Pack Triangle Vinyl Turntable LUNAR 1 + BOREA BR03 Connect Active Speakers Green
We offer you this product pack from Triangle, comprising the Lunar 01 turntable and BR03 Connect active speakers. This pack lets you enjoy your vinyl library for the most pleasant listening experience, while taking advantage of the BR03 Connect speakers' additional functions.
By buying this product you get 104 loyalty points
Reference : 19652
1 048,00 €tax incl.
873,33 € tax excl.
Instead of 1 048,00 €
Pack content
Photo du Pack Triangle Platine Vinyle LUNAR 1 + Enceintes Actives BOREA BR03 Connect
TRIANGLE LUNAR 1 : Vinyl Turntable 33/45 Tours Ortofon OM-5E Green
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
View complete product page of Triangle Lunar Turntable Lunar 1 turntable picture
TRIANGLE BR03 Connect : Active Speakers Bluetooth 5.0 aptX HD 2x60W 90dB 47Hz-22kHz Green (Pair)
Triangle Borea BR03 Connect active bookshelf speakers provide a complete, versatile stereo sound system. They incorporate a high-performance amplifier, making it easy to add sound to rooms from 15m² to 40m².
The BR03 Connect has been designed for versatile use, adapting perfectly to today's needs. With this in mind, they feature Bluetooth aptX HD reception for remote broadcasting, a phono input for connecting a turntable, an optical and HDMI (ARC/CEC) input for association with a TV, a USB-B input for use with a computer, and even a subwoofer output offering the possibility of associating a subwoofer (not supplied).
A true integrated HiFi system, the BR03 Connect features a Class D amplifier capable of delivering a comfortable 2x60W RMS power. Each speaker is equipped with an EFS fabric dome tweeter and a 16.5cm diameter bass-midrange driver. As a result, these compact bookshelf speakers are capable of developing a rich sound image, marked by powerful, controlled bass, smooth midrange and precise treble.
View complete product page of Triangle BR03 Connect BR03 Connect picture
Product typeVinyl turntable + Active speakers
Package content1x Triangle Lunar 1
1x Triangle Borea BR03 Connect speakers pair
Lunar 1 vinyl turntable specifications
Turntable typeManual
Drive systemBy belt
Playback speeds33 and 45 RPM
CartridgeOrtofon OM-5E
Diamond typeElliptical
Tone arm typeStraight
Tone arm materialAluminum
Tone arm length21.5cm
Cartridge output voltage4mV
Fréquency response20hZ-20kHz
Output1x Stereo phono RCA (with ground terminal)
CableRCA phono interconnect cable (HP-OCC and gold-plated connectors)
RCA cable length1.2m
Power supply5V DC
Dimensions420 x 330 x 112mm
Weight3.5kg
ColorGreen
Package1x Triangle Lunar 1 turntable
1x Flat belt
1x Dust cover
1x RCA Phono interconnect cable
BR03 Connect speakers specifications
Product typeActive speakers
Speaker typeBass Reflex
Number of drivers2
DriversTweeter Ø25mm
Bass-Medium Ø16cm
Sensitivity90dB/W/m
Amplification typeClass D
Power2x60W RMS
Frequency response47Hz - 22kHz
Min/max impedance4.2Ω / 8Ω
InputsBluetooth 5.0
1x Jack 3.5mm
1x Optical Toslink
1x Coaxial
1x Steroe RCA (line / phono MM)
1x HDMI (ARC/CEC)
Output1x Subwoofer output (RCA)
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Supported audio formatsMP3, WMA, APE, FLAC, WAV, Apple Lossless
Dimensions (L x H x P)206 x 360 x 314mm
Weight (pair)16.7kg
ColorGreen
Package2x Borea BR03 Connect
1x Remote control
1x Power cable
1x Speaker cable 3m
We offer you this product pack from Triangle, comprising the Lunar 01 turntable and BR03 Connect active speakers. This pack lets you enjoy your...
