Alain P.
Compliqué de faire mieux.
Après avoir écouté l'EVERSOLO DMP A10 qui est également un excellent DAC/STREAMER/PREAMPLI, j'ai finalement décidé de...
Eric B.
Excellente petite machine.
J'ai commandé ce petit ampli sur la foi de différents avis indépendants, et aussi parce que j'avais remarqué la...
Židrūnas S.
le son est doux comparé au furutech FI E35 r
ALLO Acrylic Case for Allo DigiOne and Raspberry Pi 3 Black - reviews - There are 6 reviews.
Bruno C.
ALLO boitier pour DigiOne et Pi 3
Le rapport qualité / prix est très bien.
Je suis pas très bon bricoleur, mais sur Internet on peut trouver des video de montage ... bref, montage facile et clair.
Seul petit regret : non transparent : suivi visuel des leds impossible.
D. v.
Looks nice, does its job well
The case looks good, although it is not transparent as in the images (solid black).
A little work to get the protective paper layer off, but some hot water and it peels off pretty easily.
Assembly is a breeze, but make sure to place remove the screw ring on the DigiOne coax connector before adding the sidepanel, or it wont fit correctly.
Martijn v.
Not as described
The only reason I bought an Allo Digione board for Rpi at Audiophonics and not some other supplier was because Audiophonics also sells this case. I think the see through acryl looks awesome. So I was pretty dissapointed when I opened the package and the case was not seethrough acryl with a dark shine, but just plain old black. BLACK, totally black, no see through whatsoever. If I had known this I would have looked elsewhere. So only 2 stars just because it's a case, but i'm pretty dissapointed with Audiophonics for selling a product that realy differs from the picture advertised above...
Damianos D.
Practical case, almost as described
The characteristics and dimensions of the case is as described. It has anything you might need for assembling a pi2/3 with a digione, even screws and spacers provided also by digione. The assembly is easy and intuitive. However, in my case it was not a black acrylic but a light brown cardboard. I'm OK with that, I would order it in any case, but for this difference in description I can't give the fifth star.
Pieter T.
Good case, hard to assemble
Good case, sturdy and looks great. Only thing, it is a pain to assemble, took me 1 hour, not very intuitive. But once assembled, everything perfect.
Patrice G.
Très belle qualité
Ce boitier est très qualitatif pour de l'acrylique.
Il est parfaitement conçu, l'assemblage est facile, le Raspberry Pi est fixé par quatre vis et l'ensemble ne dépare pas parmi les autres éléments de la chaîne.
Je recommande.
