Pack Triangle Vinyl Turntable LUNAR 1 Black + Elana LN01A Active Speakers Chesnut
We offer you this pack of products from Triangle, comprising the Lunar 1 turntable and LN01A active speakers. This pack lets you enjoy your vinyl library for the most pleasant listening experience, as well as taking advantage of the LN01A speakers' many additional functions.
By buying this product you get 79 loyalty points
Reference : 19642
798,00 €tax incl.
665,00 € tax excl.
Pack content
Photo of Pack Triangle Platine Vinyle LUNAR 1 + Enceintes Actives LN01A
TRIANGLE LUNAR 1 : Vinyl Turntable 33/45 Tours Ortofon OM-5E Black
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
View complete product page of Triangle Lunar Turntable Lunar 1 turntable picture
TRIANGLE Elana LN01A : Active Speakers Bluetooth aptX 2x50W 89dB 56Hz-22kHz Chesnut (Pair)
Triangle's Active Series speakers are the next generation of ultra-connected HiFi speakers. You can listen to your music from your phone, tablet or turntable and enjoy immersive and dynamic stereo sound. A true all-in-one HiFi system, the LN01A integrates a 2x50W Class D amplifier allowing you to fully enjoy your music.
View complete product page of Triangle LN01A LN01A picture
Product typeVinyl turntable + Active speakers
Package content1x Triangle Lunar 1
1x Triangle LN01A speakers pair
Lunar 1 vinyl turntable specifications
Turntable typeManual
Drive systemBy belt
Playback speeds33 and 45 RPM
CartridgeOrtofon OM-5E
Diamond typeElliptical
Tone arm typeStraight
Tone arm materialAluminum
Tone arm length21.5cm
Cartridge output voltage4mV
Fréquency response20hZ-20kHz
Output1x Stereo phono RCA (with ground terminal)
CableRCA phono interconnect cable (HP-OCC and gold-plated connectors)
RCA cable length1.2m
Power supply5V DC
Dimensions420 x 330 x 112mm
Weight3.5kg
Package1x Triangle Lunar 1 turntable
1x Flat belt
1x Dust cover
1x RCA Phono interconnect cable
Elana LN01A speakers specifications
Product typeActive speakers
Speaker typeBass Reflex
Number of drivers2
DriversTweeter 25mm
Woofer 13cm
Recommended room size15 to 30m².
Sensitivity89dB/W/m
power handling2x50W
Bandwidth (+3dB)56Hz - 22kHz
Min/Max nominal impedance4.5 / 8Ω
ConnectivityBluetooth
1x Stereo RCA
1x AUX Jack 3.5mm
1x Optical
1x Coaxial
1x Subwoofer output
Supported Bluetooth codecsaptX
Dimensions165 x 235 x 291mm
Weight9.5kg
ColorChesnut
QuantityPair
We offer you this pack of products from Triangle, comprising the Lunar 1 turntable and LN01A active speakers. This pack lets you enjoy your vinyl...
