Jean Louis d.
ALIMENTATION
l'ampli est bon mais l'alimentation est une daube , celle si perturbe beaucoup le rendu , j'ai installer une...
A H.
OMG
I got: seat at the mixing desk
I paid: the bass
And I love this
Lennart H.
Audio extractor HDMI / MHL to I2S / Coaxial / Optical 4K 60Hz - reviews - There are 14 reviews.
Wiesław P.
Useful thing
The extractor did its job. You don't have to spend a lot of money on fancy HDMI i2S cables, because it works on inexpensive, well-made cables. The extractor allows you to extract DSD files from SACDs (finally!). You can connect it directly to a Blu-ray HDD or SSD and listen to music saved in DSD without using a computer. The only limitation is that you can only play DSD64 files, the higher ones, at least for me, are played in 176kHz pcm. And the power supply is necessary, because supposedly power goes through HDMI, but there are problems. So the power supply is a must.
Florent P.
Extraction directe au format DSD 2.8Mbits des SACD sur optique/coax à condition de le coupler avec une carte additionelle
Pour ceux qui n'ont pas d entrée HDMI sur leur DAC, j ai couplé ce dispositif au module additionel Interface / DAC ES9038Q2M I2S vers SPDIF / RCA vendu chez audiophonics également (https://www.audiophonics.fr/fr/modules-interfaces/module-interface-dac-es9038q2m-i2s-vers-spdif-rca-p-17046.html) via le connecteur I2S fourni. Résultats : flux DSD 2.8Mbits reconnu par mon DAC Teac UD701N depuis un lecteur blueray Sony UBP X500. Prévoir 2 alim 12V (https://www.audiophonics.fr/fr/adaptateurs-secteur/ifi-audio-ipower-mk2-adaptateur-secteur-alimentation-audio-faible-bruit-12v-18a-p-15500.html) pour alimenter le module. Parfait
mike s.
Flawless transaction
I wanted to capture the audio out from my AppleTV and send it to my DAC via i2s. This device helped me to achieve that goal. It required one extra hdmi cable in the signal as well as a second hdmi cable to handle the i2s duties. I also needed a 5V power supply that wasn’t included. I was shocked at how quickly the unit was delivered.
Burkhardt P.
Great solution
The item is for me a great solution for hearing SACDs in stereo (mostly with headphones) directly from my Cambridge Audio 752 BD through the Holo Audio May without any conversion to PCM.
In the May you've to set the I2S to ALT2 and then it's working without any problems.
lucien S.
aucun interet dans mon cas.
ne fonctionent pas pour moi avec en sortie un sony xm800 en hdmi sacd natif sur entre gustard x16 en i2s avec cette interface !!! a savoir......
Chris S.
OK
Marche bien mais on doit comprendre qu' on peut pas connecter HDMI Out avec son DAC si on voudrait utiliser I2S. À la place, on doit utiliser IIS Out. C'est aussi HDMI. Le nom est un peu trompeur. Pourquoi pas le qualifier I2S Out?
Akkrawat W.
This brings my old stuff Pioneer bdp-150 to life
Donato p.
Digital Interface HDMI / MHL to I2S / Coaxial / Optical
Connecting it to the Sony Universal Player the dual HDMI outputs (HDMI Video goes to my receiver 4k HDR Ultra HD) - (HDMI Audio feeds the I2S digital interface HDMI). True DSD Stereo playback works wonderfully
Chow s.
DSD 128
Hi, I'm using this converter too. However when connected to my Oppo 205 as a transport via I2S to my Pontus II it can obly play DSD 64 file. However when playing DSD 128 and above there is no sound. However my Pontus II led light show 1x and DSD while my Oppo 205 show DSD. Anyone facing this problem. Thanks
Recordcard ..
Au top!
Super cette interface et en plus abordable.
Autoalimenté par l'HDMi ce qui simplifie grandement son intégration.
Les flux DSD sont intégralement transmis sur l'I2S.
Coax, Optique et i2S pour 65 €, c'est cool.
Vincent B.
