Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
Aluminium Foot 20x10mm Black (Unit) - reviews - There is 1 review.
Jose A.
Small and stable feet
Aluminum feet well made and well finished, with a rubber washer underneath. They are very easy to install. I ordered 4 feet but only 2 of them came with fixing screws, I had to purchase 4 screws locally.
This black Aluminium stand for HiFi devices will allow you to bring stability and shock absorption to your system, which is equipped with a rubber...
