arm materialAluminum
Tone arm length21.5cm
Cartridge output voltage4mV
Fréquency response20hZ-20kHz
Output1x Stereo phono RCA (with ground terminal)
CableRCA phono interconnect cable (HP-OCC and gold-plated connectors)
RCA cable length1.2m
Power supply5V DC
Dimensions420 x 330 x 112mm
Weight3.5kg
Package1x Triangle Lunar 1 turntable
1x Flat belt
1x Dust cover
1x RCA Phono interconnect cable
AIO TWIN speakers specifications
Product typeActive speakers
DriversTweeter 25mm
Woofer 13cm
Power handling2x50W
NetworkWiFi IEEE 802.11g/b/n 2.4GHz RJ45 10/100M LAN
Supported sampling ratesPCM jusqu'à 24bit 192kHz
Bluetooth version5.0
Supported Bluetooh codecsAAC, SBC, aptX, aptX LL, aptX HD
InputsWiFi
1x Stereo RCA
1x Jack 3.5mm
1x Optical Toslink
Bluetooth
1x USB-A (USB Host)
Outputs1x Subwoofer output
Frequency response56Hz - 22kHz
Supported audio formatsAPE, FLAC, WAV, Apple Lossless (ALAC), AAC, AAC-LC, HE-AAC, HE-AAC v2, MP3, CBR/VBR
Dimensions165 x 304 x 235mm
Weight10.4kg (paire)
ColorEggplant
QuantityPair
We offer you this product pack from Triangle, comprising the Lunar 1 turntable and AIO TWIN active speakers. This pack allows you to enjoy your...