Simple (un peu trop peut etre) et efficace, mais...
Tout est dans le titre. Ou presque.
Pour qui cherchera à faire une extraction audio d'un lecteur DVD/BlueRay je pense que le produit fera l'affaire (bien que je n'ai pas testé le produit dans ce but).
Par contre pour qui voudra extraire l'audio de flux videos avec du dolby digital / dts ou dolby digital ex (etc... par exemple d'un decodeur video) là plus rien n'est certain : J'ai fait l'expérience d'échecs sur plusieurs flux de ce type (malgré les 3 réglages possibles TV/AMP/DOU).
Là ou le bas blesse est l'absence d'informations sur les capacités exactes (ou détaillées) du produit et de la puce semiconn associée.
En allant sur le site de SemiConn on peut voir toutes les fonctions supportées par la puce. Mais pas de mention hélas des flux audio Dolby & Co.
En contactant le fabricant directement (yes I did lol), on arrive à choper la réponse suivante : "Some DTS or dolby audio format can be support through SPDIF output." (sic)
Dommage qu'ils n'en disent pas plus, ce serait grandement utile.
Mais j'imagine qui dit dolby ou dts dit aussi licenses...
Un downmix PCM stéréo aurait été grandement utile il me semble (comme vu sur d'autres produits).
Bref pour ceux qui sont dans cette problématique de flux DTS/Dolby je conseillerais plutot d'aller voir la ref suivante : CYP CPRO-SE2DD ( https://www.audiophonics.fr/fr/extracteurs-hdmi/cyp-cpro-se2dd-convertisseur-hdmi-uhd-dts-dolby-digital-vers-spdif-rca-p-11932.html )
Bonne extraction audio a tutti !
Amaury C.
Fait le job !
Cette interface m'a permis de récupérer le signal DSD des SACD sur la sortie HDMI 2 de mon Oppo 105 pour l'envoyer sur un Gustard DAC-X16. Il en est de même du signal PCM 16 bits/44.1 kHz des CD. Liaison donc en HDMI (avec du 1.4 ou même du 1.3 ça fonctionne sans souci) entre l'Oppo et l'interface, puis un autre câble HDMI entre la sortie HDMI/I2S de l'interface et l'entrée HDMI/I2S du Gustard.
Alors, attention, car au début cela ne fonctionnait pas. J'avais en effet branché une alimentation secteur sur cette interface (4,5 V / 600 mA) et la diode rouge de mise sous tension s'était allumée normalement. Cependant, une fois les câbles HDMI branchés et un SACD mis en lecture je n'avais aucun signal. J'ai fini par me dire que ça ne marche pas et j'ai donc commencé par débrancher l'alimentation. J'ai alors constaté que la diode rouge restait allumée. En éteignant l'Oppo 105 elle s'éteignait aussi. Ce qui signifie que l'interface est alimentée via le câble HDMI et que l'alimentation secteur n'est pas nécessaire dans ce cas de figure. J'ai donc refait jouer un SACD et là j'ai vu s'afficher sur l'écran du Gustard "DSD 2.82 Mhz" et la musique bien sûr dans les HP. En espérant que ces précisions vous seront utiles. En tout cas, le résultat d'écoute est nettement meilleurs aussi pour la lecture des CD via l'HDMI/I2S plutôt qu'en coax, plus équilibré et "analogique" dans le haut-médium/aigu, basses plus profondes.
 (5)
Ha-Dê N.
Excellent produit, i2s compatible avec la plupart des DAC chinois
Simple mais efficace, permet enfin d'extraire le DSD des Sacd avec un lecteur blu ray compatible avec DSD en sortie hdmi, pour alimenter un DAC avec entrée hdmi i2S. Prenez un DAC de marque Gustard, Smsl ou Sabaj etc, dont l'hdmi i2s est un peu paramétrable et le tour est joué!
 (3)
Petrisor G.
Digital interface with HDMI / MHL input to I2S / Coaxial / Optique output
A good choice to extract audio stream from BlueRay/DVD a sent to a better external DAC.
 (4)
