Pack WiiM Ultra Gray + Audiophonics AP300-S500NC + Audiophonics Wire RCA 30cm + Trigger Cable
New
We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra audio streamer, an AP300-S500NC amplifier, a pair of RCA modulation cables and a trigger cable. This pack will give you a connected system with plenty of power reserve and excellent sound quality.
By buying this product you get 102 loyalty points
Reference : 20650
1 029,00 €tax incl.
857,50 € tax excl.
Instead of 1 135,40 €
Pack content
Pack WiiM x Audiophonics WiiM Ultra Gray + Audiophonics AP300-S500NC + Audiophonics Wire RCA 30cm + Trigger Cable
WiiM x Audiophonics pack photo
We offer you a WiiMAudiophonics product pack comprising the Wiim Ultra audio streamer, an AP300-S500NC amplifier, a pair of RCA modulation cables and a trigger cable. This pack will give you a connected system with plenty of power reserve and excellent sound quality.
Wiim Ultra : Streamer DAC ES9038Q2M Bluetooth WiFi 32bit 384kHz
The WiiM Ultra sets a new benchmark in the world of audio streamers, thanks to a design conceived to deliver an unrivalled audio experience. It lets you enjoy your music library and favorite streaming services in a perfectly intuitive way, thanks in particular to a 3.5" color touchscreen and physical navigation button. With its extensive connectivity including WiFi and Bluetooth, you can access your music quickly and easily, whether it's stored on a NAS, computer, smartphone or via a streaming service. What's more, the WiiM Ultra boasts a rich selection of audio inputs and outputs to integrate easily into the vast majority of audio setups.
View complete product page of Wiim Ultra Wiim Ultra
Audiophonics AP300-S500NC : Class D Stereo Power Amplifier Ncore NC502MP 2x500W 4 Ohm
Le Audiophonics AP300-S500NC est un amplificateur de puissance stéréo basé sur un module d'amplification Hypex Ncore NC502MP. Cette solution est idéale pour qui veut disposer d'une réserve de puissance conséquente (2x500W @ 4Ω) sans pour autant sacrifier la qualité de restitution sonore. Ce bloc d'amplification conviendra par exemple pour accompagner des enceintes exigeantes, pour sonoriser de vastes pièces d'écoute ou pour les applications studio nécessitant un headroom considérable sans faire de compromis sur la précision et la richesse du message audio. L'ensemble des composants est intégré dans un boîtier 100% Aluminium sobre et robuste disposant d'ouvertures afin de favoriser la dissipation de chaleur. Sa conception lui permet également de limiter l'impact des interférences sur le signal.
View complete product page of AP300-S500NC Audiophonics AP300-S500NC
Audiophonics Wire RCA : Interconnect Cable Stereo RCA OFC Copper Gold Plated 30cm
The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a Mogami Neglex W2549 modulation cable and Amphenol ACPR male RCA connectors, providing excellent conductivity and durability for efficient audio signal transmission.
View complete product page of Audiophonics Wire RCA Audiophonics Wire RCA
Trigger cable : Male Jack 3.5mm to Male Jack 3.5mm Mono Cable 0.4m
This 3.5mm mono jack cable is ideal for connecting mono audio devices or triggers. It features a 40cm length.
View complete product page of the Trigger cable Câble trigger
Product typeNetwork player + Amplifier + RCA modulation cables + Trigger cable
Package content1x WiiM Ultra
1x Audiophonics AP300-S250NC
1x AUDIOPHONICS WIRE RCA
1x Trigger cable
WiiM Ultra Specification
Product typeAudio streamer
Inputs1x Stereo RCA
1x Phono input (RCA)
1x Optical Toslink
1x HDMI ARC
1x USB-A
1x Ethernet RJ45
Outputs1x Stereo RCA
1x Coaxial
1x Optical Toslink
1x Subwoofer output (RCA)
1x Jack 3.5mm headphone output
ConnectivityWiFi 6E 802.11 g/b/n/ax 2.4GHz, 5GHz, 6GHz
Ethernet 10M/100Mbps
Bluetooth 5.3
DAC chipES9038Q2M
Bluetooth versionBluetooth 5.3 BLE / BT LE Audio
A2DP, AVRCP, HID receiver and transmitter support
Works with WiiM voice control
Supported sampling ratesInput: PCM up to 32bit 384kHz
Output: PCM up to 24bit 192kHz
Supported Bluetooth codecsSBC, AAC
Max output level (line out)2.1Vrms
SNR (line out)121dB(A)
THD+N (line out) (1kHz)0.00018% (-115dqB) from 44.1kHz to 192kHz
FR curve±0.05dB
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (driver required)
Mac OSX10.6+
Linux
EQGraphic 10 bands
Parametric 10 bands
Independent for each source
Subwoofer outputBass management
Adjustable latency, phase, level and filter
TriggerOutput (12V)
Touchscreen3.5"
Supply voltage100-240VAC
Dimensions205 x 205 x 73mm
Housing materialAluminum
ColorSpace Gray
Package1x Wiim ULTRA
1x Power cable C7
1x Télécommande
Audiophonics AP300-S500NC Specification
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x350W @ 8Ω
2x500W @ 4Ω
2x450W @ 2Ω
Input1x Unbalanced Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0018%
SNR124dB
Output noise47µV
Output impedance1.5mΩ
Frequency response10Hz - 48kHz
Efficiency92%
Input sensitivityMax Power at 2.35V RMS
XLR : 2x1.17V RMS
RCA : 1.17V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Dimensions300 x 248 x 68mm
Weight2080g
Package1x Audiophonics AP300-S2500NC
1x Power cable
Audiophonics Wire RCA Specification
Product typeStereo RCA cable
ConnectorsMale RCA
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Amphenol ACPR connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialNickel
InsulationPA66
trigger cable Specification
Product typeJack cable
Length40cm (excluding connectors)
Connectors2x 3.5mm male mono jacks
Package1x 3.5mm mono jack cable
Pack WiiM Ultra Streamer Grey + Audiophonics AP300-S500NC amplifier + Audiophonics Wire RCA Cables 30cm + Trigger Cable
We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra audio streamer, an AP300-S500NC amplifier, a pair of RCA modulation...
