By buying this product you get 84 loyalty points
We offer you this pack of products from Triangle, comprising the Lunar 1 turntable and LN01A active speakers. This pack lets you enjoy your vinyl library for the most pleasant listening experience, as well as taking advantage of the LN01A speakers' many additional functions.
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
View complete product page of Triangle Lunar TurntableTriangle's Active Series speakers are the next generation of ultra-connected HiFi speakers. You can listen to your music from your phone, tablet or turntable and enjoy immersive and dynamic stereo sound. A true all-in-one HiFi system, the LN01A integrates a 2x50W Class D amplifier allowing you to fully enjoy your music.
View complete product page of Triangle LN01ATechnical characteristics
Product type | Vinyl turntable + Active speakers |
Package content | 1x Triangle Lunar 1 1x Triangle LN01A |
Lunar 1 vinyl turntable specifications | |
Product type | Vinyl turntable |
Turntable type | Manual |
Drive system | By belt |
Playback speeds | 33 and 45 RPM |
Cartridge | Ortofon OM-5E |
Diamond type | Elliptical |
Tone arm type | Straight |
Tone arm material | Aluminum |
Tone arm length | 21.5cm |
Cartridge output voltage | 4mV |
Fréquency response | 20hZ-20kHz |
Output | 1x Stereo phono RCA (with ground terminal) |
Cable | RCA phono interconnect cable (HP-OCC and gold-plated connectors) |
RCA cable length | 1.2m |
Power supply | 5V DC |
Dimensions | 420 x 330 x 112mm |
Weight | 3.5kg |
Color | Black |
Package | 1x Triangle Lunar 1 turntable 1x Flat belt 1x Dust cover 1x RCA Phono interconnect cable |
ELara LN01A speakers specifications | |
Product type | Active speakers |
Speaker type | Bass Reflex |
Number of drivers | 2 |
Drivers | Tweeter 25mm Woofer 13cm |
Recommended room size | 15 to 30m². |
Sensitivity | 89dB/W/m |
power handling | 2x50W |
Bandwidth (+3dB) | 56Hz - 22kHz |
Min/Max nominal impedance | 4.5 / 8Ω |
Connectivity | Bluetooth 1x Stereo RCA 1x AUX Jack 3.5mm 1x Optical 1x Coaxial 1x Subwoofer output |
Supported Bluetooth codecs | aptX |
Dimensions | 165 x 235 x 291mm |
Weight | 9.5kg |
Color | Abyss Blue |
Quantity | Pair |
