By buying this product you get 94 loyalty points
We offer you this pack of products from Triangle, comprising the Lunar 1 turntable and BR02 Connect active speakers. This pack lets you enjoy your vinyl library for the most pleasant listening experience, as well as taking advantage of the BR02 Connect speakers' many additional functions.
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
View complete product page of Triangle Lunar TurntableTriangle Borea BR02 Connect active bookshelf speakers provide a complete, versatile stereo sound system. They incorporate a high-performance amplifier, making it easy to add sound to rooms from 8m² to 20m².
The BR02 Connect has been designed for versatile use, adapting perfectly to today's needs. With this in mind, they feature Bluetooth aptX HD reception for remote broadcasting, a phono input for connecting a turntable, an optical and HDMI (ARC/CEC) input for association with a TV, a USB-B input for use with a computer, and even a subwoofer output offering the possibility of associating a subwoofer (not supplied).
A true integrated HiFi system, the BR02 Connect features a Class D amplifier capable of delivering a comfortable 2x50W RMS power. Each speaker is equipped with an EFS fabric dome tweeter and a 13cm diameter bass-midrange driver. As a result, these compact bookshelf speakers are capable of developing a rich sound image, marked by powerful, controlled bass, smooth midrange and precise treble.
View complete product page of Triangle BR02 ConnectTechnical characteristics
Product type | Vinyl turntable + Active speakers |
Package content | 1x Triangle Lunar 1 1x Triangle Borea BR02 Connect speakers pair |
Lunar 1 vinyl turntable specifications | |
Product type | Vinyl turntable |
Turntable type | Manual |
Drive system | By belt |
Playback speeds | 33 and 45 RPM |
Cartridge | Ortofon OM-5E |
Diamond type | Elliptical |
Tone arm type | Straight |
Tone arm material | Aluminum |
Tone arm length | 21.5cm |
Cartridge output voltage | 4mV |
Fréquency response | 20hZ-20kHz |
Output | 1x Stereo phono RCA (with ground terminal) |
Cable | RCA phono interconnect cable (HP-OCC and gold-plated connectors) |
RCA cable length | 1.2m |
Power supply | 5V DC |
Dimensions | 420 x 330 x 112mm |
Weight | 3.5kg |
Color | Black |
Package | 1x Triangle Lunar 1 turntable 1x Flat belt 1x Dust cover 1x RCA Phono interconnect cable |
BR02 Connect speakers specifications | |
Product type | Active speakers |
Speaker type | Bass Reflex |
Number of drivers | 2 |
Drivers | Tweeter Ø25mm Bass-Medium Ø13cm |
Sensitivity | 89dB/W/m |
Amplification type | Class D |
Power | 2x50W RMS |
Frequency response | 51Hz - 22kHz |
Min/max impedance | 3.6Ω / 8Ω |
Inputs | Bluetooth 5.0 1x Jack 3.5mm 1x Optical Toslink 1x Coaxial 1x Steroe RCA (line / phono MM) 1x HDMI (ARC/CEC) |
Output | 1x Subwoofer output (RCA) |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX LL, aptX HD |
Supported audio formats | MP3, WMA, APE, FLAC, WAV, Apple Lossless |
Dimensions (L x H x P) | 176 x 310 x 274mm |
Weight (pair) | 13.4kg |
Color | Black |
Package | 2x Borea BR02 Connect 1x Remote control 1x Power cable 1x Speaker cable 3m |
